Can I flat tow my Miata?
Postby Greasyman [OP] » July 6th 2012, 4:53pm
I want to buy one of these vans primarily to tow my Miata. I mentioned it in passing in another post, but I want to make sure the van is up to the task. Most trips are under 250 miles one way, with some hills but nothing really severe (iirc). The car weighs 2300 lbs or so, definitely no more than 2400 lbs. I'll be towing about once a month. I know these vans are rated for about 5000 lbs, so in theory they should be ok, but the really world doesn't always accept the theory.
Should I look for a van with a tow package, tow/haul button, specific rear end gearing, or is that stuff all nice but not necessary? If I find a van I really like but it doesn't have some or all of that stuff, should I buy it anyway? Any opinions on flat towing vs. a dolly? Trailers are out, I have no room to store one. Thanks for any and all advice.
Greasyman
Years of Membership: Greasyman has been a member for 9 full yearsGreasyman has been a member for 9 full yearsGreasyman has been a member for 9 full yearsGreasyman has been a member for 9 full yearsGreasyman has been a member for 9 full yearsGreasyman has been a member for 9 full yearsGreasyman has been a member for 9 full yearsGreasyman has been a member for 9 full yearsGreasyman has been a member for 9 full years
Re: Can I flat tow my Miata?
Postby AWDASTROVAN1999 » July 6th 2012, 5:00pm
Not a problem ... It'll do it with ease .... Ive towed many things with my 99 awd ... I'll part with it for $3k ...
You will have no problem with a rwd either ,,, Look for a deal and jump all over it ,, I'd get under it and look for rust , :driving: :driving: :driving:
AWDASTROVAN1999
Years of Membership: AWDASTROVAN1999 has been a member for 10 full yearsAWDASTROVAN1999 has been a member for 10 full yearsAWDASTROVAN1999 has been a member for 10 full yearsAWDASTROVAN1999 has been a member for 10 full yearsAWDASTROVAN1999 has been a member for 10 full yearsAWDASTROVAN1999 has been a member for 10 full yearsAWDASTROVAN1999 has been a member for 10 full yearsAWDASTROVAN1999 has been a member for 10 full yearsAWDASTROVAN1999 has been a member for 10 full yearsAWDASTROVAN1999 has been a member for 10 full years
Topics: 9
Images: 2
Postby Philly758 » July 6th 2012, 6:30pm
My understanding is that a RWD model has a slightly higher towing rating than the AWD. If you don't need AWD then RWD would probably be best for a towing specific van.
Tow/haul mode will definitely be a plus. 3.73 gears seem to be the crowd pleaser for towing as well as fun to drive.
Flat towing/dolly is probably up to you. If the rear sags it is cheap enough to upgrade the rear with load adjusting shocks, they can be had for under $100.
The transmission will get hotter when towing, the tow/haul package has a transmission fluid cooler built into the radiator, but most everyone adds an aux trans cooler to their vans whether they are towing or not. That can be done easily for under $100 (or much less) depending on what you choose. Better safe than sorry especially if you don't have a gauge installed to monitor the temps.
Good luck.
:auto-gmcredsmiley:
2000 GMC Safari SLE, AWD - 150k+
- Lifted with 22-687 leaf springs and 2" blocks
- Cooper AT3 30x9.5's on Cragar Soft 8's
- Hellwig Rear Sway Bar
- TruCool Trans Cooler
- Corvette Servo
- Moog steering
- Bilstein HD's
- 3.73 G80
Philly758
Years of Membership: Philly758 has been a member for 10 full yearsPhilly758 has been a member for 10 full yearsPhilly758 has been a member for 10 full yearsPhilly758 has been a member for 10 full yearsPhilly758 has been a member for 10 full yearsPhilly758 has been a member for 10 full yearsPhilly758 has been a member for 10 full yearsPhilly758 has been a member for 10 full yearsPhilly758 has been a member for 10 full yearsPhilly758 has been a member for 10 full years
Topics: 36
Extra Info: SLE AWD
Postby Philly758 » July 6th 2012, 6:32pm
AWDASTROVAN1999 wrote:I'd get under it and look for rust
His profile says he's from Cali, he probably doesn't know what rust is...
:auto-gmcredsmiley:
- Corvette Servo
- Moog steering
- Bilstein HD's
- 3.73 G80
Philly758
Topics: 36
Extra Info: SLE AWD
Postby Jasen » July 7th 2012, 1:28am
AWD are rated at 5k where as the RWD are 5.5k You probably won't hardly even notice the Miata, unless the hitch breaks and a Miata just like yours passes you on the interstate ;)
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Years of Membership: Jasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full yearsJasen has been a member for 12 full years
Topics: 260
Images: 101
Return to Towing/Trailers
It is currently August 5th 2021, 2:11am
Towing/Trailers Forum
Keith1212
in Towing/Trailers
Date: Jul 28 '21
Time: 1:03am
swedishian
in Towing/Trailers
Date: May 03 '21
Time: 7:24pm
in Towing/Trailers
Comments: 22
Date: Mar 01 '21
Time: 10:49pm
in Towing/Trailers
Comments: 22
Date: Feb 28 '21
Time: 8:45pm
in Towing/Trailers
Comments: 53
Date: Dec 04 '20
Time: 11:04pm
