trailer wiring
trailer wiring
Postby fatguyzinc [OP] » December 13th 2008, 1:06am
ok, i did it- and it works! everything works perfect: tail, turn, stop, and hazards....still gotta figure out where to exit the body w/the harness, tho. i just got out my chilton manual, and looked at the wiring diagrams, also checked the net. bought a universal 4 pin harness connector from checkers, and 20 minutes later it was all good. wear rubber gloves, the stock harness is taped with some nasty sh*t that dont wanna come of your hands even with lava soap!
fatguyzinc
Years of Membership: fatguyzinc has been a member for 12 full yearsfatguyzinc has been a member for 12 full yearsfatguyzinc has been a member for 12 full yearsfatguyzinc has been a member for 12 full yearsfatguyzinc has been a member for 12 full yearsfatguyzinc has been a member for 12 full yearsfatguyzinc has been a member for 12 full yearsfatguyzinc has been a member for 12 full yearsfatguyzinc has been a member for 12 full yearsfatguyzinc has been a member for 12 full yearsfatguyzinc has been a member for 12 full yearsfatguyzinc has been a member for 12 full years
Topics: 7
Re: trailer wiring
Postby Positive P » December 13th 2008, 10:54pm
When I need to use mine, I just open the door and hook it up, and shut the door.
When not in use it's just lying in the back out of the way.
Positive P
Years of Membership: Positive P has been a member for 12 full yearsPositive P has been a member for 12 full yearsPositive P has been a member for 12 full yearsPositive P has been a member for 12 full yearsPositive P has been a member for 12 full yearsPositive P has been a member for 12 full yearsPositive P has been a member for 12 full yearsPositive P has been a member for 12 full yearsPositive P has been a member for 12 full yearsPositive P has been a member for 12 full yearsPositive P has been a member for 12 full yearsPositive P has been a member for 12 full years
Topics: 47
Alias (AKA): The Tongue-Fu Master
Van Model Year: 1990
Extra Info: 4.3L
Re: trailer wiring
Postby astro355 » December 14th 2008, 2:08am
Positive P wrote:When I need to use mine, I just open the door and hook it up, and shut the door.
That's a really good idea. Nothing like corroded wire connectors to ruin your day.
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Return to Towing/Trailers
It is currently January 20th 2021, 3:43am
Towing/Trailers Forum
in Towing/Trailers
Comments: 31
Date: Dec 04 '20
Time: 11:04pm
in Towing/Trailers
Date: Oct 23 '20
Time: 11:04pm
Date: Oct 19 '20
Time: 7:10pm
in Towing/Trailers
Comments: 21
Date: Sep 12 '20
Time: 7:47pm
Sailing_Faith
in Towing/Trailers
Comments: 21
Date: Sep 11 '20
Time: 5:50am
