Should I add trans cooler to a 2002 Astro w/factory tow pkg?
Postby Dollar_Bill [OP] » April 9th 2013, 1:34pm
My 2002 RWD Astro has the tow package withe button on the gear selection stalk for tow/haul mode. Can I assume it had a trans cooler? If so, should I add an external aftermarket?
Dollar_Bill
Years of Membership: Dollar_Bill has been a member for 10 full yearsDollar_Bill has been a member for 10 full yearsDollar_Bill has been a member for 10 full yearsDollar_Bill has been a member for 10 full yearsDollar_Bill has been a member for 10 full yearsDollar_Bill has been a member for 10 full yearsDollar_Bill has been a member for 10 full yearsDollar_Bill has been a member for 10 full yearsDollar_Bill has been a member for 10 full yearsDollar_Bill has been a member for 10 full years
Topics: 5
Re: Should I add trans cooler to a 2002 Astro w/factory tow
Postby jrsride2002 » April 9th 2013, 1:43pm
The answer will always be yes.
Without it, the trans would overheat(while towing). So ANY additional cooling would save you from that headache and financial burden.
Hope that helps,
'Junior
jrsride2002
Years of Membership: jrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full yearsjrsride2002 has been a member for 11 full years
Topics: 37
Images: 21
Alias (AKA): Junior
Van Model Year: 2001
Extra Info: LS V6 RWD
Postby Dollar_Bill [OP] » April 9th 2013, 1:54pm
jrsride2002 wrote:The answer will always be yes.
Hope that helps,
'Junior
Thanks, Junior, it helps, indeed!
Looking at a Hayden on Amazon a $52.95. I suppose (??) that I need the additional parts listed below?
Hayden Automotive 678 Rapid-Cool Plate and Fin Transmission Cooler by Hayden Automotive $52.92
Hayden Automotive 390 Transmission Line Fitting Kit by Hayden Automotive $11.20
Hayden Automotive 210 Mounting Kit System by Hayden Automotive $4.96 This item is available because of the new Add-on program
Anything else?
Dollar_Bill
Topics: 5
Postby RECox286 » April 9th 2013, 2:05pm
Yes, add the external cooler.
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby Dollar_Bill [OP] » April 9th 2013, 2:23pm
RECox286 wrote:Yes, add the external cooler.
Uncle Bob
Uncle Bob, I intend to add the external cooler, thanks.
Do I need to also order the extra parts from Amazon in my above post?
Dollar_Bill
Topics: 5
Postby Dollar_Bill [OP] » April 10th 2013, 12:12am
I think I have my answer. Ordering the cooler and parts. Will let you all know how this works out.
Thank You, Bill
Dollar_Bill
Topics: 5
Postby Corsemoto » April 10th 2013, 12:21am
Tru-Cool 4490 12"x11"x.75" came with everything needed for install and fits perfectly on passenger side of condenser.
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby RECox286 » April 10th 2013, 3:06am
Most external coolers come as kits with just about every thing except fluid. (Unless you are stealing one off a JY truck, Ha.)
I have even used the condensor off an old ice cream freezer refrigeration unit. Works dandy.
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Postby jrsride2002 » April 10th 2013, 10:45pm
Yea, I would start with the cooler kit first. Any other required parts would be a quick trip to NAPA or something like that.
~Junior
jrsride2002
Topics: 37
Images: 21
Alias (AKA): Junior
Postby thegreenmachine » April 11th 2013, 1:50am
Always yes. Cooler is better. I've thought of doing my power steering with one of these kits
"that looks legit"
95 AWD Safari money pit
thegreenmachine
Firing on 6 Cylinders (L2)
Years of Membership: thegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full years
Topics: 62
Alias (AKA): Shane a lane
Return to Towing/Trailers
It is currently October 25th 2020, 5:24am
Towing/Trailers Forum
in Towing/Trailers
Date: Oct 23 '20
Time: 11:04pm
Date: Oct 19 '20
Time: 7:10pm
in Towing/Trailers
Comments: 21
Date: Sep 12 '20
Time: 7:47pm
Sailing_Faith
in Towing/Trailers
Comments: 21
Date: Sep 11 '20
Time: 5:50am
Safarimeister
in Towing/Trailers
Comments: 21
Date: Sep 11 '20
Time: 2:57am
