to install a Tran Cooler or not
Postby Wolf991 [OP] » June 23rd 2009, 5:35pm
I have to vans a 1996 astro and a 2000 Safari the newer one has the towing/hauling button on it and would like to know should i get and oil cooler or not for them and if i do get one what kind shound i get the one for the 2000lb or the 5000lb can you guys let know
Thank you!!
Wolf991
Years of Membership: Wolf991 has been a member for 11 full yearsWolf991 has been a member for 11 full yearsWolf991 has been a member for 11 full yearsWolf991 has been a member for 11 full yearsWolf991 has been a member for 11 full yearsWolf991 has been a member for 11 full yearsWolf991 has been a member for 11 full yearsWolf991 has been a member for 11 full yearsWolf991 has been a member for 11 full yearsWolf991 has been a member for 11 full yearsWolf991 has been a member for 11 full years
Re: to install a Tran Cooler or not
Postby ghostrider1061 » June 23rd 2009, 5:59pm
to have a trans cooler is always good. if it was me i'd opt for the 5klb. you can never have to big a cooler.. :2:
ghostrider1061
Years of Membership: ghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full years
Topics: 17
Alias (AKA): d j
Extra Info: 4.3L v-6 rwd
Postby 'cudapaul » June 23rd 2009, 8:37pm
Here's a source:
http://www.bulkpart.com/Merchant2/merch ... de=coolers
I like this one and have used it in four vans:
http://www.bulkpart.com/Merchant2/merch ... ct_Count=1
You probably won't find better pricing either!
'cudapaul
Years of Membership: 'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years
Alias (AKA): 'cudapaul
Extra Info: LT AWD
Postby h2omelon » June 24th 2009, 12:28am
I installed the 10000lb trans cooler.The van runs cooler now also.
h2omelon
Years of Membership: h2omelon has been a member for 11 full yearsh2omelon has been a member for 11 full yearsh2omelon has been a member for 11 full yearsh2omelon has been a member for 11 full yearsh2omelon has been a member for 11 full yearsh2omelon has been a member for 11 full yearsh2omelon has been a member for 11 full yearsh2omelon has been a member for 11 full yearsh2omelon has been a member for 11 full yearsh2omelon has been a member for 11 full yearsh2omelon has been a member for 11 full years
Topics: 13
Extra Info: SLE 4.3 RWD
Postby Wolf991 [OP] » June 24th 2009, 3:11am
if the tran is to cool will it damge the tran if its to cold or is it ok to have the 5klb cooler
Wolf991
Postby adibv5 » June 24th 2009, 4:09am
i believe heat is a bigger factor...
cold is ok but must have the trans fluid that will not freeze i got amsoil they say -55degree low viscosity so should be good i post afther winter anyways i always warm up truck before drive. and if in series with the radiator will be worm enough so shift smooth.
adibv5
Years of Membership: adibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full yearsadibv5 has been a member for 11 full years
Postby Matrixx » June 24th 2009, 7:50am
Hi Wolf991
Here is some insight on how the Tru-Coolers work. Taken from Cudapauls first link.:)
"Tru-Cool" self regulating coolers - it's the oil that regulates the cooler. That is the principle behind the revolutionary new TRU-COOL SR series of self-regulating transmission oil coolers. Thicker oil that is below the ideal operating temperature bypasses the cooler through the upper two plates. When the temperature rises, it becomes thin enough to pass through the entire cooler and receive TRU-COOL's superior heat transfer efficiently, automatically.
Matrixx
Postby 'cudapaul » June 24th 2009, 7:57am
Yeah, what he said!
'cudapaul
Extra Info: LT AWD
Postby johnny-77 » June 24th 2009, 10:40pm
The Royal Canadia Mounted police pay a lab to test if a transmition can be over cooled and the extensive study basicly said any size cooler for a transmition can be used as long as the fuid is passed thrue the radiators cooler before it is sent back to the transmition. The issue that thay were concerned with was extreamly cold fluid could posible causes transmition shutter as it rappidly cools the transmition unevenly. Just a fact I ran across looking for a thermostatic type trany cooler.
Drive your van hard and long she deserves it!
forgive my terable spelling
johnny-77
Years of Membership: johnny-77 has been a member for 12 full yearsjohnny-77 has been a member for 12 full yearsjohnny-77 has been a member for 12 full yearsjohnny-77 has been a member for 12 full yearsjohnny-77 has been a member for 12 full yearsjohnny-77 has been a member for 12 full yearsjohnny-77 has been a member for 12 full yearsjohnny-77 has been a member for 12 full yearsjohnny-77 has been a member for 12 full yearsjohnny-77 has been a member for 12 full yearsjohnny-77 has been a member for 12 full yearsjohnny-77 has been a member for 12 full years
Alias (AKA): johnny
Postby Mr_Bowtie » June 25th 2009, 3:10am
I have always used the stock radiator in conjuction with the tranny cooler.
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Van Model Year: 1985
Extra Info: 350 with 700r4
Postby Wolf991 [OP] » June 25th 2009, 5:40pm
OK thank you guys my chevy truck is set up with the rad and the trany cooler that is how i will do it when i set my up will the cooler tell you which line to connceted to to the lower tran line or upper trany line
Wolf991
Postby Mr_Bowtie » June 26th 2009, 4:38am
The tranny cooler in my Van is hooked up to the top line of the radiator.....mine is a '92 though. Depends on if you want to run it through the tranny cooler or the radiator's cooler first? I don't think there is any harm in either way???? :shrug:
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Return to Towing/Trailers
It is currently December 5th 2020, 9:21am
Towing/Trailers Forum
in Towing/Trailers
Date: Oct 23 '20
Time: 11:04pm
Date: Oct 19 '20
Time: 7:10pm
in Towing/Trailers
Comments: 21
Date: Sep 12 '20
Time: 7:47pm
Sailing_Faith
in Towing/Trailers
Comments: 21
Date: Sep 11 '20
Time: 5:50am
Safarimeister
in Towing/Trailers
Comments: 21
Date: Sep 11 '20
Time: 2:57am
