Factory Tow Package
Factory Tow Package
Postby Gone Blue [OP] » August 12th 2009, 8:12pm
I am trying to decide if the 98 AWD that I just bought has the factory towing package. It has a class three hitch and the trailer wiring has 8 wires. I dont see a trans cooler unless it is on the back side of the radiator inside the fan shroud. The A/C evaperator core covers the whole front of the radiator as best as I can see.
Can anyone tell me what the RPO code is for this option?
I assumed that the factory tow package would include a trans cooler. Is this correct? Where would the trans cooler be located on a 98 AWD?
Thanks, G.B.
2" Overland Van's Lift Kit, 235/75/15 Cooper Discovery ATR Tires, KYB Gas Adjust Shocks, 98' Overhead Console added.........
Gone Blue
Years of Membership: Gone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full years
Topics: 20
Extra Info: AWD Base
  • 94 AWD - can I tow it on a dolly?
    by underhill » January 10th 2021, 11:17pm in Towing/Trailers
    January 12th 2021, 12:57am
    March 7th 2021, 6:19pm
Re: Factory Tow Package
Postby 'cudapaul » August 12th 2009, 9:17pm
The trans cooler is internal in the radiator. It is on the right (passenger) side inside the plastic tank.
'cudapaul
Years of Membership: 'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years
Alias (AKA): 'cudapaul
Extra Info: LT AWD
Postby ihatemybike » August 12th 2009, 9:23pm
As far as I know all the 1996 and newer vans had a trans cooler built into the radiator. At least all 4 of the ones I'm owned did. Don't recall of my pre-1996 vans did.
Aaron
Prev Astros:99,97,00,94,87,86
ihatemybike
Firing on 6 Cylinders (L2)
Topics: 68
Postby Gone Blue [OP] » August 13th 2009, 7:42pm
Thanks guys. That makes some sense why I dont see the trans cooler. Do you guys know what would of came with the towing package? Would it of just been the hitch and axle ratio? Thanks again, G.B.
Gone Blue
Topics: 20
Postby ihatemybike » August 13th 2009, 8:00pm
Usually it's just the hitch and wiring, though some models did have button on the gear selection stalk for tow/haul mode. My 2000 had it.
Aaron
ihatemybike
Topics: 68
Postby d0n » October 20th 2009, 9:21pm
I'm confused... my 2000 safari has the tow/haul mode switch on the end of the shifter, a bundle of wires near the jack and 3.42:1 rear end ratio... but it does not have a trailer hitch. :confused:
It obviously can't have the "factory tow package"... right? :shrug:
d0n
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: d0n has been a member for 11 full yearsd0n has been a member for 11 full yearsd0n has been a member for 11 full yearsd0n has been a member for 11 full yearsd0n has been a member for 11 full yearsd0n has been a member for 11 full yearsd0n has been a member for 11 full yearsd0n has been a member for 11 full yearsd0n has been a member for 11 full yearsd0n has been a member for 11 full yearsd0n has been a member for 11 full years
Topics: 17
Extra Info: AWD SLE
Postby Gus_Mahn » December 24th 2009, 8:56pm
I ordered my 97 new. It did come with the trailer package. I believe all the package included was wiring to the spare tire well. It didn't come with a hitch. Look up the http://www.c2e.info/rpocodes/ RPO codes on the door sticker to find out what options you have.
Gus_Mahn
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: Gus_Mahn has been a member for 12 full yearsGus_Mahn has been a member for 12 full yearsGus_Mahn has been a member for 12 full yearsGus_Mahn has been a member for 12 full yearsGus_Mahn has been a member for 12 full yearsGus_Mahn has been a member for 12 full yearsGus_Mahn has been a member for 12 full yearsGus_Mahn has been a member for 12 full yearsGus_Mahn has been a member for 12 full yearsGus_Mahn has been a member for 12 full yearsGus_Mahn has been a member for 12 full yearsGus_Mahn has been a member for 12 full years
Topics: 10
Postby paulo57509 » July 10th 2010, 7:34pm
Almost all automatic transmission vehicles have some kind of a transmission cooler plumbed into the radiator.
I think the TH-250 transmissions were air cooled and didn't have fluid coolers.
paulo57509
Firing on 7 Cylinders (L1)
Topics: 24
Extra Info: RWD
Postby Mr_Bowtie » July 10th 2010, 7:39pm
paulo57509 wrote:Almost all automatic transmission vehicles have some kind of a transmission cooler plumbed into the radiator.
^X2
I don't know if any Astro/Safari came with an external tranny cooler. :shrug:
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Van Model Year: 1985
Extra Info: 350 with 700r4
Postby LEVE » July 10th 2010, 7:44pm
On mine... it's got the tow package... but a 2nd external aftermarket unit was added.
LEVE
Years of Membership: LEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full years
Topics: 18
Extra Info: AWD 4.3L-W
Postby Mr_Bowtie » July 10th 2010, 7:50pm
LEVE wrote:On mine... it's got the tow package... but a 2nd external aftermarket unit was added.
Ya same here I have everything you could ask for, but no external tranny cooler from the factory... :think:
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Postby Leeann_93 » July 11th 2010, 3:26pm
^ yup, no external tranny cooler from the factory, which I don't understand. Neither my Bravada nor my Astro have an additional tranny cooler, which I will rectify on the Astro since, once it's running, it'll do most of the towing duties.
On my old '90 Dodge B250 w/360, when you got the towing package from the factory you got an additional tranny cooler plumbed in along with the radiator cooler (sandwiched in between the radiator and condensor).
Doesn't make much sense not to, imho.
Postby Mr_Bowtie » July 11th 2010, 4:06pm
My old '93 K5 Blazer had the towing package & it had the external cooler on it. Wonder how they decide what needs the external and what doesn't to be considered a towing package from the factory. :whack:
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Return to Towing/Trailers
It is currently March 7th 2021, 6:19pm
Towing/Trailers Forum
in Towing/Trailers
Comments: 22
Date: Mar 01 '21
Time: 10:49pm
in Towing/Trailers
Comments: 22
Date: Feb 28 '21
Time: 8:45pm
in Towing/Trailers
Comments: 53
Date: Dec 04 '20
Time: 11:04pm
in Towing/Trailers
Date: Oct 23 '20
Time: 11:04pm
Date: Oct 19 '20
Time: 7:10pm
