installed hitch and slung full size spare, one Q
Postby mattsrevenge [OP] » September 28th 2009, 4:45pm
finally installed my hitch!
orig cond.
purchased hitch from squeek daddy https://www.astrosafari.com/viewtopic.php?f=69&t=2683&start=20#p17515
sanded/wire wheel to get all the rust off (almost 3 hours worth), painted w/ rustoleum (sp?) rust converter 2x. then coated in rubberized undercoating 3x. then painted black paint 3x. pulled the orig bracket from the bumper and replaced- no sweat (alot faster than removal off the 92!). whats your thoughts? or does anyone have something to compare with? THANKS!
what i was wondering about...
in this pic, the fwd most bolt holes on the hitch dont have a frame hole/insert to screw into. on the 92 we pulled it from it had holes (i believe) notched into the frame to allow a bolt thru? im pretty sure i need this, but cant i weld it?
and
better shot of the bolts and the missing 'hole' in the frame for my 4th bolt on each side of the hitch. everything else lined up exact.
(see comments attached to photos)
and lastly,
fresh full size rim and used tire slung under, hitch painted and ready for a pull
ext pic
96 astro conversion
98 crown vic p71
mattsrevenge
Years of Membership: mattsrevenge has been a member for 12 full yearsmattsrevenge has been a member for 12 full yearsmattsrevenge has been a member for 12 full yearsmattsrevenge has been a member for 12 full yearsmattsrevenge has been a member for 12 full yearsmattsrevenge has been a member for 12 full yearsmattsrevenge has been a member for 12 full yearsmattsrevenge has been a member for 12 full yearsmattsrevenge has been a member for 12 full yearsmattsrevenge has been a member for 12 full yearsmattsrevenge has been a member for 12 full yearsmattsrevenge has been a member for 12 full years
Extra Info: 2wd conversion
Re: installed hitch and slung full size spare, one Q
Postby tommckay » September 28th 2009, 6:38pm
The full size will fit where the donut is?
Why do it if it ain't fun?
95 Astro Cargo (for winter and RC hauling)
90 Honda Goldwing (Ridden as much as possible)
07 Kia Rondo (Wife's car)
tommckay
Years of Membership: tommckay has been a member for 11 full yearstommckay has been a member for 11 full yearstommckay has been a member for 11 full yearstommckay has been a member for 11 full yearstommckay has been a member for 11 full yearstommckay has been a member for 11 full yearstommckay has been a member for 11 full yearstommckay has been a member for 11 full yearstommckay has been a member for 11 full yearstommckay has been a member for 11 full yearstommckay has been a member for 11 full years
Topics: 19
Extra Info: 4.3 RWD Cargo
Postby mattsrevenge [OP] » September 28th 2009, 7:27pm
yup! i was surprised as well. when i dropped the spare tire, it was a "universal" (guessing it could have fit a 4-6 lug combo somehow, it had way more than 6 holes, huh, come to think of it- i never counted em. maybe later) spare under. dry rotted and more rust than paint. had to hammer the 'T' at the end of the wire line to get the rim+T separate (rusted together). the general cond of the winch mech and the fact that mine was coated in axle grease (thanks dad!!) there was no rust on the winch/pully (whatever you call it). so i decided to try it out. cuts a little ground clearance down but is still a few inches above the rear diff gear housing. my only other thought was the weight. there is ~7lb diff maybe, but im not sure from spare to full.
96 astro conversion
98 crown vic p71
mattsrevenge
Postby tommckay » September 28th 2009, 11:43pm
Good to know!
tommckay
Topics: 19
Postby Mr_Bowtie » September 29th 2009, 5:06am
Nice work! Both of my Vans the spare tire holder is just junk. Too many WI winters. :lol:
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Van Model Year: 1985
Extra Info: 350 with 700r4
Postby mattsrevenge [OP] » September 29th 2009, 1:30pm
any thoughs on the hitch? 3 bolts suffice, or 4 req? i wish i had the install inst. the label on the hitch was trashed (no model #) is why i ask.
96 astro conversion
98 crown vic p71
mattsrevenge
Postby ghostrider1061 » September 30th 2009, 8:54am
never hurts to run a bead of weld when in doubt. better to be safe then sorry. i would weld all joints where hitch meets frame. :2:
ghostrider1061
Years of Membership: ghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full years
Topics: 17
Alias (AKA): d j
Extra Info: 4.3L v-6 rwd
Postby mattsrevenge [OP] » September 30th 2009, 3:05pm
kudos ghostrider, all i need to do is find a welder!
96 astro conversion
98 crown vic p71
mattsrevenge
Postby fm-usa » October 13th 2009, 4:43pm
Had to clean out the garage this year, not enough space for my new-to-me GL1500.
After (disposing of) a few Astros in my past I accumulated a few spacesaver tires.
I got 2 stacked under the rear even with a class 2 hitch that I made.
Fits just like your fullsize tire, barely noticeable from the rear.
The right size hammer fixes anything.
Current ride(s):
2000 Astro rwd w-266K+
1991 GoldWing w-145K+
Best of both worlds!
:thumbup:
fm-usa
Years of Membership: fm-usa has been a member for 11 full yearsfm-usa has been a member for 11 full yearsfm-usa has been a member for 11 full yearsfm-usa has been a member for 11 full yearsfm-usa has been a member for 11 full yearsfm-usa has been a member for 11 full yearsfm-usa has been a member for 11 full yearsfm-usa has been a member for 11 full yearsfm-usa has been a member for 11 full yearsfm-usa has been a member for 11 full yearsfm-usa has been a member for 11 full years
Alias (AKA): FM
Extra Info: RWD
Postby astroturf » October 13th 2009, 5:39pm
fm-usa wrote:Had to clean out the garage this year, not enough space for my new-to-me GL1500.
That is good to know. Thanks, Jim
ps a pic of that would be cool.
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby dentprone » October 13th 2009, 6:04pm
mattsrevenge wrote:kudos ghostrider, all i need to do is find a welder!
PM me if you ever find yourself in FL
dentprone
Years of Membership: dentprone has been a member for 11 full yearsdentprone has been a member for 11 full yearsdentprone has been a member for 11 full yearsdentprone has been a member for 11 full yearsdentprone has been a member for 11 full yearsdentprone has been a member for 11 full yearsdentprone has been a member for 11 full yearsdentprone has been a member for 11 full yearsdentprone has been a member for 11 full yearsdentprone has been a member for 11 full yearsdentprone has been a member for 11 full years
Postby tommckay » October 13th 2009, 6:16pm
Another Winger!
tommckay
Topics: 19
Postby Uncle Fester » April 1st 2011, 4:53am
The proper temp spare and a full size spare will be the same over all height, just different thickness, full size being thicker than the skinny temp.
As for the hitch, GREAT JOB cleaning it up ! I would add the forth bolt. My thought is, the factory, who ever it is, put it there for a reason , true? The welded bead all around would not hurt, and would stiffen up the frame side to side.... could be a frame saver in a wreck, was in my case. So, I would add the last bolt, even if you have to go to a hitch shop and have them do it. They can do the weld for you too if you go that route. . . .
Good luck and keep the pics coming ! :rockon:
Proud owner of "S.l.u.t. Puppy" , a 1992 Chevy Astro and a 1987 Ford E-150 Custom Dually named "Wolf Den"
Uncle Fester
Years of Membership: Uncle Fester has been a member for 12 full yearsUncle Fester has been a member for 12 full yearsUncle Fester has been a member for 12 full yearsUncle Fester has been a member for 12 full yearsUncle Fester has been a member for 12 full yearsUncle Fester has been a member for 12 full yearsUncle Fester has been a member for 12 full yearsUncle Fester has been a member for 12 full yearsUncle Fester has been a member for 12 full yearsUncle Fester has been a member for 12 full yearsUncle Fester has been a member for 12 full yearsUncle Fester has been a member for 12 full years
Topics: 20
Alias (AKA): Fester
Extra Info: 2wd
Postby smokinjoe » April 1st 2011, 4:31pm
As for the full sized spare. The idea is right but the method is flawed. That cable can barely hold the donut & the full sized is substantially heavier. Check out my fix thread.
viewtopic.php?f=66&t=10940&p=117918&hilit=spare+mount#p117918
That cable system (on all vehicles) is sub-par for its intended job. They even had a whole segment on motor week addressing it. If (when) it fails you can imagine the catastrophic results. 70mph projectile on highway in the rain? Not a good scenario.
smokinjoe
Firing on 5 Cylinders (L2)
Topics: 268
Alias (AKA): smokinjoe
Van Model Year: 2002
Extra Info: RWD
Postby throrope » April 1st 2011, 5:50pm
nice install.
I wouldn't worry about welding as long as all available threaded bolt holes are in use. GM put them there for hitches in the first place. I also suspect that the hitch rating as bolted exceeds the tow rating. The extra bolt holes on the platform may be there to fit both the shorty and EXT's. If you need greater confidence, next time you rent a U-haul trailer, compare their platform with yours.
If I get a moment, I'll check our OEM manual for specifics.
throrope
Years of Membership: throrope has been a member for 9 full yearsthrorope has been a member for 9 full yearsthrorope has been a member for 9 full yearsthrorope has been a member for 9 full yearsthrorope has been a member for 9 full yearsthrorope has been a member for 9 full yearsthrorope has been a member for 9 full yearsthrorope has been a member for 9 full yearsthrorope has been a member for 9 full years
Extra Info: LT 4.3L AWD
Return to Towing/Trailers
It is currently January 20th 2021, 4:30pm
Towing/Trailers Forum
in Towing/Trailers
Comments: 31
Date: Dec 04 '20
Time: 11:04pm
in Towing/Trailers
Date: Oct 23 '20
Time: 11:04pm
Date: Oct 19 '20
Time: 7:10pm
in Towing/Trailers
Comments: 21
Date: Sep 12 '20
Time: 7:47pm
Sailing_Faith
in Towing/Trailers
Comments: 21
Date: Sep 11 '20
Time: 5:50am
