Wiring
Wiring
Postby Wolphin [OP] » March 23rd 2008, 3:45am
I am working to setup a 7-pin power connector, but I can't find where to get the brake line or accessory 12V, or what gauge of wire I need for it. I have the 6-wire harness wired to a 4-wire connector, but I need to get the rest of the wires run.
I also don't know what the difference between the 12V and Auxiliary lines are, that are on the 7-wire connector.
Do trailers not have backup lights? How about the "High Centre Taillight" wire in the harness?
Wolphin
Years of Membership: Wolphin has been a member for 12 full yearsWolphin has been a member for 12 full yearsWolphin has been a member for 12 full yearsWolphin has been a member for 12 full yearsWolphin has been a member for 12 full yearsWolphin has been a member for 12 full yearsWolphin has been a member for 12 full yearsWolphin has been a member for 12 full yearsWolphin has been a member for 12 full yearsWolphin has been a member for 12 full yearsWolphin has been a member for 12 full yearsWolphin has been a member for 12 full years
Alias (AKA): Wolphin
Extra Info: 4.3 L V6 AWD
Re: Wiring
Postby Jesse-James » March 30th 2008, 12:12am
Are you running a brake controller? if not just use a pigtail adapter if you need a 7 pin for your trailer.
Jesse-James
Years of Membership: Jesse-James has been a member for 12 full yearsJesse-James has been a member for 12 full yearsJesse-James has been a member for 12 full yearsJesse-James has been a member for 12 full yearsJesse-James has been a member for 12 full yearsJesse-James has been a member for 12 full yearsJesse-James has been a member for 12 full yearsJesse-James has been a member for 12 full yearsJesse-James has been a member for 12 full yearsJesse-James has been a member for 12 full yearsJesse-James has been a member for 12 full yearsJesse-James has been a member for 12 full years
Re: Wiring
Postby Wolphin [OP] » March 30th 2008, 1:24am
Well, I want to have the full wiring, not just a partial one, as I want the capability of using it without having to re-wire it in the future, or worse.....
Wolphin
Re: Wiring
Postby Jesse-James » March 30th 2008, 6:40pm
Gotcha. Here ya go.....
Jesse-James
Re: Wiring
Postby Wolphin [OP] » March 30th 2008, 9:11pm
Thanks! :goodpost: I had the diagram, I just didn't know that the centre auxiliary wire is typically wired to the backup wire. I have that wire at the back, so that one is easy to connect.
The biggest thing that I still need answered: Where do I connect the wire for the electric brake line? :banghead: I can't find the details for that wire anywhere!
Wolphin
Re: Wiring
Postby Wolphin [OP] » March 30th 2008, 9:39pm
Nevermind... Found the details! http://www.etrailer.com/faq_brakecontroller.aspx
Basically, you tap the brake switch (that is on the back of the brake petal), to a brake controller unit (that I need to still get), Power and ground to it, and wire the output to the electric brake wire!
Now I just have the get the hitch mounted, and the additional wires run....
Wolphin
Re: Wiring
Postby Jesse-James » March 31st 2008, 2:53am
If you haven't bought your controller yet Prodigy is money well spent. I won't buy anything else.
This is the one I have in my Astro.
Jesse-James
Re: Wiring
Postby Wolphin [OP] » March 31st 2008, 3:24am
Hmm, that's exactly what I was looking at ;)
Wolphin
Re: Wiring
Postby PPerson » July 29th 2008, 11:50pm
I have a 2002 Astro AWD that came with the towing package. I'm looking to mount a 7-pin RV connector and be able to use my 16' landscape trailer with electric brakes. I've located the wiring harness in the back right compartment. As I peel back the tape covering the wires more are exposed to view. Using the previously posted chart I can figure out this end of the project. How simple is the hookup under the dash? Is there a place to just plug in a harness that then plugs into the brake controller or do I start from scratch, slicing into existing wiring?
Thanks,
Peter
PPerson
Years of Membership: PPerson has been a member for 12 full yearsPPerson has been a member for 12 full yearsPPerson has been a member for 12 full yearsPPerson has been a member for 12 full yearsPPerson has been a member for 12 full yearsPPerson has been a member for 12 full yearsPPerson has been a member for 12 full yearsPPerson has been a member for 12 full yearsPPerson has been a member for 12 full yearsPPerson has been a member for 12 full yearsPPerson has been a member for 12 full yearsPPerson has been a member for 12 full years
Van Model Year: 2002
Re: Wiring
Postby gtkane » July 30th 2008, 3:12am
Under the dash, you'll have to splice into the wire from the brake switch for a signal.
You'll also need a ground,12+ power, and a power out wire for the brakes.
No plug-n-play here.
User album #4...check it out!
gtkane
Years of Membership: gtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full years
Alias (AKA): Astruck
Extra Info: nasty 4.3
Re: Wiring
Postby PPerson » August 4th 2008, 5:33pm
OK, I contorted myself in under the dash and see the harness coming off the brake pedal arm. I'm assuming only one of the wires gets spliced into. By the way I think I'll remove the drivers seat to do the work.
or....
I may just "pay the man".
Thanks,
Peter
PPerson
Re: Wiring
Postby MVMan » August 9th 2010, 11:47pm
I am trying to install the brake controller and can not find the Blue wire & the orange wire under the driver side floor mat as per the owners manual. The wires are in the harness at the jack area, but I can not find them in front. Also having problem seeing/locating the brake light switch. Would very much like any help from anyone that has found them under mat.
MVMan
Years of Membership: MVMan has been a member for 10 full yearsMVMan has been a member for 10 full yearsMVMan has been a member for 10 full yearsMVMan has been a member for 10 full yearsMVMan has been a member for 10 full yearsMVMan has been a member for 10 full yearsMVMan has been a member for 10 full yearsMVMan has been a member for 10 full yearsMVMan has been a member for 10 full yearsMVMan has been a member for 10 full years
Alias (AKA): MVman
Extra Info: Tow Camper
Re: Wiring
Postby MVMan » September 19th 2010, 3:38am
Wolphin
You need to run three wires from under the hood to the 6/7 wire4 socket. You should use 10 gauge stranded or a min. of 12 gauge stranded. Connect the "AUX" wire to the A or B terminal or to the Hot side of the battery, use a 30 amp auto reset breaker or in line fuse. Connect the ground to the battery ground, I know you can get it in back, but when you add trailer brakes you will want a better ground. As for the last wire, it will be for the Brake on the trailer, will run from brake controller to 6/7 wire socket. Just a note a low cost way to get the wire and only have to run "one" line is to purchase a 10-3 extension cord at Lowe's or Home Depot and remove the plug. Run the cord front to rear leaving extra for easy reach to wire it up. The main thing when you use this method is to write which color heavy wire is which so you do not cross wire anything. Good Luck!
MVMan
Alias (AKA): MVman
Re: Wiring
Postby astroturf » September 19th 2010, 4:14am
MVMan wrote:Wolphin
Great Tip on the extension cord MVMan.
Thanks, Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Re: Wiring
Postby David78212 » June 9th 2012, 1:22am
I just ran the brakes controller wires for mine. Run a sheilded 10ga x 2 wires inside the frame rail almost the entire length of the van... nice and protected... You can buy the whole setup from eTrailer for about $58 and comes with everything you need to run the controller wiring for the trailer. Has 7 + 4 pin plugs and a 10, 20 and 30 amp auto reset breaker. I used a wire fish to run the wires in the frame rail, worked sweet... I then ran the wires needed for inside the cab through the parking brake grommet in the firewall... worked very nice, and I didn't have to make a new hole to run wires.
My install used the white wire on the brake pedal for the signal wire, everything else was pretty easy to figure out. I used the Prodigy P2 controller... No need for the big bucks P3, plus the P2 has the "slide switch" on the bottom to "test" the trailer brakes... the P3 has a button you push many times to do the same thing. The biggest difference between the P2 and P3 is electric to hydraulic controls which I do not need and the number of electric brakes / axles it will control. Since I have no plans on towing a 8 axle trailer with hydraulic brakes, I could not justify spending $80 plus dollars more for the P3 over the P2... Almost all the other features are identical.
"Common sense has to kick in at some point in time."
1991 GMC Safari, my $1,000 wonder.
1996 29ft Hi-Lo
David78212
Years of Membership: David78212 has been a member for 8 full yearsDavid78212 has been a member for 8 full yearsDavid78212 has been a member for 8 full yearsDavid78212 has been a member for 8 full yearsDavid78212 has been a member for 8 full yearsDavid78212 has been a member for 8 full yearsDavid78212 has been a member for 8 full yearsDavid78212 has been a member for 8 full years
Alias (AKA): David
Van Model Year: 1991
Extra Info: XT 4.3L RWD
Re: Wiring
Postby Big_kid » June 10th 2012, 5:31am
I had run a few extra wires when I replaced my carpet a few years ago, I used those. I wasn't able to figure out which wire I needed to tap into for the brake switch, but I did notice there was a hole for a second brake light switch. I stopped by a FLAPS, and $5 later had a separate switch dedicated solely to stopping my camper.
Firing on 7 Cylinders (L7)
Topics: 185
Images: 337
Extra Info: 2WD 5.7 V8
Re: Wiring
Postby SandpointSafari99 » October 21st 2015, 10:42pm
OK I've got most of these labeled using the test light. I have 3 unknown. Blue (I believe is for trailer brakes) orange per convention should be 12v power ?? Where does it go so I can get power to it? And bright green ( I have no idea. Please advise and correct me if needed.
SandpointSafari99
Years of Membership: SandpointSafari99 has been a member for 5 full yearsSandpointSafari99 has been a member for 5 full yearsSandpointSafari99 has been a member for 5 full yearsSandpointSafari99 has been a member for 5 full yearsSandpointSafari99 has been a member for 5 full years
Extra Info: AWD SLE Hi-Top
Re: Wiring
Postby AstroWill » October 21st 2015, 11:29pm
Orange is battery other end is under carpet near interior fuse box.
Dark blue for brake controller.
Lt. Green is reverse lights.
Images: 460
Re: Wiring
Postby SandpointSafari99 » October 23rd 2015, 4:24am
Thanks for the info.
SandpointSafari99
Re: Wiring
Postby SandpointSafari99 » October 23rd 2015, 4:52am
OK now why is there a second white ? I found it was brake lights( I marked it as STOP). What would you use that for?
SandpointSafari99
Return to Towing/Trailers
It is currently January 19th 2021, 10:15am
Towing/Trailers Forum
in Towing/Trailers
Comments: 31
Date: Dec 04 '20
Time: 11:04pm
in Towing/Trailers
Date: Oct 23 '20
Time: 11:04pm
Date: Oct 19 '20
Time: 7:10pm
in Towing/Trailers
Comments: 21
Date: Sep 12 '20
Time: 7:47pm
Sailing_Faith
in Towing/Trailers
Comments: 21
Date: Sep 11 '20
Time: 5:50am
