I just purchased a 2004 Astro LT with the "factory installed" trailer wiring. I say that because in the jack area in back, there was the 7 pin wiring, all nicely taped and such. Previous to the Astro, I had a Jeep, and there are several differences I noticed immediately after getting a Curt hitch and 7 pin plug hooked up today.
One was that when plugged in to the trailer wiring, the "running" lights on the trailer came on, irrespective of whether or not the lights in the Astro were on. I'm assuming this is due to the daytime running lights on the Astro?
A second thing is that when the ignition is turned off, it appears that it kills the power back to the trailer? Again, is this normal, as the Jeep would power the trailer until its battery was dead?
Thirdly, if the battery on the trailer is dead, will that prevent the Astro from powering things like the fridge and 12v lights and such? That is apparently happening, and I don't know if it is not wired correctly, or if that would affect the way the trailer gets power.
Thank you very much for your help!!
