Meterpig wrote:AstroWill wrote:Those guys probably don't know what they are talking about... ;)
If you read through what Haydyn says...
I have, and I will quote directly from their FAQ http://www.haydenauto.com/Installation- ... ntent.aspx
Hayden Automotive Installation FAQ for Mofos wrote:Q. Can you over cool the transmission fluid?
A. Transmissions are not highly sensitive to cool operating temperatures. However, in sub-zero (20-30° F) weather conditions transmission fluid can actually gel up in an external cooler and cease to flow, causing damage. Use of the radiator cooler actually helps warm the fluid under these conditions. It is critical in extreme cold conditions to use the original equipment cooler in series with the auxiliary cooler and allow the vehicle to warm up before driving.
If my reading comprehension has not failed on me, it states that in sub-zero (20-30° F) weather conditions the fluid can actually gel up in an external cooler and even cease to flow, causing damage ;) Then it continues to state that it's CRITICAL in extreme cold conditions to use the OEM cooler in series.
My summation is that you should always use the OEM cooler in series in most of North America, and it is CRITICAL to use the OEM cooler in series if your vehicle will ever experience extreme cold situations.
The rest I'm not even going to waste my time with.
