Anyone build a Front Wheel drive Astro flat bed tow truck ?
Postby trackvw [OP] » May 31st 2015, 3:28am
In Europe its pretty common to have a front wheel drive flatbed tow truck ,
some of them have twin axles in the back with smaller wheels so the loading bed can be much lower,
Will an All wheel drive AstroVan work with only the front wheel part hooked up ?
is it strong enough ?
I would be only hauling 2500-3000 pound cars , and mostly smaller 2000 pound cars....
Just an idea , maybe a crazy one :)
and if you have seen one please point me to the pictures
Thanks
trackvw
Years of Membership: trackvw has been a member for 6 full yearstrackvw has been a member for 6 full yearstrackvw has been a member for 6 full yearstrackvw has been a member for 6 full yearstrackvw has been a member for 6 full yearstrackvw has been a member for 6 full years
Re: Anyone build a Front Wheel drive Astro flat bed tow truc
Postby Astrofarian » May 31st 2015, 3:54am
:confused: Graft a tandem car hauler to the front subframe of an Astro....sure it would work. The question is WHY? Helluva lotta work to get a tow vehicle with no cab space and a WIDE turning radius. :confused:
-Mike-
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Postby Lumpy » May 31st 2015, 4:31am
There's no frame in an Astro. Making an "El Camino" or pickup or convertable/no top means removing the top half of the structural part of the van.
Build a frame under it and you might be able to strengthen it to the point where it's safe. Start loading weight on the back and it's an even bigger engineering think through.
If you do it, I want to see roughly eleven-gazillion photos. And none of those "turned on their side cellphone shots" either. It would look cool as heck.. :clap:
I suggest researching those who have built an El CaminoAstro to find out how they've dealt with the unibody, no frame issue. If they're still around, see if the thing is still together or has it buckled so much as to make the doors un-openable etc.
Hope it works!
Years of Membership: Lumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full yearsLumpy has been a member for 11 full years
Postby Astrofarian » May 31st 2015, 5:10am
PM Stan (DRZ) for info on doing an Astro pickup; And I hope you get it figured out. People have built some very ambitious project vehicles on this site. This would be one of them, for sure!
-Mike-
Astrofarian
Alias (AKA): M!ke
Postby Zebediah III » May 31st 2015, 5:45am
I see at least one like you're describing a week.
I think a shop near me builds them.
Zebediah III
Years of Membership: Zebediah III has been a member for 11 full yearsZebediah III has been a member for 11 full yearsZebediah III has been a member for 11 full yearsZebediah III has been a member for 11 full yearsZebediah III has been a member for 11 full yearsZebediah III has been a member for 11 full yearsZebediah III has been a member for 11 full yearsZebediah III has been a member for 11 full yearsZebediah III has been a member for 11 full yearsZebediah III has been a member for 11 full yearsZebediah III has been a member for 11 full years
Images: 16
Extra Info: 383 Crate Motor
Postby Lumpy » May 31st 2015, 6:01am
Zebediah III wrote:I see at least one like you're describing a week.
Damn! Keep your camera on standby and let us see a few, por favor!
Postby Meterpig » May 31st 2015, 6:04am
The astro van flexes like a russian ballerina..and that's with the "square" (not really square) body around it. I bet a version with out the box would really flex.
Don't know how long the front axle would last running full time. Keep the rear wheel drive and make a flatbed.
I would like to see someone raise the roof or at least everything behind the cab.
Meterpig
Firing on 5 Cylinders (L2)
Years of Membership: Meterpig has been a member for 6 full yearsMeterpig has been a member for 6 full yearsMeterpig has been a member for 6 full yearsMeterpig has been a member for 6 full yearsMeterpig has been a member for 6 full yearsMeterpig has been a member for 6 full years
Topics: 63
Alias (AKA): meterpig
Van Model Year: 2002
Extra Info: Not a minivan
Postby 97cargocrawler » May 31st 2015, 8:13am
Lumpy wrote:I suggest researching those who have built an El CaminoAstro to find out how they've dealt with the unibody, no frame issue. If they're still around, see if the thing is still together or has it buckled so much as to make the doors un-openable etc.
I heard those things are coffins on wheels. Brings the saying "meet your maker" to whole new levels of dumb.
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Postby markmitch » May 31st 2015, 4:01pm
Anything is possible, but the cost would far outweigh the useableness of the vehicle. What I suggest would be start with a truck frame with 4x4 figure out how to disable the rear axle then put the front cab section of an Astro fabricate it so you have the back section (like DRZ did) then attache the flatbed section. And if you do decide to take on such a project take gazillion pictures and post them here so we can see. Good luck Papa Mark
Teal Status (L7)
Teal Status (L7)
Topics: 635
Images: 21
Extra Info: RS V8 AWD
Postby trackvw [OP] » May 31st 2015, 5:05pm
Thanks for your thoughts
It is just an idea , there are many times that it would be useful but then I would need a place to store it....
My friend in Italy has one , that works out good for his shop, his is based on an Iveco truck
I have a couple car trailers too !
trackvw
Postby AstroWill » May 31st 2015, 9:59pm
I just wanted to say 'gazillion' too.
Topics: 109
Images: 481
Return to Towing/Trailers
It is currently June 25th 2021, 10:36am
Towing/Trailers Forum
swedishian
in Towing/Trailers
Date: May 03 '21
Time: 7:24pm
in Towing/Trailers
Comments: 22
Date: Mar 01 '21
Time: 10:49pm
in Towing/Trailers
Comments: 22
Date: Feb 28 '21
Time: 8:45pm
in Towing/Trailers
Comments: 53
Date: Dec 04 '20
Time: 11:04pm
in Towing/Trailers
Date: Oct 23 '20
Time: 11:04pm
