Rear (dutch) door speakers not working
Postby Vandy_B [OP] » December 19th 2016, 8:47pm
I have factory speakers in my dutch doors but they don't work. I pulled the panels and they are connected. I tested the passengers side by running a wire from the pillar speaker to that speaker and it worked, so it must be an issue with the wires (blue and green). I took the easy route and just spliced a wire into the pillar speaker wire and ran it through the access hole in the door and now it works. But that is just the passengers side.
The drivers side has the rear heater core in the way and I wasn't able to fish a wire through there. Anyone have any luck doing that without disassembling the whole heater and duct assembly? Any suggestions?
Thanks,
Andy
Vandy_B
Years of Membership: Vandy_B has been a member for 4 full yearsVandy_B has been a member for 4 full yearsVandy_B has been a member for 4 full yearsVandy_B has been a member for 4 full years
Topics: 33
Images: 19
Alias (AKA): andy
Extra Info: 4.3L V6 AWD
  • Front speakers issue. Tweeters work, rear speakers work.
    by Jakob1994 » December 9th 2020, 11:29pm in Mobile Electronics
    December 15th 2020, 2:03am
    49
    March 1st 2021, 8:18pm
Re: Rear (dutch) door speakers not working
Postby WimpTech » December 19th 2016, 8:49pm
Did you check the rear subamp for operation? Its behind the driver side center panel, behind the heater. Are you using the stock head unit?
WimpTech
Firing on 4 Cylinders (L5)
Topics: 38
Images: 322
Alias (AKA): =Wimpy=
Extra Info: AWD 3+1 Lift
Postby MI_Ghost » December 19th 2016, 8:58pm
Wimpazz wrote:Are you using the stock head unit?
This would be my first suspect.
~Ghost
Ast' Cargo: 2001 Astro Cargo
Beauty: 2009 Impala LT
MI_Ghost
Images: 107
Alias (AKA): Ghost
Van Model Year: 2001
Extra Info: Big White RWD Box
Postby Vandy_B [OP] » December 19th 2016, 9:11pm
The previous owner had the stock stereo replaced. I don't know about the rear subamp. I can certainly pull the side panel and look...sounds like a reasonable possibility for them not working. Does that subamp drive the rear pillar speakers too?
Um...what does it look like? anyone have a pic?
Thanks!
Vandy_B
Topics: 33
Images: 19
Alias (AKA): andy
Postby TurnNburn » December 19th 2016, 9:29pm
Wimpazz wrote:Image
TurnNburn
Green Status (L4)
Green Status (L4)
Alias (AKA): iGoogle
Postby dchan51360 » December 19th 2016, 9:31pm
Sub amp only drives the door speakers (sub frequencies only).
Wow. Dat's a big hand!
dchan51360
Firing on 7 Cylinders (L1)
Postby WimpTech » December 19th 2016, 9:50pm
Aftermarket radio does not play well with the sub-amp, or so I heard.
Sorry, gotta ask, did you make sure the fader was set correctly on the head unit? Never hurts to ask. Barring that, it sounds like the head unit was not installed correctly, might want to pull it and check the wiring. Pillar speakers are setup in the harness as rear speakers.
WimpTech
Topics: 38
Images: 322
Postby Vandy_B [OP] » December 19th 2016, 9:55pm
Thanks for posting the pic. I thought I remembered seeing something there when I had the panels off before so I checked there before I saw the pic. The amp is hooked up. But when I pulled the plug on it, nothing changed. So it seems like the stereo was not hooked up correctly.
And yes, the fader control was adjusted...but always good to ask!
So if the pillar speakers are the "rear" then what goes to the rear subamp?
Vandy_B
Topics: 33
Images: 19
Alias (AKA): andy
Postby dchan51360 » December 19th 2016, 10:04pm
You actually have to bypass the amp completely to remove the "sub woofer" aspect of that amp. If you just unplug it, the symptom will get worse.
Have you actually put your ear to one of the door speakers with the system turned up and the amp plugged in? I seem to recall that the frequency cross over on those door speakers is pretty low and almost inaudible.
dchan51360
Postby WimpTech » December 20th 2016, 12:00am
WimpTech
Topics: 38
Images: 322
Postby Vandy_B [OP] » December 20th 2016, 6:21pm
Thanks Wimpazz...that link is super helpful!
Vandy_B
Topics: 33
Images: 19
Alias (AKA): andy
Postby WimpTech » December 20th 2016, 6:25pm
Happy to help, Christopher did all the hard work though. We haven't heard from him in a while, hope all is well.
WimpTech
Topics: 38
Images: 322
Postby MI_Ghost » December 20th 2016, 8:10pm
Not sure why they call it an amp as it only seems to deamplify. My limited understanding of audio makes it sound more like a low band filter.
~Ghost
MI_Ghost
Images: 107
Alias (AKA): Ghost
Postby GreatWhite » January 7th 2017, 12:14pm
TurnNburn wrote:
Wimpazz wrote:Image
'04 GMC Safari SLT AWD
'07 Honda Element AWD
'97 Nissan Hardbody 4x4
https://www.youtube.com/watch?v=HWAAXrlt43s
GreatWhite
Years of Membership: GreatWhite has been a member for 4 full yearsGreatWhite has been a member for 4 full yearsGreatWhite has been a member for 4 full yearsGreatWhite has been a member for 4 full years
Topics: 18
Extra Info: AWD SLT 3+1 Lift
Postby chrstphr81620 » June 28th 2017, 7:33pm
Wimpazz wrote:Happy to help, Christopher did all the hard work though. We haven't heard from him in a while, hope all is well.
I'm here still! - I've been doing a lot more lurking than posting lately.
Glad that fix worked for ya. All I did was take all the jumbled info on all the threads and put it into one location. - Cheers!
1999 Astro AWD 4.3 "Fidel CastroVan"
chrstphr81620
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: chrstphr81620 has been a member for 4 full yearschrstphr81620 has been a member for 4 full yearschrstphr81620 has been a member for 4 full yearschrstphr81620 has been a member for 4 full years
Images: 66
Alias (AKA): Christopher
Extra Info: LS 4.3L V6 AWD
Return to Mobile Electronics
It is currently March 1st 2021, 8:18pm
Mobile Electronics Forum
BPACH
Date: Feb 24 '21
Time: 11:56pm
DriveDog
Date: Feb 05 '21
Time: 5:03am
Attached by: Birdshake
Birdshake
Date: Feb 04 '21
Time: 11:17pm
Comments: 9
Date: Nov 24 '20
Time: 5:12pm
Attached by: icebrrg3rd
icebrrg3rd
Date: Nov 11 '20
Time: 12:41am
