Sound deadening
Sound deadening
Postby Robesine [OP] » March 4th 2019, 1:53pm
Hello everyone,
I have seen many types of sound deadening around. I was wondering if anyone has noticed a big difference between the brands? I have been using GT mat 80 mil. Thanks in advance
On instagram @brick_city_fab
My Article About Types Of Car Lifts
Rock Corps member
Build Thread: Suzi Q Samurai Instagram #suziqbuggy
Build Thread: 199 Team HOONIGAN XJ
Cheap Thrills Racing #505 XJ - ECORS AA-class
Robesine
Years of Membership: Robesine has been a member for 2 full yearsRobesine has been a member for 2 full years
Alias (AKA): Jessica
Re: Sound deadening
Postby 1lowcab » March 4th 2019, 4:39pm
I have used pretty much all of it, Boom mat, GT mat, Noico, Dynamat, Kilmat, Fatmat...you name it.
It's all pretty much the same, adds mass to thin panels. I used Noico the last install.
If you want to save a little money use Peel & Seal on the floors, works great. Don't use it on anything vertical or over head, but it works perfect on floors.
1lowcab
Firing on 8 Cylinders (L3)
Years of Membership: 1lowcab has been a member for 5 full years1lowcab has been a member for 5 full years1lowcab has been a member for 5 full years1lowcab has been a member for 5 full years1lowcab has been a member for 5 full years
Topics: 58
Images: 165
Re: Sound deadening
Postby markmitch » March 4th 2019, 5:00pm
does any of that stuff cause rust to build up under it over time? Kinda like the stuff under the stock carpet does? Just curious -sorry to have changed the subject kinda sorta.
Firing on 8 Cylinders (L6)
Topics: 629
Images: 21
Extra Info: RS V8 AWD
Re: Sound deadening
Postby 1lowcab » March 4th 2019, 5:16pm
As longs as its clean and sealed (no bare metal) when you put it down it will be fine.
But honestly I've never pulled any to check under it.....once that stuff is down its a nightmare to pull up or remove!
That brings me to another thing. When installing any of those sound deadeners you have to use a roller and really press that stuff down for it to work it's best. Form it around every little angle and dip so it makes good contact with the surface.
1lowcab
Topics: 58
Images: 165
Re: Sound deadening
Postby sixsixsixsix is online! » March 4th 2019, 11:17pm
1lowcab wrote: ... Peel & Seal on the floors, works great. Don't use it on anything vertical or over head, but it works perfect on floors.
Tell me about your experience or what you may have heard about not using Peel & Seal on ceiling areas.
( I ask this rather sheepishly, hoping no one will notice )
And are there some that CAN be used overhead? Obviously with more expense. Maybe Dynamat?
Mike
I Love Peaches also & Wolverines and Gophers
Topics: 39
Images: 1359
Re: Sound deadening
Postby 1lowcab » March 5th 2019, 2:37am
Its fine to use Dynamat or any of the others on vertical surfaces or overhead.
The reason not to use Peel & Seal on vertical surfaces or overhead is because it doesn't stick as well and may, over time, come loose.
But its great on floors and saves a lot of cash using it there.
1lowcab
Topics: 58
Images: 165
Re: Sound deadening
Postby Birdshake » March 5th 2019, 4:54pm
I haven't had any issues with peal & seal on my ceiling and walls. I wiped down the interior with acetone and warmed up the peal & seal before applying it. its been stuck there for over 4 years. I am up north though.
2005 4WD Astro Cargo
NP236 3.73 Eaton Posi
S10 HD Springs 3" blocks
245/75/16 BFG KO2
KYB Monomax
Birdshake
Years of Membership: Birdshake has been a member for 9 full yearsBirdshake has been a member for 9 full yearsBirdshake has been a member for 9 full yearsBirdshake has been a member for 9 full yearsBirdshake has been a member for 9 full yearsBirdshake has been a member for 9 full yearsBirdshake has been a member for 9 full yearsBirdshake has been a member for 9 full yearsBirdshake has been a member for 9 full years
Topics: 10
Images: 28
Extra Info: 4.3 AWD
Return to Mobile Electronics
It is currently April 23rd 2021, 12:45pm
Mobile Electronics Forum
Attached by: LumaWJ
LumaWJ
Comments: 14
Date: Mar 22 '21
Time: 10:33am
Attached by: LumaWJ
LumaWJ
Comments: 14
Date: Mar 21 '21
Time: 8:39pm
Attached by: LumaWJ
LumaWJ
Comments: 14
Date: Mar 21 '21
Time: 3:41pm
BPACH
Date: Feb 24 '21
Time: 11:56pm
DriveDog
Date: Feb 05 '21
Time: 5:03am
