Aftermarket amp locations
Postby _brad_ [OP] » February 18th 2013, 10:31am
Where does everyone install their aftermarket amps in these vans?
_Brad_
_brad_
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: _brad_ has been a member for 11 full years_brad_ has been a member for 11 full years_brad_ has been a member for 11 full years_brad_ has been a member for 11 full years_brad_ has been a member for 11 full years_brad_ has been a member for 11 full years_brad_ has been a member for 11 full years_brad_ has been a member for 11 full years_brad_ has been a member for 11 full years_brad_ has been a member for 11 full years_brad_ has been a member for 11 full years
Topics: 25
  • Aftermarket auto safety devices
    by plainolebill » July 9th 2020, 9:17pm in Mobile Electronics
    Last post by dchan51360 View the latest post
    July 10th 2020, 7:00am
  • New Amp install Help
    by DoubleDeckerStudios » November 24th 2020, 5:13pm in Mobile Electronics
    November 25th 2020, 12:54am
    79
    December 1st 2020, 12:20am
Re: Aftermarket amp locations
Postby chevymaherchevymaher is online! » February 18th 2013, 12:35pm
Before I got the stereo that is so fricken loud it dont need one. Mine was by my knees under the dash. Straight down from the steering column to the right next to the dog house.
Postby markmitch » February 18th 2013, 12:45pm
mine is to big to put under the dash so its under the pass seat. I also had one mounted on the wall right behind the drivers seat, but if you have kids its a totally different thing.
Firing on 6 Cylinders (L6)
Topics: 615
Images: 20
Extra Info: RS V8
Postby StanVan » February 18th 2013, 11:34pm
I have 2, relatively small ones, one for each sub. And in my cargo van, they're on the left side wall, near the fuel inlet.
2000 Astro AWD Cargo Van rigged for camping.
StanVan
Years of Membership: StanVan has been a member for 12 full yearsStanVan has been a member for 12 full yearsStanVan has been a member for 12 full yearsStanVan has been a member for 12 full yearsStanVan has been a member for 12 full yearsStanVan has been a member for 12 full yearsStanVan has been a member for 12 full yearsStanVan has been a member for 12 full yearsStanVan has been a member for 12 full yearsStanVan has been a member for 12 full yearsStanVan has been a member for 12 full yearsStanVan has been a member for 12 full years
Alias (AKA): Stan
Extra Info: AWD Cargo
Postby JaxSPL » February 19th 2013, 1:00am
My amps are mounted to the back of the enclosure, since my enclosure is double walled all the way around (1.5" thick) and fiberglass resin spread over the wood (enclosure weights in at 900lbs without the subs).
"Installer's Nightmare" has officially come to life. Only 1 sub, but loud and clear.
Subwoofer enclosure designer. PM For More Info
JaxSPL
Firing on 8 Cylinders (L1)
Years of Membership: JaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full years
Topics: 45
Images: 9
Extra Info: 4.3L V6 SPL
Postby redfury » February 19th 2013, 5:53am
I had thought about installing amps if I ever went that route to under the rear seat along with a quick disconnect for the wiring in the event I needed to remove said seat and subs for hauling, otherwise I'd think about seeing if I could find a place behind the interior panels, though you aren't getting easy access if you decide you need to get at it for any reason. That's the problem with having no trunk. I can't mount it under the front seats due to them both being power as well. Passenger side non powered seat would be a great location and probably the cleanest install insomuch that you only have to run speaker wires to the back at that point.
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Extra Info: LT 5.7L 4wd
Postby mistayoung » July 15th 2013, 5:52am
If you have a 7 passenger under the mid row captains chairs is a good spot.
1997 Chevy Astro AWD
White/Silver 7 Passenger
mistayoung
Years of Membership: mistayoung has been a member for 12 full yearsmistayoung has been a member for 12 full yearsmistayoung has been a member for 12 full yearsmistayoung has been a member for 12 full yearsmistayoung has been a member for 12 full yearsmistayoung has been a member for 12 full yearsmistayoung has been a member for 12 full yearsmistayoung has been a member for 12 full yearsmistayoung has been a member for 12 full yearsmistayoung has been a member for 12 full yearsmistayoung has been a member for 12 full yearsmistayoung has been a member for 12 full years
Alias (AKA): 2finga
Postby thegreenmachine » July 16th 2013, 4:39pm
I put mine in the second row side pocket above the rear heater. Not the most ideal place but it works.
Sent from AutoGuide.com App
"that looks legit"
95 AWD Safari money pit
thegreenmachine
Firing on 6 Cylinders (L2)
Years of Membership: thegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full years
Topics: 62
Alias (AKA): Shane a lane
Return to Mobile Electronics
It is currently December 1st 2020, 12:20am
Mobile Electronics Forum
Comments: 9
Date: Nov 24 '20
Time: 5:12pm
Attached by: icebrrg3rd
icebrrg3rdicebrrg3rd is online!
Date: Nov 11 '20
Time: 12:41am
Date: Nov 10 '20
Time: 4:13am
Attached by: SportsBoy
SportsBoy
Date: Jul 24 '20
Time: 4:21am
wingvader
Comments: 46
Date: May 03 '20
Time: 9:15pm
