Hello Everyone! I'm thinking about putting an amp and sub in my van this summer and started doing a little measuring today. I'm a little picky when it comes to sub locations and do not want limit my cargo space by putting a standard box behind the rear seat. An option I am thinking of is putting the box with a low profile sub and amp under the third seat with a removable plug so i can take it out when the seats need to be removed.
However the main option I am thinking of now is building a box for a low profile sub to fit in the back corner where the spare tire jack is located and then covering it with the stock jack cover with a hole cut for the sub and port for a factory look if the vans would have come with subs, similar to some SUV's. I took some pictures and measurements today and it looks like a 12" low profile sub will fit tightly in the area, a 10" should fit with ease. Another problems with this location is the amp will have a very tight fit in this location and I am worried about heat generation.
If you guys can share some of your sub and amp locations and what low profile subs and amps you guys are using. Would a 10" sub offer similar power to a 12"? I am currently thinking about buying Alpine SWR-T12 with MRX-M110 but my friend said the Rockford Fosgate Punch P35D2-12 and P400x1 would be a good buy. Thanks guys.
