The antenna power wire is not hooked up. Antenna isn't powered.
The Dash light dimmer wire is not hooked up. Where does it go?
The remote wire is not hooked up. I don't have an amp.
This is a new van to me and the dash lights and only the dash lights do not work. Interior lights and headlights work. This issue is not new and was like this before the radio install.
I have checked the fuses underneath the steering column all are good.
I have a new dimmer switch to swap in hopes the dash lights will turn on.
So should I check the dimmer switch first and then move on to why the stereo isn't on and does the dash light dimmer wire need to be hooked up from the new aftermarket radio? And where does the dash light dimmer wire exactly go?
