Rear speaker wiring and ohms?
Postby ktthecarguy [OP] » March 21st 2010, 8:09am
Hi there,
I want to put new speakers in the rear pillars and the doors in my '92 Safari. I heard one time that the speaker ohms should be the same front to back, so as not to overload the amp in the head unit. I have an older Sony CD head unit (sorry, don't have the model handy).
My question is, were the original speakers wired in series, the pillar to the door? That's what the wiring looks like, anyway. And is the impedence important? For example, if I put 5" speakers with 4 ohms up front, should I use 4" speakers with 2 ohms in the pillars, and 5" speakers with 2 ohms in the doors?
Does this make any sense?
Thanks,
KT
ktthecarguy
Years of Membership: ktthecarguy has been a member for 10 full yearsktthecarguy has been a member for 10 full yearsktthecarguy has been a member for 10 full yearsktthecarguy has been a member for 10 full yearsktthecarguy has been a member for 10 full yearsktthecarguy has been a member for 10 full yearsktthecarguy has been a member for 10 full yearsktthecarguy has been a member for 10 full yearsktthecarguy has been a member for 10 full yearsktthecarguy has been a member for 10 full years
Alias (AKA): KT
Extra Info: old Swayback
  • Front speakers issue. Tweeters work, rear speakers work.
    by Jakob1994 » December 9th 2020, 11:29pm in Mobile Electronics
    December 15th 2020, 2:03am
    74
    January 16th 2021, 8:52am
Re: Rear speaker wiring and ohms?
Postby Jasen » March 21st 2010, 4:23pm
Not knowing the specs of your deck I'm going to say no. As far as I know, head units are typically 4 ohms. Running 2 ohm speakers will damage the amp in the deck and I believe the speaker.
If you us external amps you need to make sure they are stable down to 2 ohms.
As far as the front speakers being wired in series, are you taking a full range and a tweeter. Typically the tweeter would be wired through a cross over between the full range speaker and tweeter, or they both run through a cross over where you have one set of wires in and two set out, one for the full range and one for the tweeter, which are set at different cross over points.
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Postby rev_les » March 21st 2010, 4:35pm
I haven't checked the wiring, but 2 2 ohm speakers in series would be 4 ohms....... that being said, I don't recall seeing door speakers available in 2 ohm configuration, but I've been out of audio for a couple of years.I think mine were wired parallel with a coil on the rear door drivers to cut out high frequency.If you're just looking for a simple upgrade in sound, just ditch the rear door speakers, and run the ones in the c pillar,running a typical head unit at less than 4 ohms is gonna kill it.
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby tedanderson » March 21st 2010, 6:36pm
They don't necessarily have to carry the same load. It's just that as long as the load isn't lower than 4 ohms, no matter how you slice it, you will be fine. One thing that you can do is install a 1/4-watt or 1/2-watt resistor inline with each 4 ohm speaker to bring it up to 8 ohms and then when you connect the rear and pillar speakers in parallel, you will still maintain that 4-ohm load.
tedanderson
Firing on 8 Cylinders (L3)
Topics: 76
Alias (AKA): 2Big4aMiniVan
Return to Mobile Electronics
It is currently January 16th 2021, 8:52am
Mobile Electronics Forum
Comments: 9
Date: Nov 24 '20
Time: 5:12pm
Attached by: icebrrg3rd
icebrrg3rd
Date: Nov 11 '20
Time: 12:41am
Date: Nov 10 '20
Time: 4:13am
Attached by: SportsBoy
SportsBoy
Date: Jul 24 '20
Time: 4:21am
wingvader
Comments: 47
Date: May 03 '20
Time: 9:15pm
