Adding Factory Door Tweeters
Postby Gone Blue [OP] » May 2nd 2010, 4:19am
My base 98' Astro came with a base AM/FM radio only. No cassette or CD, just radio. Upgrading the sound system is not high on my list of mods right now but I did install some new Kenwood 6.5" speakers in the doors, because one of the factory door speakers was blown, and a Sony 10 disc CD changer that I had lying around. I picked up some factory door tweeters and grills during my last U Pull-It yard visit for $3.99 each. I had a pleasant surprise today when I took the door panels off to install them. I was sure that the tweeters would 1/4 turn into the back of the switch panel on my van just like they did in the van I took them out of. But what I didnt expect was that there was a connector in the doors to plug the tweeters into. This is the easiest mod I have ever seen. Once you remove the arm rest and switch panel, all you have to do is - Snap off the round solid blank tweeter cap, 1/4 turn the tweeter in, plug in the connector, and snap on the grill. The factory tweeters have capacitors wired on them to limit the low frequency so they will work with any combination of door speakers. I will take some pictures tomorrow when I button up the other side. G.B.
2" Overland Van's Lift Kit, 235/75/15 Cooper Discovery ATR Tires, KYB Gas Adjust Shocks, 98' Overhead Console added.........
Gone Blue
Years of Membership: Gone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full yearsGone Blue has been a member for 11 full years
Topics: 20
Extra Info: AWD Base
Re: Adding Factory Door Tweeters
Postby astroturf » May 2nd 2010, 8:46am
Gone Blue wrote:My base 98' Astro came with a base AM/FM radio only. No cassette or CD, just radio. Upgrading the sound system is not high on my list of mods right now but I did install some new Kenwood 6.5" speakers in the doors, because one of the factory door speakers was blown, and a Sony 10 disc CD changer that I had lying around. I picked up some factory door tweeters and grills during my last U Pull-It yard visit for $3.99 each. I had a pleasant surprise today when I took the door panels off to install them. I was sure that the tweeters would 1/4 turn into the back of the switch panel on my van just like they did in the van I took them out of. But what I didnt expect was that there was a connector in the doors to plug the tweeters into. This is the easiest mod I have ever seen. Once you remove the arm rest and switch panel, all you have to do is - Snap off the round solid blank tweeter cap, 1/4 turn the tweeter in, plug in the connector, and snap on the grill. The factory tweeters have capacitors wired on them to limit the low frequency so they will work with any combination of door speakers. I will take some pictures tomorrow when I button up the other side. G.B.
I love it when a plan comes together. Pix please... Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby Gone Blue [OP] » May 2nd 2010, 2:38pm
Here are a few pics of the tweeter install. G.B.
Blank Tweeter Caps
Molded in 1/4 turn feature for the tweeter
Tweeter Installed notice connector on door harness for tweeter
Ready to Rock
Gone Blue
Topics: 20
Postby astroturf » May 2nd 2010, 2:56pm
That is Awesome G.B. It was there just waiting for you. How does it sound? Thanks for the pix. Jim
astroturf
Topics: 112
Postby Gone Blue [OP] » May 2nd 2010, 3:39pm
astroturf wrote:That is Awesome G.B. It was there just waiting for you. How does it sound? Thanks for the pix. Jim
Jim,
It made a pretty big difference. The main door speakers are so low in the door and you sit up high in these vans, you lose a lot of the high end brilliance. After I get thru with my other mods I may look to replace the rear door speakers with some 6" sub woofers to give the system some more low end. Thanks, G.B.
Gone Blue
Topics: 20
Postby ShAgSTRO » May 2nd 2010, 3:42pm
Nice man! I would've loved to see your face when you saw that! haha
1986 Astro...I like my EFI carb ;)
ShAgSTRO
Years of Membership: ShAgSTRO has been a member for 10 full yearsShAgSTRO has been a member for 10 full yearsShAgSTRO has been a member for 10 full yearsShAgSTRO has been a member for 10 full yearsShAgSTRO has been a member for 10 full yearsShAgSTRO has been a member for 10 full yearsShAgSTRO has been a member for 10 full yearsShAgSTRO has been a member for 10 full yearsShAgSTRO has been a member for 10 full yearsShAgSTRO has been a member for 10 full years
Topics: 16
Extra Info: 4.3L
Postby webcat » May 2nd 2010, 7:49pm
Is the wiring allready there for subs?
On my 2002 Astro my stock rear 5 1/4 " speakers came from the factory wired like subs (low pass filters)
webcat
Firing on 3 Cylinders (L3)
Topics: 253
Alias (AKA): Larry aka Rambo
Extra Info: g10 5.7L vortec
Postby Gone Blue [OP] » May 2nd 2010, 9:43pm
No, I am going to replace the stock rear door speakers with 6.0 or 6.5" subs. My 98' has 6.5" speakers with low pass filters like yours in the rear doors and my plan is to replace them with subs and low pass filters. G.B.
Gone Blue
Topics: 20
Postby Vanguy » May 13th 2010, 6:42pm
When replacing my stock speakers with JL components, I noticed the plug in. But opted to use the included crossovers.
Although it certainly would have been handy to know about beforehand.
Vanguy
Years of Membership: Vanguy has been a member for 10 full yearsVanguy has been a member for 10 full yearsVanguy has been a member for 10 full yearsVanguy has been a member for 10 full yearsVanguy has been a member for 10 full yearsVanguy has been a member for 10 full yearsVanguy has been a member for 10 full yearsVanguy has been a member for 10 full yearsVanguy has been a member for 10 full yearsVanguy has been a member for 10 full years
Postby Gone Blue [OP] » May 13th 2010, 7:33pm
Vanguy wrote:When replacing my stock speakers with JL components, I noticed the plug in. But opted to use the included crossovers.
I think you still would not want to have used the factory tweeter wiring with your JL speaker set up. As you can see by the pictures above, the tweeters have the low pass filters on them as there is no cross over in the stock radios. I am not sure using this wiring would have gained you anything. G.B.
Gone Blue
Topics: 20
Postby JaxSPL » July 5th 2010, 7:13pm
In the 3rd pic. That capacitor on the back of the speaker is actually a high pass filter to block out the bass. A low pass filter blocks out the highs. and usually look like a resistor or wire coil.
"Installer's Nightmare" has officially come to life. Only 1 sub, but loud and clear.
Subwoofer enclosure designer. PM For More Info
JaxSPL
Firing on 8 Cylinders (L1)
Years of Membership: JaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full years
Topics: 45
Images: 9
Extra Info: 4.3L V6 SPL
Return to Mobile Electronics
It is currently December 2nd 2020, 1:04pm
Mobile Electronics Forum
Comments: 9
Date: Nov 24 '20
Time: 5:12pm
Attached by: icebrrg3rd
icebrrg3rd
Date: Nov 11 '20
Time: 12:41am
Date: Nov 10 '20
Time: 4:13am
Attached by: SportsBoy
SportsBoy
Date: Jul 24 '20
Time: 4:21am
wingvader
Comments: 46
Date: May 03 '20
Time: 9:15pm
