Wiring Color Codes - All Years
Postby JaxSPL [OP] » May 23rd 2010, 1:04am
From what I can gather all years of the Astro/Safari use the same color wiring. I haven't checked into the alarm wiring yet and will add it here once I confirm the wiring for all years.
Here are the color codes for the stereo:
Constant 12V+ / Orange
Switched 12V+ / Yellow
Ground / Black
Illumination / Gray
Dimmer / Brown
Antenna / Right Front
Left Front (+) / Tan
Left Front (-) / Gray
Right Front (+) / Light Green
Right Front (-) / Dark Green
Left Rear (+) / Brown
Left Rear (-) / Yellow
Right Rear (+) / Dark Blue
Right Rear (-) / Light Blue
Note: It is best to use an aftermarket wiring harness to install a new headunit/stereo. The above information will be useful for those that have cut wires in the stereo area.
Once I get all the information together I will have all the part numbers available for faceplate kits, antenna adapters, wiring harness, and what ever else is needed. I also believe this info was posted on the old forum but not sure. Will try to look soon.
"Installer's Nightmare" has officially come to life. Only 1 sub, but loud and clear.
Subwoofer enclosure designer. PM For More Info
JaxSPL
Firing on 8 Cylinders (L1)
Years of Membership: JaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full years
Topics: 45
Images: 9
Extra Info: 4.3L V6 SPL
Re: Wiring Color Codes - All Years
Postby chevy57bert » May 23rd 2010, 1:10am
ISO connector
chevy57bert
Section Moderator
Section Moderator
Firing on 7 Cylinders (L3)
Years of Membership: chevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full years
Topics: 69
Images: 68
Alias (AKA): Bertjuh
Extra Info: Ext 4.3L rwd
Postby jamestkirk » July 5th 2010, 8:42pm
aaahhhhhh! i just installed some new speakers and tried to figure out the +/- for the dark/light green and tan/grey. looked in my new snazzy service manual to no avail. lo and behold, it's right here in this thread!
my question is, if you've gotten the +/- mixed up what difference does it make? the speakers sound fine so far. looks like i'll probably yank the panels again and get it right....ugh!
kirk out
jamestkirk
Years of Membership: jamestkirk has been a member for 10 full yearsjamestkirk has been a member for 10 full yearsjamestkirk has been a member for 10 full yearsjamestkirk has been a member for 10 full yearsjamestkirk has been a member for 10 full yearsjamestkirk has been a member for 10 full yearsjamestkirk has been a member for 10 full yearsjamestkirk has been a member for 10 full yearsjamestkirk has been a member for 10 full yearsjamestkirk has been a member for 10 full years
Extra Info: AWD cargo van
Postby $uperJoe » July 5th 2010, 8:59pm
with the wires reversed you will have speakers out of phase. this will not be noticeable at higher frequencies and also on lower end speakers. what will suffer will be low end response from the speaker. this will make the stereo sound "tinny" and not produce clear lower notes, drum kicks, bass hits, and lower octave singers will sound "cloudy"
Check out my Van build
$uperJoe
Firing on 4 Cylinders (L2)
Years of Membership: $uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years$uperJoe has been a member for 11 full years
Topics: 59
Return to Mobile Electronics
It is currently January 24th 2021, 9:36am
Mobile Electronics Forum
Comments: 9
Date: Nov 24 '20
Time: 5:12pm
Attached by: icebrrg3rd
icebrrg3rd
Date: Nov 11 '20
Time: 12:41am
Date: Nov 10 '20
Time: 4:13am
Attached by: SportsBoy
SportsBoy
Date: Jul 24 '20
Time: 4:21am
wingvader
Comments: 52
Date: May 03 '20
Time: 9:15pm
