Rear Camera Install Not Working HELP
Postby corndogs [OP] » July 15th 2015, 1:47am
Installed my Pyle single din DVD player 7" . Ran a wire from the the head unit ( it was labeled BACK ) to the back of my 04 cargo van and attached it to the light green wire that was in the trailer wire bundle. Installed the camera and plugged in the video into the back of the radio and then at the camera there is a red and black wire. I don't think I have wired it to the right wires. Any help would be great.
corndogs
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: corndogs has been a member for 5 full yearscorndogs has been a member for 5 full yearscorndogs has been a member for 5 full yearscorndogs has been a member for 5 full yearscorndogs has been a member for 5 full years
Extra Info: Cargo Adventure Van
Re: Rear Camera Install Not Working HELP
Postby Meterpig » July 15th 2015, 2:29am
Do you have a way of checking the signal any other way?
Meterpig
Firing on 5 Cylinders (L2)
Years of Membership: Meterpig has been a member for 6 full yearsMeterpig has been a member for 6 full yearsMeterpig has been a member for 6 full yearsMeterpig has been a member for 6 full yearsMeterpig has been a member for 6 full yearsMeterpig has been a member for 6 full years
Topics: 63
Alias (AKA): meterpig
Van Model Year: 2002
Extra Info: Not a minivan
Postby Roger Ramjet » July 15th 2015, 2:47am
corndogs wrote:Installed my Pyle single din DVD player 7" . Ran a wire from the the head unit ( it was labeled BACK ) to the back of my 04 cargo van and attached it to the light green wire that was in the trailer wire bundle. Installed the camera and plugged in the video into the back of the radio and then at the camera there is a red and black wire. I don't think I have wired it to the right wires. Any help would be great.
Why would you tap into the trailer harness ? Green is right turn and brake lights . I tapped mine into the reverse light wiring . The red on the camera should be onto reverse light power and the black goes to ground . The only wire that runs to the front of the van to the radio is yellow rca ended cable .
I have two rear cameras , one that is powered buy the reverse light and it goes to RCA jack on the back of my dvd stereo single din .. The other one is on switched power and runs to a rear view mirror with built in little screen the mirror itself is also on the acc side and only works with key on . , I can turn it on anytime I want to see out the back of my van .. All my rear glass is covered in .
1997 Astro Van
Roger Ramjet
Years of Membership: Roger Ramjet has been a member for 7 full yearsRoger Ramjet has been a member for 7 full yearsRoger Ramjet has been a member for 7 full yearsRoger Ramjet has been a member for 7 full yearsRoger Ramjet has been a member for 7 full yearsRoger Ramjet has been a member for 7 full yearsRoger Ramjet has been a member for 7 full years
Topics: 9
Images: 11
Alias (AKA): Roger Ramjet
Extra Info: 2WD 4.3
Postby corndogs [OP] » July 15th 2015, 1:49pm
Light green is reverse/back up. When I go into reverse the monitor swithce over to the , It just does not show a video feed. There was a plug just sitting in the back cargo door when I took off the plate so I just used that for power. I'm thinking that may be the problem.
corndogs
Fueling (1/2 tank)
Fueling (1/2 tank)
Postby corndogs [OP] » July 15th 2015, 3:45pm
Ok, i have it wired to the reverse and it works, but since i ran a wire from back of radio to reverse light I think i want to wire the camera red wire to the reverse and also bridge it to constant key power so while im driving I can switch to rear camera also. Any suggestions?
corndogs
Fueling (1/2 tank)
Fueling (1/2 tank)
Postby Lumpy » July 15th 2015, 5:02pm
Postby corndogs [OP] » July 15th 2015, 5:25pm
thanks Lump.
corndogs
Fueling (1/2 tank)
Fueling (1/2 tank)
Postby corndogs [OP] » July 15th 2015, 5:29pm
Lumpy wrote:Image
Lump can the dash switch just be the camera function on the radio?
I'm not very smart when It comes to diodes. What way would I put the diode? I know they allow flow of current in only one direction.
Thanks
corndogs
Fueling (1/2 tank)
Fueling (1/2 tank)
Postby Lumpy » July 15th 2015, 5:39pm
I'm not familiar, of course, with what your radio switch does. But anything that provided +12v power would do the trick. If you put a meter or a light bulb on the output wire from your radio switch then flipped the switch on and off you would discover if that's the case. And you'd probably want it to provide power only when the IGN is on.
The diode would, as you correctly stated, allow the power from the B/U lamps to flow to the camera but it would BLOCK power from the switch flowing back into the B/U lamps. That way, when you flipped your switch, the camera would energize but the backup lamps would not come on. B/U lamps would still function normally with the transmission selector.
Typical diode like a 1N4001 would be a little cylinder with a wire sticking out each end. There's a paint stripe around one end of the diode. That paint stripe side goes toward the camera. Current can flow from the UNpainted side to the paint stripe side but not the other direction.
Those little diodes are rated at 1 amp. If you tried to power a device that required more than 1 amp you'd need a bigger diode or a relay. But the camera probably has very little draw. There's also a little voltage drop through the diode of about a volt. That shouldn't be a problem either with most cameras. But if it was, it's simple and cheap to install a relay. Then you can switch cameras, aux back up lights, M2 machine guns, oil slick deploy modules, blow up doll compressors etc.
Postby corndogs [OP] » July 15th 2015, 9:37pm
awesome, thanks.
corndogs
Fueling (1/2 tank)
Fueling (1/2 tank)
Postby Roger Ramjet » July 16th 2015, 12:27am
Sorry I thought you meant that you tapped into the trailer harness . Four wire , Green , Brown , Yellow , White . and not into the taillight harness
1997 Astro Van
Roger Ramjet
Topics: 9
Images: 11
Extra Info: 2WD 4.3
Return to Mobile Electronics
It is currently February 28th 2021, 10:38pm
Mobile Electronics Forum
BPACH
Date: Feb 24 '21
Time: 11:56pm
DriveDog
Date: Feb 05 '21
Time: 5:03am
Attached by: Birdshake
Birdshake
Date: Feb 04 '21
Time: 11:17pm
Comments: 9
Date: Nov 24 '20
Time: 5:12pm
Attached by: icebrrg3rd
icebrrg3rdicebrrg3rd is online!
Date: Nov 11 '20
Time: 12:41am
