2 Ohm Head Unit?
2 Ohm Head Unit?
Postby jeff's93astro [OP] » July 20th 2010, 6:06am
i've found a nice set of infinity speakers but they're all 2 ohm. and i cant find a 2 ohm head unit so are they safe to run on certain 4 ohm head units or am i not looking in the right place for a 2 ohm head unit. Or can i run them on my current head unit its an older one but seems like a real good unit
http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/In-Dash/CD-Players/DEH-P3500
And heres the speakers
http://www.millionbuy.com/inf629i.html
http://www.millionbuy.com/inf429i.html
95 Astro 5.3L RWD 3/3 drop
03 Suburban 5.3L 2wd 3/5 drop
jeff's93astro
Topics: 55
Images: 19
Extra Info: CS 4.3L V6 RWD
  • Upgrade stock head units? unlocking?
    by dcsleeperdcsleeper is online! » August 3rd 2020, 8:00pm in Mobile Electronics
    Last post by dcsleeperdcsleeper is online! View the latest post
    August 4th 2020, 10:48pm
    56
    December 4th 2020, 2:47am
Re: 2 Ohm Head Unit?
Postby LEVE » July 20th 2010, 6:18am
No... don't do it... you'll damage out the amplifier.
LEVE
Years of Membership: LEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full years
Topics: 18
Extra Info: AWD 4.3L-W
Postby jeff's93astro [OP] » July 20th 2010, 6:22am
thats what i thought.
These are the cheaper infinity speakers. Now would these be better than the blaupunkts in the dash and the memphis audios in the back doors i'm running now. they sound good but i dont like running mix match like that. O yea cant forget the boss 4" in the pillars
http://www.millionbuy.com/inf6032si.html
jeff's93astro
Topics: 55
Images: 19
Postby 94 Van Guy » July 20th 2010, 8:27am
If you were to connect two of them in series, it would add up to 4 ohms, then if you add another in the pillar, also in series, now it would be 6 ohms total, for the three speakers. It's been a while, but I think that is the way it works with speakers.
Check with a stereo install shop, they would know for sure. I wonder if they make these so one would be able to balance the impedance within the system.
Good luck, Keith
'91 Chevy G30 Bus 39.3K Miles
Retired
Safari
87 Safari, 91 Astro
86 Astro, 85 Astro
88 Astro, 92 Astro
89 Astro, 88 Astro
94 Van Guy
Firing on 5 Cylinders (L3)
Years of Membership: 94 Van Guy has been a member for 10 full years94 Van Guy has been a member for 10 full years94 Van Guy has been a member for 10 full years94 Van Guy has been a member for 10 full years94 Van Guy has been a member for 10 full years94 Van Guy has been a member for 10 full years94 Van Guy has been a member for 10 full years94 Van Guy has been a member for 10 full years94 Van Guy has been a member for 10 full years94 Van Guy has been a member for 10 full years
Topics: 71
Images: 44
Alias (AKA): Keith
Van Model Year: 1991
Extra Info: G30 Bus
Postby jeff's93astro [OP] » July 20th 2010, 9:12am
sounds like it'd be easier just to get 4 ohm speakers
jeff's93astro
Topics: 55
Images: 19
Postby JaxSPL » July 20th 2010, 12:16pm
You can do what Keith mentioned by running them in series, or get a 2ohm stable amplifier. I wouldn't go with running @6ohm. The 4ohm speakers would be easier to install.
"Installer's Nightmare" has officially come to life. Only 1 sub, but loud and clear.
Subwoofer enclosure designer. PM For More Info
JaxSPL
Firing on 8 Cylinders (L1)
Years of Membership: JaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full years
Topics: 45
Images: 9
Extra Info: 4.3L V6 SPL
Postby tedanderson » July 20th 2010, 12:19pm
Another thing that you can do is to install a ¼-watt 6-ohm resistor in series to bring it up to 8 ohms.
tedanderson
Firing on 8 Cylinders (L3)
Topics: 76
Alias (AKA): 2Big4aMiniVan
Postby jeff's93astro [OP] » July 20th 2010, 9:13pm
I've found a set of 4 ohm infintys so thats the route i'm gonna take. And i've never really tried different brands i've always used Sony everything :o (I know) I always thought sony was good stuff but after reading on here and seen reviews online on some of their products its really not as good as i thought. And the Pioneer head unit i got was gave to me from my dad and sounds really good for old as it is.
So now i'm stepping out on a limb and gonna try new stuff but i want reasonably good quality stuff and my question is would a Pioneer head unit go real good with these Infinitys.http://www.millionbuy.com/inf6032si.html
Also i do plan on upgradeing to a Pioneer premier within the next year if that help with quality or would i need a different brand head unit?
jeff's93astro
Topics: 55
Images: 19
Postby JaxSPL » July 21st 2010, 12:00am
As long as you stick with the main brands you'll be all right. Main brands = Pioneer, Alpine, Kenwood, Clarion, JVC. there are more, but those are the main ones I'll use (well, besides SoundStream products, but that's another class all together)
Stay away from Boss, Audiovox, Pyramid, Dual, Rampage, and anything you'll see new at a flea market.
Of course, it really all depends on what you want your system to do and sound like.
And yes, the pioneer will match up to the Infinitys real good. Infinitys usually are very good equipment and sound great.
JaxSPL
Topics: 45
Images: 9
Postby jeff's93astro [OP] » July 21st 2010, 12:43am
JaxSPL wrote:As long as you stick with the main brands you'll be all right. Main brands = Pioneer, Alpine, Kenwood, Clarion, JVC. there are more, but those are the main ones I'll use (well, besides SoundStream products, but that's another class all together)
Thats good i'll stick with Pioneer and it also looks like i'll be replaceing the Dual 12's in the back with infinitys also then.
And last thing i've got a 2 channel 400watt audiobahn amp bridged to those Duals which are wired in series in a band pass box. so would these Infinitys http://www.millionbuy.com/inf1260w.html
sound better in a band pass box or a sealed box.
jeff's93astro
Topics: 55
Images: 19
Postby tedanderson » July 21st 2010, 7:24pm
x2 on the brand name stuff.
As a teenager I was an avid fan of Pyramid. At age 16, I bought my first pair of 6x9 woofers from the stereo closeout sale, built a pair of oval shaped enclosures and then used an Audiovox amp to power them. I had a pretty decent sounding system..little did I know I bought a bunch of junk..
tedanderson
Topics: 76
Return to Mobile Electronics
It is currently December 4th 2020, 2:47am
Mobile Electronics Forum
Comments: 9
Date: Nov 24 '20
Time: 5:12pm
Attached by: icebrrg3rd
icebrrg3rd
Date: Nov 11 '20
Time: 12:41am
Date: Nov 10 '20
Time: 4:13am
Attached by: SportsBoy
SportsBoy
Date: Jul 24 '20
Time: 4:21am
wingvader
Comments: 46
Date: May 03 '20
Time: 9:15pm
