by haze5736 [OP] » August 22nd 2015, 11:48pm
by George Jetson » August 23rd 2015, 12:32am
by AstroWill » August 23rd 2015, 8:40am
by haze5736 [OP] » August 23rd 2015, 11:40am
George Jetson wrote:Found this but not sure about wire colors for other years.
2003 Chevrolet Astro Van Stereo Wiring Information
Radio Battery Constant 12v+ Wire: Orange
Radio Accessory Switched 12v+ Wire: Yellow
Radio Ground Wire: Black
Radio Illumination Wire: Gray
Stereo Dimmer Wire: Brown
Stereo Antenna Trigger Wire: Pink
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
by Leeann_93 » August 23rd 2015, 2:58pm
by haze5736 [OP] » August 24th 2015, 1:39pm
by George Jetson » August 24th 2015, 5:09pm
by Leeann_93 » August 24th 2015, 9:46pm
haze5736 wrote:Thank you Leann, that was so incredibly helpful. I don't understand why wire colors in the vehicle don't match the schematic. I had to go by the A/B labeling since my wire colors don't match.
Also, it would appear that the upper pillar speakers are not powered by the factory amp even though the wires go thru the connector. I was still getting sound from them after disconnecting the amp.
Does anyone know if I can use any of the existing wires as my remote signal to tun on the aftermarket amp? My aftermarket head unit has a remote signal wire but I would prefer not to run an additional wire if I'm already getting the signal through the factory wiring harness.
by magster65 » December 12th 2015, 8:28pm
It is currently March 1st 2021, 9:02pm
Mobile Electronics Forum |
Previous topic Next topic |
Sponsors |
