Double din install
Double din install
Postby Wakes03astro [OP] » September 29th 2015, 3:40am
Finally got around to installing my Pioneer avh-p4400bhs unit.
I used the bottom of the stock stereo.
Checking the fit. Figuring how to cover the side openings.
I bent the back (kinda) level. There was plenty of room so it didn't have to be cut.
Just about there.I used a Metra dash kit for a 2004 Toyota 4Runner SR5. I then slowly trimmed the bezel, checking for fit. It wanted to crack, but patience was key. I then sanded the cuts to smooth them out. Just a little bit more trimming up top.
Wakes03astro
Years of Membership: Wakes03astro has been a member for 6 full yearsWakes03astro has been a member for 6 full yearsWakes03astro has been a member for 6 full yearsWakes03astro has been a member for 6 full yearsWakes03astro has been a member for 6 full yearsWakes03astro has been a member for 6 full years
Images: 4
Alias (AKA): Wakes
Extra Info: Regency Conversion
  • New Amp install Help
    by DoubleDeckerStudios » November 24th 2020, 5:13pm in Mobile Electronics
    November 25th 2020, 12:54am
    31
    February 28th 2021, 4:51am
Re: Double din install
Postby WoodButcher » September 30th 2015, 1:43am
Welcome to the forum Wakes.
Pretty good fit, I see your not afraid of a little hacking. That's a good thing when so few aftermarket goodies are made for these vans anymore.
Do you have the stock CD still working? If not that space makes a good catch all for pens, phones and smokes. If you pull the player you can fab up a box and glue it to the back of the doghouse panel like my cargo was.
WoodButcher
Firing on 5 Cylinders (L6)
Topics: 30
Images: 514
Alias (AKA): Bruce
Extra Info: 5.7L RWD
Postby Wakes03astro [OP] » October 1st 2015, 12:57am
I enjoy doing stuff like this. The stock cd is disconnected and i plan on getting the pocket. A little bit at a time with my busy schedule. Thanks for the welcoming. Its good to finally make a post.
I borrowed a friends dremel. I need to purchase one. I just sanded the top and bottom a little bit and evened it out. Much better than hand sanding.
Wakes03astro
Images: 4
Alias (AKA): Wakes
Postby '97 astro man » December 12th 2015, 9:42pm
i have a question regarding the wiring you needed to do on this job.
did you need to acquire one of those PCA interfaces to connect the factory wiring to the radio or perhaps was it as simple as a Metra adapter fused straight to the factory wires?
if you only used the Metra adapter I'd guess you had to cut the factory connection to the factory radio and solder the wires together?
im stuck at this point on my job and could use some help...thanks!
'97 astro man
Years of Membership: '97 astro man has been a member for 5 full years'97 astro man has been a member for 5 full years'97 astro man has been a member for 5 full years'97 astro man has been a member for 5 full years'97 astro man has been a member for 5 full years
Postby Wakes03astro [OP] » January 18th 2016, 5:51pm
I picked up the Metra 70-1858 Radio Wiring Harness For GM 88-05 Harness and crimped the wires together to the new stereo. I also wired a relay so I didn't have to use the e-brake to watch videos. You simply unplug the wire harness from the back of the factory radio and plug the metro harness into that. No muss no fuss.
Wakes03astro
Images: 4
Alias (AKA): Wakes
Postby AstroWill » January 19th 2016, 4:25am
'97 astro man wrote:if you only used the Metra adapter I'd guess you had to cut the factory connection to the factory radio and solder the wires together?
Always use a vehicle specific adapter IMO. They are less than ~$10 and you don't have to cut the factory wires at all, that is what the adapter is for. You will however have to use connectors or solder to join the adapter to the new radio harness.
So it goes new radio harness, soldered/crimped to the vehicle specific harness and then it just plugs into the factory wiring.
Here is another install using the Metra kit. https://www.astrosafari.com/viewtopic.php?f=32&t=140564
Images: 472
Return to Mobile Electronics
It is currently February 28th 2021, 4:51am
Mobile Electronics Forum
BPACH
Date: Feb 24 '21
Time: 11:56pm
DriveDog
Date: Feb 05 '21
Time: 5:03am
Attached by: Birdshake
Birdshake
Date: Feb 04 '21
Time: 11:17pm
Comments: 9
Date: Nov 24 '20
Time: 5:12pm
Attached by: icebrrg3rd
icebrrg3rd
Date: Nov 11 '20
Time: 12:41am
