by Tripsouth [OP] » July 11th 2016, 5:06am
by Astrofarian » July 12th 2016, 1:29pm
by gavio » July 12th 2016, 4:40pm
by Leeann_93 » July 12th 2016, 11:03pm
gavio wrote:I get the impression that what you're thinking is to use the coolant line as a source for a heat exchange coil in a hot water tank? If so, then yes, I've seen it (and similar) done before.... I think best would be to replace the heater core with a copper coil, then enclose that in a dedicated hot water tank, add a thermostat and solenoid to control the heating to it doesn't become overly hot (or at least add a temperature gauge so you can turn it off in time and there ya go.... Simple, yes?
You could try using the heater core as it exists, just dropping that into a tank, but that design, while very good as a water-to-air heat exchanger is sub-optimal as a water-to-water exchanger...
As with most things, the devil's in the details so a good investment of time would be to google up the ways other folks have done it...
by Tripsouth [OP] » July 13th 2016, 4:08pm
by Tripsouth [OP] » July 21st 2016, 4:17pm
by 97cargocrawler » July 21st 2016, 11:35pm
by Tripsouth [OP] » October 26th 2016, 5:04am
by gavio » October 26th 2016, 6:04am
It is currently January 24th 2021, 8:28pm
Climate Control Forum |
Previous topic Next topic |
Sponsors |
