Heater not working
Heater not working
Postby buick68 [OP] » January 5th 2011, 2:48am
Hello, 1995 RWD Astro Van Conversion my heater is on the blink, works when it wants to work! I have to put the heater on low for 5 to 10 mins before it comes on, Then i can move it up one every 5 mins or so till i have heat on high speed :confused: Need help a/s/a/p thanks!!!!!!!!!!
buick68
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: buick68 has been a member for 11 full yearsbuick68 has been a member for 11 full yearsbuick68 has been a member for 11 full yearsbuick68 has been a member for 11 full yearsbuick68 has been a member for 11 full yearsbuick68 has been a member for 11 full yearsbuick68 has been a member for 11 full yearsbuick68 has been a member for 11 full yearsbuick68 has been a member for 11 full yearsbuick68 has been a member for 11 full yearsbuick68 has been a member for 11 full years
Topics: 21
Alias (AKA): jd
Extra Info: conversion
  • Front heater not working on full power
    by Paulc » March 1st 2021, 5:15pm in Climate Control
    Last post by Paulc View the latest post
  • Heater control valve leaks- always the valve?
    by highfigh » February 24th 2021, 5:13pm in Climate Control
    Last post by highfigh View the latest post
    March 11th 2021, 3:12pm
    7
    64
    April 15th 2021, 6:08pm
Re: Heater not working
Postby chevymaher » January 5th 2011, 3:02am
Is blower motor working and you not getting heat or is it the blower motor not coming on.Need more info
Topics: 91
Postby Phantom » January 5th 2011, 3:05am
Take a voltage meter and go to the blower resistor connector plug and test the voltage on each of the pins to see if you are getting voltage at each pin as soon as you turn the switch to each position , that should tell you if you are getting voltage to each speed level to the motor instantly or if you have to wait for it , it should be instantly ; If it is then maybe your resistor or motor is going bad . as the blower ages it starts to draw an increase in current till it goes out , , it also could be bad ground connections delaying the current flow , clean all ground connections in the circuit.
Phantom
Firing on 7 Cylinders (L4)
Postby buick68 [OP] » January 5th 2011, 3:30am
chevymaher wrote:Is blower motor working and you not getting heat or is it the blower motor not coming on.Need more info
Blower not comeing on as soon as i turn heat on, have to turn on low then wait 5 or so mins then turn up to high speed for blower motor to blow heat
buick68
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 21
Alias (AKA): jd
Postby chevymaher » January 5th 2011, 3:41am
Phantom the man on electrical stuff.Check grounds like he said.The resistor probably the culprit. here a picture of where it at.Under hood on left you will see it
Topics: 91
Postby buick68 [OP] » January 5th 2011, 3:44am
chevymaher wrote:Phantom the man on electrical stuff.Check grounds like he said.The resistor probably the culprit. here a picture of where it at.Under hood on left you will see it
:ty: that pic is a vry big help!
buick68
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 21
Alias (AKA): jd
Postby chevymaher » January 5th 2011, 3:55am
I more old school common kind of guy.I assume if you asking you were like I was when I was young wow my first time.You welcome
Topics: 91
Return to Climate Control
It is currently April 15th 2021, 6:08pm
Climate Control Forum
AOTD
in Climate Control
Date: Feb 27 '21
Time: 10:05pm
AOTD
in Climate Control
Date: Feb 27 '21
Time: 9:31pm
Attached by: Toskavat
Toskavat
in Climate Control
Comments: 17
Date: Feb 26 '21
Time: 4:13pm
Sailing_Faith
in Climate Control
Date: Feb 18 '21
Time: 9:05pm
sixsixsixsix is online!
in Climate Control
Date: Feb 17 '21
Time: 2:47pm
