Got Heat...Blower Fan...Nothing Out of Vents
Postby tntv [OP] » January 11th 2011, 10:01pm
How do I address no heat coming out of dash and floor when I can hear both fan motors working fine and can feel heat residual heat coming out. I can hear and feel it in the box under the passanger dash. No heat but same story on the rear heat too. Nothing in my Haynes manual. What do I take a part, if anything, to diagnose? Any help would warm my soul! Thanks. 2000 Astro 4.3L
tntv
Years of Membership: tntv has been a member for 10 full yearstntv has been a member for 10 full yearstntv has been a member for 10 full yearstntv has been a member for 10 full yearstntv has been a member for 10 full yearstntv has been a member for 10 full yearstntv has been a member for 10 full yearstntv has been a member for 10 full yearstntv has been a member for 10 full yearstntv has been a member for 10 full years
Extra Info: LT 4.3L V6 RWD
Re: Got Heat...Blower Fan...Nothing Out of Vents
Postby Phantom » January 11th 2011, 10:43pm
Blend door not moving , maybe a vacuum line has cracked and leaking , or maybe fallen off,
not sure on the rear heat as I have not worked on those
astro vacuum diagram.jpg (133.24 KiB) Viewed 1210 times
Phantom
Firing on 7 Cylinders (L4)
Postby swingkid72 » January 12th 2011, 9:40pm
Try the vaccuum line that is attached UNDER the Temp "Mixer" valve...mine came off and was doing the same thing.
swingkid72
Years of Membership: swingkid72 has been a member for 10 full yearsswingkid72 has been a member for 10 full yearsswingkid72 has been a member for 10 full yearsswingkid72 has been a member for 10 full yearsswingkid72 has been a member for 10 full yearsswingkid72 has been a member for 10 full yearsswingkid72 has been a member for 10 full yearsswingkid72 has been a member for 10 full yearsswingkid72 has been a member for 10 full yearsswingkid72 has been a member for 10 full years
Postby redfury » January 13th 2011, 12:41am
If you lost vacuum, then the blend door has probably closed on the dash heater, you should get defrost by default though. IF it's a loss of vacuum, then the rear heat solenoid has closed as it needs vacuum to pull the valve open to allow heat to flow to the rear heater.
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Extra Info: LT 5.7L 4wd
Postby tntv [OP] » January 13th 2011, 2:37am
Wow....found a fix on this site. Bad vacum line which solved the dash vent issue. Still can hear the fan working for the rear heater at the floor of driver's side passenger seat but nothing coming out. I'm pretty sure there is heat and the fan is working. Another...different vacum line? Also, I'm still not getting anything on the driver's side floor. Great site.
tntv
Postby UsedCarTech » January 16th 2011, 2:12am
Ok so I dont know to start a new one or put it hear? I have read a few of this same problem up hear and I have found what is wrong but my vacum setup is differnt from the diagam up here and the dealer. Maybe the guy before me change it. So my question is do you need to use the vacum resovor thing. And any advice on a hole in the fiewall for running new vacum lines? My factor one broke right behind the battery.
UsedCarTech
Years of Membership: UsedCarTech has been a member for 10 full yearsUsedCarTech has been a member for 10 full yearsUsedCarTech has been a member for 10 full yearsUsedCarTech has been a member for 10 full yearsUsedCarTech has been a member for 10 full yearsUsedCarTech has been a member for 10 full yearsUsedCarTech has been a member for 10 full yearsUsedCarTech has been a member for 10 full yearsUsedCarTech has been a member for 10 full yearsUsedCarTech has been a member for 10 full years
Alias (AKA): Tony
Extra Info: 4.3l v6 rwd
Postby 96 astro » January 30th 2011, 9:13pm
we had the same on our 96 van and it turned out to be the pipe connector under the rad / washer bottle area connect back up and heat works again..
96 astro
Years of Membership: 96 astro has been a member for 12 full years96 astro has been a member for 12 full years96 astro has been a member for 12 full years96 astro has been a member for 12 full years96 astro has been a member for 12 full years96 astro has been a member for 12 full years96 astro has been a member for 12 full years96 astro has been a member for 12 full years96 astro has been a member for 12 full years96 astro has been a member for 12 full years96 astro has been a member for 12 full years96 astro has been a member for 12 full years
Topics: 38
Images: 4
Extra Info: 4.3 lt v6 rwd
Postby redfury » January 30th 2011, 9:43pm
Most likely the rear heat issue is the valve next to the blower box behind the AC dryer. The valve may have failed. The default setting is off. I believe there are two vacuum fittings on it...switch them and see if you get heat.
redfury
Topics: 53
Images: 13
Postby Leeann_93 » January 31st 2011, 1:36am
UsedCarTech wrote:but my vacum setup is differnt from the diagam up here and the dealer.
That diagram is from my '93 FSM, so it probably doesn't apply to your '95.
Postby UsedCarTech » January 31st 2011, 2:17am
Thats just none up here apply to my 95 not even the dealer. :banghead:
UsedCarTech
Alias (AKA): Tony
Return to Climate Control
It is currently March 7th 2021, 3:24pm
Climate Control Forum
AOTD
in Climate Control
Date: Feb 27 '21
Time: 10:05pm
AOTD
in Climate Control
Date: Feb 27 '21
Time: 9:31pm
Attached by: Toskavat
ToskavatToskavat is online!
in Climate Control
Comments: 14
Date: Feb 26 '21
Time: 4:13pm
Sailing_Faith
in Climate Control
Date: Feb 18 '21
Time: 9:05pm
in Climate Control
Comments: 14
Date: Feb 17 '21
Time: 2:47pm
Users browsing this forum: Google Adsense [Bot] and 11 guests
