2004 Astro Operating Temp?
Postby Corsemoto [OP] » June 18th 2008, 5:03am
What should these vans run at? Mine is at 210 all the time and will creep up with Max A/C and/or Rear A/C on in traffic, etc.
I have not been able to source a lower temp thermostat for the 2004 model year as I could for my '97 Safari. Do these use the same thermostat? I replace the thermostat last summer with a standard temp from Napa and it still operates at the same. Going to be flushing the coolant soon and would like a lower temp thermostat for the hot weather here if possible. Need to check my fan clutch as well...
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Re: 2004 Astro Operating Temp?
Postby gtkane » June 19th 2008, 4:26am
210 on the dash is about right.
Just remember, it's an indicator on the dash, not a true guage. Whatever it reads is probably normal. Varying from that point indicates a problem.
And the a/c will make it run hotter, just because of the extra heat load. Just make sure the rad and condenser are clean!
User album #4...check it out!
gtkane
Years of Membership: gtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full years
Alias (AKA): Astruck
Extra Info: nasty 4.3
Postby cherokeexj » July 28th 2008, 11:06pm
Jet Performance offers a 180 degree thermostat.
http://www.jetchip.com/Shop/shopdisplay ... 10&catID=1
Rob B
Indiana
05 Ford E350 Chateau with the V10
2011 Subaru Imprezza (may sell to get back into the Safari/Astros)
cherokeexj
Years of Membership: cherokeexj has been a member for 12 full yearscherokeexj has been a member for 12 full yearscherokeexj has been a member for 12 full yearscherokeexj has been a member for 12 full yearscherokeexj has been a member for 12 full yearscherokeexj has been a member for 12 full yearscherokeexj has been a member for 12 full yearscherokeexj has been a member for 12 full yearscherokeexj has been a member for 12 full yearscherokeexj has been a member for 12 full yearscherokeexj has been a member for 12 full yearscherokeexj has been a member for 12 full years
Topics: 9
Postby duff » July 29th 2008, 2:23am
Yeh - My 2004 z motor has been running like that for a few years. Seems to have started when the water pump was replaced. Not sure if that was related. It would jump one tick above 200 (digital dash) and stay there for about 5 mintes then drop back down. I changed the thermostat and then installed a supercooler radiator. It made no difference. Still did the same thing. I thought it was the guage or sender.
I just did the inake manifold gaskets. When I had it off I noticed that the passenger side of the block had a sludge build up yet the driver's side was perfectly clean. I suspect that may indicate a hot cylinder.
Recently it's been staying at 210. So I just put a 180 in it. That made a definate difference. So now It jumps between one tick below 200 back to 200 now. I got 175K on it so who knows how much life is lef in her ?
duff
Years of Membership: duff has been a member for 12 full yearsduff has been a member for 12 full yearsduff has been a member for 12 full yearsduff has been a member for 12 full yearsduff has been a member for 12 full yearsduff has been a member for 12 full yearsduff has been a member for 12 full yearsduff has been a member for 12 full yearsduff has been a member for 12 full yearsduff has been a member for 12 full yearsduff has been a member for 12 full yearsduff has been a member for 12 full years
Topics: 10
Postby astroman97 » August 9th 2014, 3:26am
My 2003 seems to run at 100 Celsius all the time hot IMHO...my 97 and 98 run just above 40-60...I figured the rad was plugged or clutch fan were not working correctly so I swapped it them with the 98 and installed a new thermostat everything but water pump...still runs at 100 was thinking a lower temp thermostat as mentioned ..as I will be replacing the transmission soon (heat is not a transmissions friend) would love to see it run cooler any other suggestions? :confused:
astroman97
Years of Membership: astroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full years
Topics: 78
Images: 2
Extra Info: Also 97 both 2wd
Postby Leeann_93 » August 9th 2014, 3:27am
Yes, start a new thread in Engines.
This is a 6-yr-old post....
Postby Corsemoto [OP] » August 9th 2014, 3:51am
Wow, blast from the past!
Since then I've replaced fan clutch and with Jet Programmer plugged in, it shows temp is right around 200° or so even though the dash gauge reads higher so nothing to worry about.
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Return to Climate Control
It is currently January 19th 2021, 12:27pm
Climate Control Forum
Attached by: SportsBoy
SportsBoy
in Climate Control
Date: Jan 10 '21
Time: 5:10am
SportsBoy
in Climate Control
Date: Dec 31 '20
Time: 4:43am
SportsBoy
in Climate Control
Date: Dec 29 '20
Time: 5:46am
SportsBoy
in Climate Control
Date: Dec 27 '20
Time: 5:13am
Comments: 17
Date: Nov 19 '20
Time: 9:33pm
