Rear AC/ REAR heat switch swap
Postby Rookie162 [OP] » January 28th 2017, 6:47pm
Amazon has the rear ac switch at 39 bucks versus the rear heat switch at 58.
Can i buy 2 rear ac switches and label one "heat" on my own since both my switches have bulbs burnt out?
I would imagine these 2 switches are identical internally since they do the same function.
Rookie162
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: Rookie162 has been a member for 3 full yearsRookie162 has been a member for 3 full yearsRookie162 has been a member for 3 full years
Topics: 13
Alias (AKA): Mel
Van Model Year: 2002
Extra Info: 4.3L V6 AWD LS
Re: Rear AC/ REAR heat switch swap
Postby AstroWill » January 28th 2017, 6:49pm
If the only problem is that they don't light up, why not just replace the bulbs? $80+ for new switches, or $2 for bulbs...
Images: 443
Postby Rookie162 [OP] » January 28th 2017, 7:17pm
AstroWill wrote:If the only problem is that they don't light up, why not just replace the bulbs? $80+ for new switches, or $2 for bulbs...
I took them apart already.....theyre not as as as a job as the radio lites were. The bulb wires are long and weave in n out. Hard to explain
Rookie162
Fueling (5/8 tank)
Fueling (5/8 tank)
Topics: 13
Alias (AKA): Mel
Postby srdragonusa » January 28th 2017, 7:24pm
I have a few Rear switches, They cam out of a 2002/2003 Astro.
64497
Not sure if it lights up. I may be able to test it. I was just about to post up these spare parts.
[email protected] AKA SR Dragon
2003 AWD Astro
1995 Toyota Tacoma 4x4 *SOLD* :-(
2012 Nissan Xterra Pro4X (wife's)
1985 MCI 102 A3
srdragonusa
Years of Membership: srdragonusa has been a member for 4 full yearssrdragonusa has been a member for 4 full yearssrdragonusa has been a member for 4 full yearssrdragonusa has been a member for 4 full years
Images: 115
Alias (AKA): Paul
Postby Rookie162 [OP] » January 28th 2017, 7:57pm
srdragonusa wrote:I have a few Rear switches, They cam out of a 2002/2003 Astro.
64497
Test it and lemme know
Or u could do a bulb replacement tutorial. Haha
Rookie162
Fueling (5/8 tank)
Fueling (5/8 tank)
Topics: 13
Alias (AKA): Mel
Postby srdragonusa » January 29th 2017, 2:53am
hehe
OK, took the spare apart, not hard, just need to be careful. Seems all the plastic is very brittle in theses vans. I don't think it's worth swapping the bulbs easier to swap the switch.
Here's the switch separated in 2
64577
Close up of Bulb side the 2 blue things are the bulbs
64585
if you click on image and zoom in you can see the tiny wire leg of the bulb. Doesn't look like fun to me.
2003 AWD Astro
1985 MCI 102 A3
srdragonusa
Images: 115
Alias (AKA): Paul
Postby Rookie162 [OP] » January 29th 2017, 4:34am
Exactly! Lol
So back to my original question.....
Would 2 "REAR AC" switches work....and i label one for heat?
Rookie162
Fueling (5/8 tank)
Fueling (5/8 tank)
Topics: 13
Alias (AKA): Mel
Postby AstroWill » January 29th 2017, 4:46am
Images: 443
Postby 1lowcab » January 29th 2017, 4:47am
I replaced the bulb in my rear heat switch....it was not fun. Also, now it doesn't match the other lights as the factory bulbs have that blue coating on them.
Someday I'll just replace the switch.
1lowcab
Firing on 8 Cylinders (L3)
Topics: 58
Images: 165
Postby AstroWill » January 29th 2017, 5:22am
They do sell the colored 'gel' caps/covers that go over standard white bulbs, aka lighting filters. Of course, all of the used ones are 12+ years old now as well, and it is quite common for them to be burned out.
I wouldn't buy these online, but they should be available locally, I had bought some years ago. http://amzn.to/2pKCeMD
Something like this might work as well. http://amzn.to/2p5Gh7s
Images: 443
Postby One-Eye » March 11th 2017, 2:27am
I'm not sure why this is such a discussion. I replaced my bulbs in both switches quite easily with perfect results. There is a thread in the forums on how to do it, written quite well. The bulbs can be had on ebay cheap. I got a pack of 10 of them for something like $3.00. I did mine slightly different then the post, I didn't crush my bulbs in fear of damaging the covers. I instead clipped the leads as close to the bulbs as possible and carefully removed the covers so I could reuse them on the new bulbs. I also chose to use the incandescent 7219 bulbs instead of LEDs because I want the bulbs to dim with the rest of the dash and don't want to get into replacing all my dash lights with LEDs yet (Dimming issue and the time involved).
'85 Cargo - First Astro, Recycled.
'89 Customized Shorty - Up for Sale, 225k, still running.
'03 Regency Hightop, 4.3L, X VIN
Mods: AWD converted to RWD (More mods to follow).
One-Eye
Years of Membership: One-Eye has been a member for 4 full yearsOne-Eye has been a member for 4 full yearsOne-Eye has been a member for 4 full yearsOne-Eye has been a member for 4 full years
Alias (AKA): Bernie
Extra Info: Regency Hightop
Postby 1lowcab » March 11th 2017, 2:55am
I re-did all 3 switches with 3mm LEDs, along with all the other bulbs on the dash/doors.
The rear heat, rear ac and rear wiper are a little hard and it is easiest to crush the original bulbs so you have more wire to work with but worth it when it's done.
1lowcab
Topics: 58
Images: 165
Return to Climate Control
It is currently December 4th 2020, 2:48pm
Climate Control Forum
Date: Nov 19 '20
Time: 9:33pm
Date: Nov 18 '20
Time: 5:15pm
doogaloo
in Climate Control
Comments: 9
Date: Nov 09 '20
Time: 11:08pm
Date: Oct 31 '20
Time: 9:45pm
Devo
in Climate Control
Date: Oct 25 '20
Time: 10:53pm
