OK here is a challenge for all the A/C gurus here. The ac on the 95 has been screwed over since I got it. They did a junk yard motor replacement so that will give you an idea. I traced out the vacuum and got that working right. Had a few wiring issues, got those straightened out. Found the pipe not connected at the condensor, got that taken care of. The compressor wouldnt kick on, got that taken care of. Finally decided to give it a go. First put in a can of stop leak and a little oil. Followed with two cans of 134. The ac was blowing cold and the astro was a happy van again. In the morning the astro was sad --- the ac was blowing hot. Checked it with the single gauge and it was showing zero pounds but the clutch was kicking and the compressor was working. I double checked all the vacuum and checked that the heater wasnt on, you know all that sort. still blowing hot.
Decided to take a closer look so went to remove the lines on the back of the compressor to be sure the gaskets are good and it is all right back there. As I was loosing the clamp there was pressurized freon leaking out from a system that is supposed to have zero charge and blows hot.
So here is what I am going to do tomorrow. I am going to replace the orfice tube filter. Im thinking the thing is clogged and not letting the top half of the system to pressure up --- what do you think??? I am open to any suggestions. Thanks A j
