Rear heat wiring harness
Postby Rinny [OP] » May 19th 2017, 6:30pm
Does anyone know if this is the rear heater wiring harness end that plugs into the block by the fuse box that is next to the brake pedal? and exactly where does it plug in?
03Astro AWD/4WD
TorsenDiffs,3:73'S,VettServo
NP236TC
Dual Piston Rear Calipers
GY DTrac 235/85/R16
ARB &/Custom bumpers
2x6x1/4 Rockrails
Rinny
Years of Membership: Rinny has been a member for 5 full yearsRinny has been a member for 5 full yearsRinny has been a member for 5 full yearsRinny has been a member for 5 full yearsRinny has been a member for 5 full years
Images: 6
Extra Info: 5.7L NP236
  • Rear heat not working
    by K-TRON » September 18th 2020, 3:51am in Climate Control
    September 19th 2020, 5:25am
  • Removing conversion van rear heat/AC unit
    by AstroOafAdventurerAstroOafAdventurer is online! » November 18th 2020, 5:16pm in Climate Control
    Last post by icebrrg3rd View the latest post
    December 19th 2020, 2:21pm
    7
    63
    January 19th 2021, 1:35pm
Re: Rear heat wiring harness
Postby AstroWill » May 19th 2017, 6:56pm
You can probably match the colors to the connector end views in the techline eSI.
Images: 460
Postby Rinny [OP] » May 20th 2017, 3:09pm
OK so I now know I do not have the harness for the rear heat, after taking the dash out of course. Does anyone have a harness from a rear heat delete job? This is going to hold up the swap if I cant get one.
03Astro AWD/4WD
NP236TC
GY DTrac 235/85/R16
2x6x1/4 Rockrails
Rinny
Images: 6
Return to Climate Control
It is currently January 19th 2021, 1:35pm
Climate Control Forum
Attached by: SportsBoy
SportsBoy
in Climate Control
Date: Jan 10 '21
Time: 5:10am
SportsBoy
in Climate Control
Date: Dec 31 '20
Time: 4:43am
SportsBoy
in Climate Control
Date: Dec 29 '20
Time: 5:46am
SportsBoy
in Climate Control
Date: Dec 27 '20
Time: 5:13am
Comments: 17
Date: Nov 19 '20
Time: 9:33pm
