A/C high pressure valve won't stop leaking
Postby SLIMESTER [OP] » July 11th 2017, 11:43pm
My a/c high pressure port is leaking real bad and the only thing holding it is the dust cap. I poked a small screwdriver in it to try and re-seat the seal and lots of air and oil, or refrigerant comes out, but it won't completely seal. I hope I they sell high pressure schrader valves at my local auto parts store. If I replace that valve, would I have to evacuate the system after?
SLIMESTER
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: SLIMESTER has been a member for 6 full yearsSLIMESTER has been a member for 6 full yearsSLIMESTER has been a member for 6 full yearsSLIMESTER has been a member for 6 full yearsSLIMESTER has been a member for 6 full yearsSLIMESTER has been a member for 6 full years
Topics: 10
Van Model Year: 2001
  • Heater control valve leaks- always the valve?
    by highfigh » February 24th 2021, 5:13pm in Climate Control
    Last post by highfigh View the latest post
    March 11th 2021, 3:12pm
  • high pressure switch?
    by keith92ext » May 29th 2021, 9:41pm in Climate Control
    Last post by keith92ext View the latest post
    May 29th 2021, 10:45pm
    35
    June 25th 2021, 11:16am
Re: A/C high pressure valve won't stop leaking
Postby TurnNburn » July 11th 2017, 11:46pm
They do sell that valve, pretty common. And yes, evac and recharge.
TurnNburn
Green Status (L4)
Green Status (L4)
Years of Membership: TurnNburn has been a member for 5 full yearsTurnNburn has been a member for 5 full yearsTurnNburn has been a member for 5 full yearsTurnNburn has been a member for 5 full yearsTurnNburn has been a member for 5 full years
Alias (AKA): iGoogle
Postby WimpTech » July 12th 2017, 12:06am
Screw out the whole valve and replace it with a new port, this one should fit perfectly:
Link: http://a.co/1y3IkfQ
Regarding evac... as long as there is pressure in the system, then moisture could not get in so may not have to vacuum. I recharged mine w/o evac after the system was depressurized for years. Why? 'cause I'm an idiot... but it held up just fine. Receiver/ dryer soaked it all up no problem.
Point being if you have always had positive pressure, and are quick about changing out that valve on a non-rainy day, should be fine. Yes there is a risk, but a pretty small one. Safe bet is like TnB said.
You shouldn't have to put in more PAG oil since your system is pressurized still, so just straight R134 in the amount appropriate to your van, see yellow sticker on AC box under hood, passenger side.
If you have rear A/C then it's 4 lbs total - that's about 5x 12ox cans (16oz =1 pound, small cans are only 12oz). without I believe is around 3.6lbs
WimpTech
Firing on 4 Cylinders (L5)
Topics: 39
Images: 322
Alias (AKA): =Wimpy=
Extra Info: AWD 3+1 Lift
Postby SLIMESTER [OP] » July 12th 2017, 2:29am
Thanks guys! I may go to Harbor Freight and buy an a/c vacuum pump to go with my new set of manifold guages.
SLIMESTER
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 10
Postby WimpTech » July 12th 2017, 4:45am
Don't bother with the cheap $20 one
:2:
WimpTech
Topics: 39
Images: 322
Postby 97cargocrawler » July 12th 2017, 4:30pm
Have you checked to make sure the old valve is completely screwed in? Don't buy anything from HF period. Rent one from the LAP or get a cheapo on Amazingzon.
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Postby SLIMESTER [OP] » July 12th 2017, 8:20pm
Yeah, it is screwed on tight. I checked the websites on a bunch of auto parts stores near me about their loaner tools, but I don't see any that loan a vacuum pump. It would have been nice not having to buy one.
SLIMESTER
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 10
Postby WimpTech » July 12th 2017, 8:38pm
I'd skip it, but thats me.
WimpTech
Topics: 39
Images: 322
Postby 1lowcab » July 12th 2017, 8:55pm
Give your LAPS a call, they may have it but don't have it listed. Mine didn't have one listed but they do carry them for loaners.
1lowcab
Firing on 8 Cylinders (L3)
Years of Membership: 1lowcab has been a member for 5 full years1lowcab has been a member for 5 full years1lowcab has been a member for 5 full years1lowcab has been a member for 5 full years1lowcab has been a member for 5 full years
Topics: 58
Images: 165
Postby CopperFiremistCopperFiremist is online! » July 12th 2017, 8:59pm
AC Delco 15-5438
Pullin The Pass
Years of Membership: CopperFiremist has been a member for 6 full yearsCopperFiremist has been a member for 6 full yearsCopperFiremist has been a member for 6 full yearsCopperFiremist has been a member for 6 full yearsCopperFiremist has been a member for 6 full yearsCopperFiremist has been a member for 6 full years
Topics: 25
Images: 6
Alias (AKA): B
Extra Info: LS Swap
Postby AstroWill » July 12th 2017, 9:20pm
97cargocrawler wrote:Have you checked to make sure the old valve is completely screwed in? Don't buy anything from HF period. Rent one from the LAP or get a cheapo on Amazingzon.
x2, with an emphasis on borrowing one from your LAPS.
Topics: 109
Images: 481
Postby Old Barney » July 12th 2017, 9:49pm
Bought on e-bay a tool set that allows removing the core and NOT loose any gas From national car parts store I was quoted $79.00 for EACH tool one for high side and one for low side. I bought both for R134 and snap they onto the proper port for $19.00 for the PAIR. Made of BRASS good quality. No instructions were supplied but self explanatory if studied for a couple minutes and well worth the purchase. Can use it many times and lasts for years
Old Barney
Years of Membership: Old Barney has been a member for 6 full yearsOld Barney has been a member for 6 full yearsOld Barney has been a member for 6 full yearsOld Barney has been a member for 6 full yearsOld Barney has been a member for 6 full yearsOld Barney has been a member for 6 full years
Topics: 23
Images: 47
Alias (AKA): Barney
Extra Info: awd
Postby SLIMESTER [OP] » July 13th 2017, 12:30am
1lowcab wrote:Give your LAPS a call, they may have it but don't have it listed. Mine didn't have one listed but they do carry them for loaners.
Thanks for telling me to call. You were right, they don't show up on their website for the loaner tool program, but they do have them for $155 deposit. I'm going there now. Thanks again!
SLIMESTER
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 10
Postby 1lowcab » July 13th 2017, 12:40am
Question on the AC Delco 15-5438, will that fit both the high and low valves?
1lowcab
Topics: 58
Images: 165
Postby WimpTech » July 13th 2017, 12:46am
i dont think low side valve comes off like that. On mine i just replaced the schrader valve core
WimpTech
Topics: 39
Images: 322
Postby TurnNburn » July 13th 2017, 12:55am
the high side and low side are different sizes, so no, that wont work for both, but there might be one for the other side as well.
TurnNburn
Green Status (L4)
Green Status (L4)
Postby 1lowcab » July 13th 2017, 1:59am
Oh, I see it now, thats the whole valve. Anyone have a link to the valve cores for both sides?
Sorry for the thread jack!
1lowcab
Topics: 58
Images: 165
Postby chevymaher » July 13th 2017, 12:51pm
1lowcab wrote:Oh, I see it now, thats the whole valve. Anyone have a link to the valve cores for both sides?
High pressure side is the same as a valve stem for a tire.
Topics: 91
Postby SLIMESTER [OP] » July 13th 2017, 3:57pm
Okay, I replaced the high pressure schrader valve and put a vacuum on it for 10 or 15 minutes and it won't hold after few minutes. So I must have another leak. Can I just add refrigerant and dye without the pag oil so I can find the leak? Will I harm the compressor by doing that? Also, I forgot to oil the O ring on the new high pressure schrader valve port, is that absolutely necessary?
SLIMESTER
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 10
Postby chevymaher » July 13th 2017, 6:04pm
No it wont hurt it using just the dye. No the o ring will be fine. It is probably the seal under the clutch on the compressor that leaks and the dye will not help you find that.
Topics: 91
Return to Climate Control
It is currently June 25th 2021, 11:16am
Climate Control Forum
stal023
in Climate Control
Comments: 13
Date: Jun 22 '21
Time: 5:11pm
Sailing_Faith
in Climate Control
Date: Jun 21 '21
Time: 1:07am
Date: Jun 12 '21
Time: 1:56am
stal023
in Climate Control
Comments: 13
Date: May 30 '21
Time: 9:57pm
Date: May 27 '21
Time: 5:48pm
