Name that hose
Name that hose
Postby JonnyDelux [OP] » August 1st 2017, 1:22am
Hey, found a pretty serious air leak. This hose, and one attached to it needs to be replaced. Anyone know what it's called?
JonnyDelux
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: JonnyDelux has been a member for 4 full yearsJonnyDelux has been a member for 4 full yearsJonnyDelux has been a member for 4 full yearsJonnyDelux has been a member for 4 full years
Topics: 27
Alias (AKA): Fidel Astro
Van Model Year: 2002
Extra Info: LT 4.3 V6 AWD
  • Help Identifying Hose
    by smercado212 » August 20th 2020, 10:05pm in Climate Control
    August 20th 2020, 10:50pm
    23
    December 2nd 2020, 2:13pm
Re: Name that hose
Postby CopperFiremistCopperFiremist is online! » August 1st 2017, 1:27am
Bulk vacuum line from your LAPS
Pullin The Pass
Firing on 1 Cylinder (L2)
Topics: 24
Images: 6
Alias (AKA): B
Extra Info: LS Swap
Re: Name that hose
Postby TurnNburn » August 1st 2017, 1:30am
What is a Hooty Snooter valve, Alex?
On a serious note, that's your HVAC control line. I believe it leaves that T and goes down to that plastic ball.
Whats going on with it?
Like CPF said, literally anywhere will have that hose. Its nothing special.
TurnNburn
Green Status (L4)
Green Status (L4)
Alias (AKA): iGoogle
Re: Name that hose
Postby MI_Ghost » August 1st 2017, 3:24am
I bet you are having problems getting the dash vents off the defroster, That is why!
3/16 vacuum hose from the T to the firewall and T down to the ball,
~Ghost
Ast' Cargo: 2001 Astro Cargo
Beauty: 2009 Impala LT
MI_Ghost
Images: 107
Alias (AKA): Ghost
Van Model Year: 2001
Extra Info: Big White RWD Box
Re: Name that hose
Postby JonnyDelux [OP] » August 1st 2017, 3:33am
Yes my front vents only defrost, that and also not very cold A/C. I just pulled it off, is it supposed to be fitted onto this screw with no hole? That can't be right
JonnyDelux
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 27
Re: Name that hose
Postby MI_Ghost » August 1st 2017, 3:53am
Look for a rubber fitting through the firewall. It runs through that fitting to the back of the heater control panel.
The hose on the screw goes to the ball directly below the AC dryer. Roughly straight down from the T fitting,
~Ghost
MI_Ghost
Images: 107
Alias (AKA): Ghost
Re: Name that hose
Postby JonnyDelux [OP] » August 1st 2017, 4:26am
Alright, thanks a lot. My vents are strong now, just not quite as cold. So that hose really goes to a non hollow screw? What is the point of that?
JonnyDelux
Fueling (7/8 tank)
Fueling (7/8 tank)
Topics: 27
Re: Name that hose
Postby sixsix » August 1st 2017, 12:24pm
JonnyDelux wrote: ... So that hose really goes to a non hollow screw? ...
No, don't think so.
Mike
Well, after all... what would Banacek say ?... “May be hard to believe... President Trump should rest easy and concede what was in fact a foregone conclusion: Another OLD MAN won with only about 50% of the Change Believers/Fools showing up."
Firing on 4 Cylinders (L5)
Topics: 38
Images: 1303
Re: Name that hose
Postby Toskavat » August 1st 2017, 1:55pm
If it isn't the one going to the ball (vacuum canister), it could be the supply. See diagram, it's the red line. All hoses should have no leaks for everything to work.
Toskavat
Years of Membership: Toskavat has been a member for 5 full yearsToskavat has been a member for 5 full yearsToskavat has been a member for 5 full yearsToskavat has been a member for 5 full yearsToskavat has been a member for 5 full years
Images: 24
Alias (AKA): ASTRORC
Extra Info: 4.3 V6 2WD
Re: Name that hose
Postby Leeann_93 » August 1st 2017, 10:58pm
JonnyDelux wrote:Alright, thanks a lot. My vents are strong now, just not quite as cold. So that hose really goes to a non hollow screw? What is the point of that?
No, it's not supposed to be there. Some dumbass put it there because, well, they're a dumbass.
He told you where it's supposed to be; he meant the end that's on the screw.
Re: Name that hose
Postby MI_Ghost » August 2nd 2017, 2:30am
The vacuum ball is a storage reservoir. It stores a small amount of vacuum to cover low vacuum conditions. Sudden acceleration by pressing the pedal to the floor causes this momentary loss of vacuum. The way your hose is run now terminated on the screw it has no reserve and the dash vents will cut out on hard acceleration.
If you look below the AC dryer you will see the round ball shaped reservoir. The hose attaches to the nipple on the reservoir. There is little working room and getting the hose on the nipple can be a pain. Probably why it was just plugged it onto a screw to stop the vacuum leak.
~Ghost
MI_Ghost
Images: 107
Alias (AKA): Ghost
Return to Climate Control
It is currently December 2nd 2020, 2:13pm
Climate Control Forum
Date: Nov 19 '20
Time: 9:33pm
Date: Nov 18 '20
Time: 5:15pm
doogaloo
in Climate Control
Comments: 9
Date: Nov 09 '20
Time: 11:08pm
Date: Oct 31 '20
Time: 9:45pm
Devo
in Climate Control
Date: Oct 25 '20
Time: 10:53pm
