Rumble/Vibration when compressor kicks in?
Postby DOcean [OP] » July 17th 2011, 5:29pm
What would cause a (more than normal) vibration when the A/C compressor kicks on? The vibration isn't serious/violent, but it is annoying. I know some vehicles always vibrate annoyingly when the A/C turns on, but I'm experiencing an abnormal vibration that has slowly gotten worse since I've owned the van. A/C works fine.
I'm wondering if the serp belt tensioner might have something to do with this... :shrug:
DOcean
Years of Membership: DOcean has been a member for 12 full yearsDOcean has been a member for 12 full yearsDOcean has been a member for 12 full yearsDOcean has been a member for 12 full yearsDOcean has been a member for 12 full yearsDOcean has been a member for 12 full yearsDOcean has been a member for 12 full yearsDOcean has been a member for 12 full yearsDOcean has been a member for 12 full yearsDOcean has been a member for 12 full yearsDOcean has been a member for 12 full yearsDOcean has been a member for 12 full years
Topics: 26
Re: Rumble/Vibration when compressor kicks in?
Postby redfury » July 17th 2011, 5:54pm
DOcean wrote:What would cause a (more than normal) vibration when the A/C compressor kicks on? The vibration isn't serious/violent, but it is annoying. I know some vehicles always vibrate annoyingly when the A/C turns on, but I'm experiencing an abnormal vibration that has slowly gotten worse since I've owned the van. A/C works fine.
Well, you could watch the engine while someone kicks the A/C on and see if you are getting it out of the belt.
Beyond that, I'd want to put a set of gauges on it and see what they say..look for a vibrating needle that might indicate worn reed valves, etc.
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Extra Info: LT 5.7L 4wd
Postby DOcean [OP] » July 17th 2011, 6:15pm
redfury wrote:Well, you could watch the engine while someone kicks the A/C on and see if you are getting it out of the belt.
"Getting it out of the belt"? What does that mean? A stretched/worn belt could cause this?
DOcean
Topics: 26
Postby redfury » July 17th 2011, 6:34pm
seeing if the vibration is caused when the compressor kicks in and sends a shudder through the belt. You'd see the tensioner try to adjust for the movement. You could simply have a tensioner that is bad and isn't working properly. I've had that before. Belt was tight, but the tensioner was solid and I had to replace it when I replaced the belt when the A/C locked up on me ( probably due to belt tension )
Easy enough to do, get a 3/8's ratchet or breaker bar and see if you can move the tensioner.
redfury
Topics: 53
Images: 13
Postby DOcean [OP] » July 24th 2011, 9:43pm
Tested today. Tensioner appears to be good. Full range of motion with a moderate amount of "spring".
Belt is worn, but not stretched.
One thing I noticed was the tensioner was moving as the vehicle idles. Is it supposed to "bounce"?
DOcean
Topics: 26
Postby chevymaher » July 24th 2011, 10:37pm
DOcean wrote:Tested today. Tensioner appears to be good. Full range of motion with a moderate amount of "spring".
No there not supposed to bounce. Usually that a pulley or belt issue.
Topics: 91
Postby DOcean [OP] » July 26th 2011, 10:26pm
What would be the cause of tensioner "bounce", and would the tensioner bounce also be the cause of my vibration?
DOcean
Topics: 26
Postby chevymaher » July 26th 2011, 11:10pm
DOcean wrote:What would be the cause of tensioner "bounce", and would the tensioner bounce also be the cause of my vibration?
A pulley that is siezing.Grabbing(bearing locking for a second)spin all pulleys and tensioner pulleys make sure they spin freely without singing or popping.Belts sometimes just get hard in places when they get old.Resist bending to different degrees in different places.A pulley grabbing jerking as it spins would cause a vibration.
Topics: 91
Return to Climate Control
It is currently April 23rd 2021, 5:36pm
Climate Control Forum
Comments: 18
Time: 6:25am
AOTD
in Climate Control
Date: Feb 27 '21
Time: 10:05pm
AOTD
in Climate Control
Date: Feb 27 '21
Time: 9:31pm
Attached by: Toskavat
Toskavat
in Climate Control
Comments: 17
Date: Feb 26 '21
Time: 4:13pm
Sailing_Faith
in Climate Control
Date: Feb 18 '21
Time: 9:05pm
