2000 Astro only has high speed on heat fan
Postby Vaughn [OP] » November 15th 2017, 5:34am
My Astro fan motor just quit working on anything but high. Is it usually in the motor or is it the switch in the dash.
I am going to have access to switch when I put in a new radio, I could easily put in a new switch while I have access.
Don't want to wait till the motor totally quits. It's getting cold here in Pa
Vaughn
Years of Membership: Vaughn has been a member for 5 full yearsVaughn has been a member for 5 full yearsVaughn has been a member for 5 full yearsVaughn has been a member for 5 full yearsVaughn has been a member for 5 full years
Topics: 12
Extra Info: LS 4.3 AWD
Re: 2000 Astro only has high speed on heat fan
Postby Birdshake » November 15th 2017, 5:51am
https://www.astrosafari.com/viewtopic.php?f=34&t=14502
Either the blower motor resistor or the main vacuum line.
2005 4WD Astro Cargo
NP236 3.73 Eaton Posi
S10 HD Springs 3" blocks
245/75/16 BFG KO2
KYB Monomax
Birdshake
Years of Membership: Birdshake has been a member for 9 full yearsBirdshake has been a member for 9 full yearsBirdshake has been a member for 9 full yearsBirdshake has been a member for 9 full yearsBirdshake has been a member for 9 full yearsBirdshake has been a member for 9 full yearsBirdshake has been a member for 9 full yearsBirdshake has been a member for 9 full yearsBirdshake has been a member for 9 full years
Topics: 10
Images: 28
Extra Info: 4.3 AWD
Postby AstroWill » November 15th 2017, 3:11pm
Vaughn wrote:My Astro fan motor just quit working on anything but high. Is it usually in the motor or is it the switch in the dash.
Usually the resistor/controller at the blower motor.
Vacuum line is when it jumps to or stays on defrost.
Topics: 109
Images: 473
Postby Spdcrazy » November 15th 2017, 8:02pm
Yep. Blower motor resistor is my bet. Very common. When they go out the resistor fails and you only have on and off nothing in between.
Spdcrazy
Years of Membership: Spdcrazy has been a member for 3 full yearsSpdcrazy has been a member for 3 full yearsSpdcrazy has been a member for 3 full years
Alias (AKA): Rob
Extra Info: 4.3L AWD
Postby Vaughn [OP] » November 17th 2017, 12:05am
Thanks, I will check it out
Vaughn
Topics: 12
Postby carnage » November 17th 2017, 2:23am
the same thing happened to my last van
and it was the resister burned out
carnage
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: carnage has been a member for 4 full yearscarnage has been a member for 4 full yearscarnage has been a member for 4 full yearscarnage has been a member for 4 full years
Topics: 5
Images: 7
Alias (AKA): ROY
Extra Info: cargo van
Return to Climate Control
It is currently May 6th 2021, 4:51pm
Climate Control Forum
Comments: 20
Date: Apr 22 '21
Time: 6:25am
AOTD
in Climate Control
Date: Feb 27 '21
Time: 10:05pm
AOTD
in Climate Control
Date: Feb 27 '21
Time: 9:31pm
Attached by: Toskavat
Toskavat
in Climate Control
Comments: 17
Date: Feb 26 '21
Time: 4:13pm
Sailing_Faith
in Climate Control
Date: Feb 18 '21
Time: 9:05pm
