2000 Astro no heat, blend door?
Postby thelackof [OP] » December 12th 2017, 4:11am
Drove my van from CO to VA and 6 hours before arrival, my heat starts blowing cold air.
Took my van in for an oil leak fix and mentioned the heat and when I got the van back, my heat was already on and blowing hot air.
Simply turned it off.
Several days later, I drove the van back from VA to CO.
I realized that only option 4 is working and only out of the top dash, even when set on feet or front or etc.
When I turn the heat off, the van was blowing very hot air during my entire trip.
Left it in the off position and just kept cracking my window for the trip.
AC also was not working.
After I arrived back in CO, the next day, my van no longer blows any hot air at all.
but now, the 1-4 options work again and the position knob (feet, front, etc) also work.
but just blowing cold air, even in the off position.
and the cold/hot knob does nothing.
Van has rear and front heat and both blow cold.
Took it into a local shop and they told me the labor could be several hundred $$ alone and that I should research online and do it my self
and they suggested a "blend door"?
When the hood was opened, they pointed out two tubes coming from my coolant tank that were hot.
They pointed out another object on the far right that was also hot.
and then, in the center left, there was a thin tube line that when moved, you could hear air coming out of it.
Guy said that could have something to do with it.
Please, any online videos that would help me to fix this my self?
and what exactly do you think is the problem with my heat and AC?
How should I go about fixing this?
and what is that line that is leaking air?
Thank you!
thelackof
Years of Membership: thelackof has been a member for 3 full yearsthelackof has been a member for 3 full yearsthelackof has been a member for 3 full years
Topics: 17
Extra Info: LS 2WD
Re: 2000 Astro no heat, blend door?
Postby AstroWill » December 12th 2017, 4:53am
While the front does have a blend door, the rear does not. Start with your vacuum lines, get >$10 worth of vacuum lines and start replacing, one at a time. https://sites.google.com/site/astrosafa ... ac-airflow
Images: 443
Postby smokinjoe » December 12th 2017, 5:26am
It could be the heater valve. Its vacuum driven and bad vac lines would cause a no heat condition.
For sure get a diagram and replace vac lines. I had to replace a lot of them on my 02. They were turning to powder.
On my 95 I just bypassed the heat valve Cut the hoses and threw it away. Spliced the hosed back together and had awesome heat.
You need to find your heater valve and look at the lines going to it and other vac lines.
smokinjoe
Firing on 5 Cylinders (L2)
Topics: 268
Alias (AKA): smokinjoe
Van Model Year: 2002
Extra Info: RWD
Postby Old Barney » December 12th 2017, 12:23pm
Any way to cheapen up the works. For many years cable control was used successfully Then cheap and fast during the building of an auto get it out the door CHEAPLY. Yeh it lasted 17 years But the control's in my son's 1950 chevy deluxe still works just fine!! The 1956 Olds I owned with AC worked fine both heat and air?? So not only is vacuum easy to install down the line and cheap it doesn't last for ever as we would like. Plastic parts are formed by heat and destroyed by heat.
Old Barney
Years of Membership: Old Barney has been a member for 6 full yearsOld Barney has been a member for 6 full yearsOld Barney has been a member for 6 full yearsOld Barney has been a member for 6 full yearsOld Barney has been a member for 6 full yearsOld Barney has been a member for 6 full years
Topics: 23
Images: 47
Alias (AKA): Barney
Extra Info: awd
Return to Climate Control
It is currently November 28th 2020, 11:14am
Climate Control Forum
Date: Nov 19 '20
Time: 9:33pm
Date: Nov 18 '20
Time: 5:15pm
doogaloo
in Climate Control
Comments: 9
Date: Nov 09 '20
Time: 11:08pm
Date: Oct 31 '20
Time: 9:45pm
Devo
in Climate Control
Date: Oct 25 '20
Time: 10:53pm
