Front and rear blower motor issues! HELP!
Postby KC10Chief [OP] » November 20th 2011, 8:04am
On my 1997 Safari van, it doesn't seem like the front blower motor blows very hard. I can tell that the speed changes with each click of the knob. It just doesn't blow hard in high. Is it worn out?
The rear fan is kind of rattling. It's noisy. Is this common? Where is it even at? I tried a search, but didn't come up with much. It's pretty dang cold here in Alaska right now. It takes a while for the van to warm up.
Matt
1997 Safari SLE AWD
74,000 miles
KC10Chief
Years of Membership: KC10Chief has been a member for 9 full yearsKC10Chief has been a member for 9 full yearsKC10Chief has been a member for 9 full yearsKC10Chief has been a member for 9 full yearsKC10Chief has been a member for 9 full yearsKC10Chief has been a member for 9 full yearsKC10Chief has been a member for 9 full yearsKC10Chief has been a member for 9 full yearsKC10Chief has been a member for 9 full years
Topics: 24
Re: Front and rear blower motor issues! HELP!
Postby chevymaher » November 20th 2011, 2:25pm
The rear one rattling some thing wrong.maybe a bearing.I dont have one.But I believe it on the drivers side under the interior panel under the rear window behind the wheel well.
The front blower motor it is subjective how much they blow.Mine works perfectly and it not doing a whole lot.Lumpy has the same complaint with his air conditioning.
Only thing I see that can help is removing the water control valve.It is restrictive when it is working correctly.I remove them for people locally here.It will not increase the air flow but it does increase the temp of the air coming out.In short the heater puts out more BTUs of heat energy.
Postby Phantom » November 20th 2011, 2:35pm
KC10Chief wrote:On my 1997 Safari van, it doesn't seem like the front blower motor blows very hard. I can tell that the speed changes with each click of the knob. It just doesn't blow hard in high. Is it worn out?
You may have a vacuum line problem or solenoid not operating properly to change to air flow direction , or maybe blower is dying , or blade slipping and not spinning as fast as it should
Try here for the heater location , I think it is the same for Gen2 behind the driver seat
Early Gen 1 RearHeatAssembly-EXPLODED.jpg (45.9 KiB) Viewed 1269 times
Phantom
Firing on 7 Cylinders (L4)
Postby RECox286 » November 20th 2011, 3:59pm
Front blower issue:
Does your truck have a cabin air filter in the ductwork ? That could be the air flow problem. Is the air diverter actually working ?
Is the fan motor running at all speeds ? Does the hose to the heater feel uncomfortably warm to the touch. May need a new T-stat./ pressure cap ?
Try a blank off plate in front of the radiator when it is really cold out. Hey, it's Alaska ! When would it not be cold out ???
Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby Phantom » November 20th 2011, 4:26pm
I once tried to confirm if astro had a cabin filter , and 2 dealerships said there was no cabin filter on astro ,
Have heard several times the water control valve chev mentioned , has solved the problem for several people ,
Phantom
Postby Leeann_93 » November 20th 2011, 5:12pm
The blower is right behind the driver's seat. The panel just pulls out at the back - it's those stupid metal clips on plastic posts, so be careful. One screw at the front as it wraps around the pillar behind the driver's door - you have to unscrew that and thread the seat belt through the slit, then it pulls right off.
It's a sealed unit, so you probably have a bearing issue.
You should be able to reach that one screw without removing the heater core, but I included the pic just to show it to you a bit better.
Postby KC10Chief [OP] » November 20th 2011, 9:43pm
Thanks! You guys are awesome. The fan sounds like it is right behind the drivers seat somewhere. They look pretty cheap at the auto parts stores. About $25. I'll just throw a new one in there. Also, I hate those metal clips on plastic posts! Who thought that was a good idea? :?
Matt
1997 Safari SLE AWD
74,000 miles
KC10Chief
Topics: 24
Postby Phantom » November 20th 2011, 10:28pm
KC10Chief wrote: Also, I hate those metal clips on plastic posts! Who thought that was a good idea? :?
Some bean counter at a desk looking to get a raise in salary ... :lol:
Phantom
Postby Leeann_93 » November 20th 2011, 10:35pm
It's faster for assembly and easier in manufacturing. Isn't that great?
Postby 104mariner » November 28th 2011, 5:57pm
Just replaced heat/ac blower in my 2002 Astro. Sometimes it was noisy - other times wouldn't turn on. Was "easy" 1.5 hr. project. Accessable from under the hood. Bought new motor ($29 at Auto Zone- other discount parts outfit wanted $79 !) Auto Zone will also give you two page instruction which was mainly correct. You must first remove washer and radiator over flow canistors (mine was single unit) Lift up on plastic studs to release, discontect washer hose, pump connector, and radiator overflow hose. Remove support bracket for two heater hoses to get extra room to work old motor out - you do not have to disconnect them. Once cannisters are removed you will cut plastic shroud on marked lines to gain access to motor. There is actually a molded note on plastic that says " cut on lines to access motor." Use a stiff razor knife. There is also a small screw on middle left side that will hold plastic. That hex screw is 7/32" as will be screws that hold motor (4) ea. Remove blower electrical plug. You will notice a small rubber hose that apparently cools blower. It is hooked to blower and lower housing. My replacement blower (VDO brand) did not have male tube fitting but just a hole that hose went into. Don't force hose too far inside as it might interfere with motor. After replacing motor I replaced cut out plastic, secured small screw and ran a bead of silicone adhesive around cut. Replaced everything else and I now enjoy a powerful blower.I have not replaced rear blower but I think it is easier than front.
-104mariner
104mariner
Years of Membership: 104mariner has been a member for 9 full years104mariner has been a member for 9 full years104mariner has been a member for 9 full years104mariner has been a member for 9 full years104mariner has been a member for 9 full years104mariner has been a member for 9 full years104mariner has been a member for 9 full years104mariner has been a member for 9 full years104mariner has been a member for 9 full years
Alias (AKA): GJH
Extra Info: 4.3 V6 Vortex
Return to Climate Control
It is currently February 25th 2021, 8:42pm
Climate Control Forum
Sailing_Faith
in Climate Control
Date: Feb 18 '21
Time: 9:05pm
in Climate Control
Comments: 14
Date: Feb 17 '21
Time: 2:47pm
Attached by: SportsBoy
SportsBoy
in Climate Control
Date: Jan 10 '21
Time: 5:10am
SportsBoy
in Climate Control
Date: Dec 31 '20
Time: 4:43am
SportsBoy
in Climate Control
Date: Dec 29 '20
Time: 5:46am
Users browsing this forum: Baidu [Spider] and 3 guests
