hi there.
thanks for the help with my emission issues. two new denso 02 sensors and $200 later, i passed smog.
my newest issue:
my 2000 safari awd van (230,000 miles) has never had decent heating and i have decided to deal with it.
symptoms:
--the blower works (i can hear it) but little air comes out of vents (besides on defrost mode)
--the top hose is warm but not hot
--i have enough coolant and the temp gauge registers the engine getting hot but never getting anywhere near red (it gets up to 215 degrees at top). i assume my thermostat works.
***** so, would you recommend a full flush first to see if there might be an obstruction in heater core etc?
***** does the fluid always run thru the heater core or is there a sensor for the core that opens when the temp get to a certain level?
***** what steps would any of you do in terms of diagnosis? I'm a rank amateur at figuring things out but willing and able to do the hellish grunt work of replacing when i know what the problem is?
***** and one more dumb one: does the fluid run through the water pump?
thank you
dan
