What do these lines go to?
Postby HootenWeb [OP] » January 7th 2019, 3:12am
Today while changing my shocks I found two lines that aren't connected. These are on the passenger side right by the top shock mount. Does anyone know what these are for? They are severely corroded and not connected to anything on the motor front end. I did not follow them to back.
Thanks,
Webster
HootenWeb
Years of Membership: HootenWeb has been a member for 2 full yearsHootenWeb has been a member for 2 full years
Alias (AKA): Webster Hootenheimer
Van Model Year: 2002
Extra Info: 4.3L AWD HighTop
  • Rear AC removal Block lines
    by gmcjunk » February 5th 2021, 5:41pm in Climate Control
    Last post by gmcjunk View the latest post
    7
    97
    April 18th 2021, 3:57pm
Re: What do these lines go to?
Postby Leeann_93Leeann_93 is online! » January 7th 2019, 4:02am
They’re pretty bad, but they could be rear heat lines.
If they’re not connected, don’t worry about them.
Postby HootenWeb [OP] » July 20th 2019, 5:23pm
Ok I didn't worry about the lines as suggested, but now it's 95 out and I have no AC. If I put some refrigerant in and these rear lines are not connected will I just loose all my refrigerant?
Is the front and rear AC separate?
Thanks,
Hootenweb
HootenWeb
Postby Leeann_93Leeann_93 is online! » July 21st 2019, 12:00am
No. Not really. The rear AC has a separate evaporator and blower motor (and blower motor resistor), but the single compressor up front does both.
The silvery line with the big connector, further away from the shock is for the rear AC. The other set, the really really rusty set, is for rear heat.
If neither set is connected to anything and it doesn't look like there's a matching set of hoses (for rear heat) or lines (for rear AC) that also isn't connected to anything, then they've been disconnected from the front systems and the front systems should be sealed.
Postby Astro Pop » July 21st 2019, 12:38am
Easy and inexpensive way to locate leaks in AC is to hook up air line from shop compressor to AC system and run it up to about 50 psi then listen for leaks. In your case check those mystery lines. But once everything is done and fixed you have to evacuate the s**t out of the system. Like about 4 hrs at max vacuum.
Astro Pop
Years of Membership: Astro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full years
Topics: 41
Images: 9
Alias (AKA): Xfirepop
Van Model Year: 1996
Extra Info: AWD - 5 inch lift
Return to Climate Control
It is currently April 18th 2021, 3:57pm
Climate Control Forum
AOTD
in Climate Control
Date: Feb 27 '21
Time: 10:05pm
AOTD
in Climate Control
Date: Feb 27 '21
Time: 9:31pm
Attached by: Toskavat
ToskavatToskavat is online!
in Climate Control
Comments: 17
Date: Feb 26 '21
Time: 4:13pm
Sailing_Faith
in Climate Control
Date: Feb 18 '21
Time: 9:05pm
sixsixsixsix is online!
in Climate Control
Date: Feb 17 '21
Time: 2:47pm
