AC Not Working - Im stumped
Postby Primusblack [OP] » July 13th 2019, 4:13am
AC Not Working - Im stumped and Im sure everyone is dealing with the major heat/ humidity wave going on right now.
Long story short....as possible,
2000 Astro Van with Front & Rear AC
Attempt by Mechanic 1
Mechanic replaced a few O ring leaks, fixed.
Then recharged AC; worked for 2 days front and rear.
Attempt by Mechanic 2
Everything work but appears the compressor went bad. I replaced compressor and seals. Re-charged AC and worked for 2 days front and rear.
Attempt by Mechanic 3
Mechanic did a dye tech and said the condenser was faulty and was leaking
I replaced condenser.
Re-charged AC and worked for 5 days front and rear.
Attempt by Mechanic 4
Mechanic stated vacuum test failed and refused to assist any further and said he couldn’t diagnose any further.
Attempt by Me 5
I got a dye kit and light and filled
Couldn’t find any visible leaks, checked the entire vehicle including all line behind dog house. Also try soap and water method, nothing.
Attempt by Me 6
Bought a AC gauge set and vacuum test passed and held for 24+hrs.
Filled with refridgerant and found out the High Side valve was faulty. Replaced and vacuum tested again, filled refrigerant and still not working.
Read some other forums and thought it might be the expansion valve and I don't know where it is on the front AC
IM STUMPED and not sure where to go from here, any assistance or guidance would be appreciated. :banghead:
Primusblack
Years of Membership: Primusblack has been a member for 2 full yearsPrimusblack has been a member for 2 full years
  • No heat has got me stumped
    by teafreak35 » October 24th 2020, 6:24pm in Climate Control
    October 24th 2020, 10:57pm
  • Rear heat not working
    by K-TRON » September 18th 2020, 3:51am in Climate Control
    September 19th 2020, 5:25am
    73
    March 1st 2021, 2:31am
Re: AC Not Working - Im stumped
Postby Mmusicman » July 13th 2019, 11:36am
You have or had more than one leak.. hence the first few failed repairs.
Maybe your new compressor leaks? (I've had them leak brand new)
If vacuum holds, maybe the compressor leaks only when it's running?
You said mech #4 said vacuum test failed, but your test passed?
This is a contradiction.
Maybe leaking depending on position of compressor shaft?
Vacuum tests may not be 100% either.
I suppose it's possible a seal could leak under pressure, but may not leak under vacuum?
The forces of vacuum and pressure may push/pull on seals in opposite directions with different results?
Leaks are not always in places you can see or get to (evaporator coils for example)
I'm sure you didn't use soap and water on your evaporator coil, or even see it.
A sniffer can help with this one.. let sit a while then hit fan (with sniffer in front of vent)
Primusblack wrote:..filled refrigerant and still not working.
What is "not working"? Fan? Compressor?
Compressor not coming on?
Compressor coming on but not blowing cold?
What are your meter readings?
Your original complaint was that the system worked, but leaked out after a few days.
For some reason you got a new compressor. A different problem?
Did you ever "flush" the system?
Contaminates and debris from 1st failed compressor could kill a new one.
Contaminates and debris could clog orifice tube, but this would show up in the meter readings.
As many times you had the system empty or apart, you don't know where the expansion valve is and never changed it?
Topics: 73
Images: 49
Postby fabinator » July 16th 2019, 9:31pm
front ac does not use an expansion valve, I think the rear might.
one thing that could be happening, which fits your story perfectly is:
original compressor wore itself out and leaked a bit.
oil was contaminated with compressor debris, and clogged the orifice tube.
not enough oil remains in the system after all the component replacements, and wore out the new compressor.
crappy belt driven fan is lacking on the best of days, replace it with an electric one (Lincoln mark 8 is a near perfect fit)
flush system thoroughly, and add 10 ounces of ester oil (confirm actual capacity), replace compressor, orifice tube, and pull hard vacuum for an hour, and refill with propane to test function.
fabinator
Years of Membership: fabinator has been a member for 1 full year
Topics: 9
Extra Info: LT EXT AWD
Postby Leeann_93 » July 16th 2019, 10:44pm
fabinator wrote:front ac does not use an expansion valve, I think the rear might.
Correct - front doesn't, rear does.
Postby chevymaher » July 20th 2019, 12:42pm
Going by the chain of events here. It was working untill the pressure switches were fooled with. Check switches and their connections and make sure the system has proper charge.
Postby Leeann_93 » July 20th 2019, 3:29pm
Yeah, I'm with Randy. The pressure cycling switch (the one on the accumulator) on my '93 Bravada went bad on a day much like the ones in the past week; my husband jumped it with a paper clip to make it run until I could get a new switch.
First, he put gauges on the system and said it was full, then checked the wiring with his meter and said the system was calling for cooling, then jumped that switch and it ran. Bingo. Replaced that switch (you actually won't lose refrigerant when you remove that switch; there's a seal) and it worked perfectly until the ground went bad on another day like these. Made a new ground connection and it worked perfectly again.
Return to Climate Control
It is currently March 1st 2021, 2:31am
Climate Control Forum
AOTD
in Climate Control
Date: Feb 27 '21
Time: 10:05pm
AOTD
in Climate Control
Date: Feb 27 '21
Time: 9:31pm
Attached by: Toskavat
Toskavat
in Climate Control
Comments: 14
Date: Feb 26 '21
Time: 4:13pm
Sailing_Faith
in Climate Control
Date: Feb 18 '21
Time: 9:05pm
sixsixsixsix is online!
in Climate Control
Comments: 14
Date: Feb 17 '21
Time: 2:47pm
