A/C gauge set has Schrader valves inside hoses
Postby N6KB [OP] » September 23rd 2019, 5:51am
I just received a pressure gauge manifold hose set to use on my 2005 Astro A/C system. As with most of these sets there are three hoses, blue, red, and yellow for the low pressure, high pressure and vacuum pump or Freon charge. There appear to be Schrader valves inside one end of each hose. I cannot figure out why they are there. The valves are not blocking flow through the hoses, although they probably do restrict the flow somewhat. Connecting the hoses to the manifold or to the test port adaptors does not push on the Schrader valve center pins to actuate them or open them further. They do not seem to work as one way valves or really do anything other than offer some resistance to gas flow. I guess I'll just remove them. Don't understand why they are in there in the first place. The single page of instructions that came with the set does not mention them at all. Anyone seen this in a gauge/manifold/hose set or know what their purpose may be?
N6KB
Years of Membership: N6KB has been a member for 7 full yearsN6KB has been a member for 7 full yearsN6KB has been a member for 7 full yearsN6KB has been a member for 7 full yearsN6KB has been a member for 7 full yearsN6KB has been a member for 7 full yearsN6KB has been a member for 7 full years
Topics: 49
Images: 6
Alias (AKA): N6KB
  • No heat has got me stumped
    by teafreak35 » October 24th 2020, 6:24pm in Climate Control
    October 24th 2020, 10:57pm
    7
    98
    October 29th 2020, 2:58am
Re: A/C gauge set has Schrader valves inside hoses
Postby AstroWill » September 23rd 2019, 12:02pm
Just the valve depressors. It has to be able to depress the schrader when installed. My old set has them, my new r410a set has a screw in depressor on both the high and low side.
The ends that connect to the manifold shouldn't have anything in them other than their seal. Are you sure you bought the right thing? Maybe post some pictures.
Topics: 106
Images: 440
Postby Leeann_93 » September 23rd 2019, 10:48pm
As Will said, they're not Schrader valves, they're the depressors for the Schrader valves you connect the hoses to.
The side of the hose with no pins goes to your manifold.
Postby N6KB [OP] » September 24th 2019, 9:34pm
Yes they are depressors. There are no Schrader valves for them to depress in either the gauge manifold or the test port adaptors that came with the set. I suppose these hoses are also sold with other sets that have valves that need to be opened by the depressors. What is really depressing though is the R134a can adaptor. The center pin is not long enough to open the can, and I cannot get any more freon into the system.
N6KB
Topics: 49
Images: 6
Alias (AKA): N6KB
Postby Leeann_93 » September 24th 2019, 9:56pm
There's something new about the R134a cans. My husband's cousin was telling us about it when he brought over his '06 Liberty for us to test...there's a new thing you have to put in between the adapter and the can. Shut-off valve, maybe? Round blue spin-on thing...crap. Let me look...
EDIT: found it.
https://www.napaonline.com/en/p/BK_7653 ... 4a+adapter
New cans have self-sealing valves, old cans didn't. So old can taps are piercing-style and new ones are for the self-sealing cans. The above adapter lets you use an older piercing can tap with a new, self-sealing can.
Or you can just get a depresser-style can tap.
Postby N6KB [OP] » September 27th 2019, 7:33pm
Got the cheap plastic adaptor for the new style self sealing cans at NAPA. Not impressed with the setup, but it is usable. Could not get enough freon into the system to get the high pressure gauge up to 200 PSI because the compressor continued to cycle on and off. The solution was to ground the switched ground end of the A/C Compressor relay coil with a little wire wrapped around that pin of the relay and connected to a chassis ground screw. This kept the compressor operating continuously so I could finally get the pressure back up. The system is now working and with the ground wire removed the compressor stays on when it needs to.
N6KB
Topics: 49
Images: 6
Alias (AKA): N6KB
Postby Leeann_93 » September 27th 2019, 10:57pm
Yeah, I wasn't too impressed, either, but it does work. I'll get a new can tap at some point to replace the old+adapter.
Glad you got it all working, though.
Postby AstroWill » September 27th 2019, 11:05pm
Congrats! Glad to hear that you got everything working.
Topics: 106
Images: 440
Postby N6KB [OP] » September 29th 2019, 3:02am
After I got it working using the cheapo plastic adapter for the Freon can and the test port connectors that depress the Schraders on the car as soon as you plug them in, the better can fitting and test port connectors with open/close knobs on them arrived. So next time I'll be better equipped. One more feature I wish my set had is purge valves to purge the air out of the lines before charging the system. The only way I know to do it with my present setup is to loosen the hoses on the test port fittings and let a bit of Freon flow before tightening them back up. I don't see purging the lines mentioned in every description of how to charge your system, and I wonder how many people contaminate their systems with air from the manifold and hoses because they don't think about purging the hoses first.
N6KB
Topics: 49
Images: 6
Alias (AKA): N6KB
Postby AstroWill » September 29th 2019, 5:11am
N6KB wrote:The only way I know to do it with my present setup is to loosen the hoses on the test port fittings and let a bit of Freon flow before tightening them back up.
Yep, that is standard practice.
N6KB wrote:I don't see purging the lines mentioned in every description of how to charge your system, and I wonder how many people contaminate their systems with air from the manifold and hoses because they don't think about purging the hoses first.
There are a lot of things that aren't mentioned either because the instructions assume that you have some training, or it's amateurs that didn't know/forgot to mention it.
Topics: 106
Images: 440
Postby MechBob » September 29th 2019, 5:26am
"Topping off" the system is not a normal or approved procedure.The only way to properly repair an A/C system is measure the refrigerant,by weight,or(old way) see the luqid in an sight glass.But,hey,most of us have done it.The proper procedure is to use a recycling machine(I think Will pointed this out). But,bleeding the lines a bit,till the refrigerant seeps out is what most do,however illegal.
MechBob
Firing on 1 Cylinder (L2)
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Return to Climate Control
It is currently October 29th 2020, 2:58am
Climate Control Forum
Devo
in Climate Control
Date: Oct 25 '20
Time: 10:53pm
Date: Oct 17 '20
Time: 7:13pm
Date: Oct 03 '20
Time: 8:08pm
charlesives95
in Climate Control
Comments: 13
Date: Sep 25 '20
Time: 3:38am
charlesives95
in Climate Control
Comments: 13
Date: Sep 24 '20
Time: 9:00pm
