Ac pressure switch
Ac pressure switch
Postby gengomepyle [OP] » June 9th 2020, 3:32pm
I have a 2003 Astro, do I need to vacuum down my system to replace the ac pressure switch?
2003 Cargo Astro Van
gengomepyle
Years of Membership: gengomepyle has been a member for 2 full yearsgengomepyle has been a member for 2 full years
Topics: 10
Alias (AKA): gomer
Extra Info: 4.3
Re: Ac pressure switch
Postby Leeann_93 » June 10th 2020, 4:17am
No. There’s a seal to prevent that.
Postby gengomepyle [OP] » June 10th 2020, 8:22pm
Would a bad pressure switch cause the ac clutch from disengaging? It doesn’t disengage unless I turn the ac off.
gengomepyle
Topics: 10
Alias (AKA): gomer
Extra Info: 4.3
Postby Leeann_93 » June 10th 2020, 10:24pm
I had to replace the switch on the accumulator on my '93 Bravada because the compressor wouldn't run until my husband jumpered the connector. That is the low pressure switch, though - and that's the switch I was thinking about when I answered you.
The high pressure switch is on the back of the compressor and I actually don't know if that requires you to recover the refrigerant first. I've never had to replace that one.
Return to Climate Control
It is currently December 4th 2020, 2:19pm
Climate Control Forum
Date: Nov 19 '20
Time: 9:33pm
Date: Nov 18 '20
Time: 5:15pm
doogaloo
in Climate Control
Comments: 9
Date: Nov 09 '20
Time: 11:08pm
Date: Oct 31 '20
Time: 9:45pm
Devo
in Climate Control
Date: Oct 25 '20
Time: 10:53pm
Users browsing this forum: Google [Bot] and 12 guests
