a/c vacuum control actuator - where to buy?
Postby snailsafari [OP] » July 17th 2020, 9:58pm
1999 GMC Safari AWD
Was poking around under the dash and found this part dangling from a rod. Had to google the part number to figure out what it is since HVAC systems are not my specialty.
GM part number: 52470573
description: ACTUATOR, A/C Vacuum Control
it has a red hose/wire and a blue hose/wire. Seems that in normal operation an arm rotates and pushes down on the plunger presumably to swap air from hot to cold? (red and blue?)
either way, the plunger is definitely not descending since the whole thing cracked off of its bracket. I am more than happy to JBWeld it or something, but also like to know where I can buy this part new as a an option to fall back on.
Google just tells me discontinued at every source I can find.
thanks in advance
snailsafari
Topics: 5
Extra Info: SLE 4.3L V6 AWD
  • AC completely empty but manages to hold vacuum ???
    by kiwi_dollar » August 14th 2020, 12:26am in Climate Control
    August 14th 2020, 1:14am
  • HVAC vacuum issue?
    by Devo » October 25th 2020, 10:54pm in Climate Control
    November 1st 2020, 5:10pm
    7
    22
    November 29th 2020, 4:49pm
Re: a/c vacuum control actuator - where to buy?
Postby snailsafari [OP] » July 20th 2020, 9:00pm
Can anyone chime in on this ? Really cannot find it in stock anywhere.
If anyone lives near a u-pull-it I'll pay for part+shipping+time
snailsafari
Topics: 5
Postby snailsafari [OP] » July 20th 2020, 9:03pm
Or if we're aware of an updated part which replaced this component
snailsafari
Topics: 5
Postby snailsafari [OP] » July 22nd 2020, 4:27am
Update: Found a junked Astro van in a lot nearby and looked inside. Figured out how the thing is supposed to attach and picked up a tube a JB plastic weld. Should hold it over.
snailsafari
Topics: 5
Postby MechBob » July 22nd 2020, 1:08pm
Yep, no longer available.Most do what you are doing,some just prop door open and live without it.
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Return to Climate Control
It is currently November 29th 2020, 4:49pm
Climate Control Forum
Date: Nov 19 '20
Time: 9:33pm
Date: Nov 18 '20
Time: 5:15pm
doogaloo
in Climate Control
Comments: 9
Date: Nov 09 '20
Time: 11:08pm
Date: Oct 31 '20
Time: 9:45pm
Devo
in Climate Control
Date: Oct 25 '20
Time: 10:53pm
