Is this what a leaking compressor belly joint looks like?
Postby snailsafari [OP] » August 3rd 2020, 6:49pm
1999 GMC Safari AWD w/ rear a/c.
Issue is a/c not working on van. The system was completely empty, clutch not engaging. To troubleshoot I figured may as well see if the system works so I filled with 48oz R134a refrigerant. Clutch engaged and the the air blew cold. Well, cool - not cold. Within a few days or less (I don't drive it everyday) the coolant had completely leaked out and a/c clutch no longer engages and no cool air.
The bearing on the compressor started making a constant screeching sound when the clutch is not engaged, which was not there before. I would like to make that go away while I figure everything else out. I also noticed some wetness appear on the compressor after adding the refrigerant. Is this the infamous belly joint leak?
After running for a few minutes
A few minutes after adding 48oz coolant to empty system. Noticed small wet area on compressor.
4 days later, occasional use
4 days later, no cool air, clutch no longer engaging. Large wet area on compressor visible. Also a horrible screeching sound began.
Video Link Here is a short video file with audio showing the awful bearing sound. How can I fix this? Does compressor need replaced?
snailsafari
Extra Info: SLE 4.3L V6 AWD
Re: Is this what a leaking compressor belly joint looks like
Postby dcsleeper » August 3rd 2020, 7:05pm
That's yer clutch making noise, not the compressor which is not engaged.
But since it's all wet, and the clutch is making noise, yeah
Profile | Edit signature
dcsleeper
Topics: 19
Images: 77
Alias (AKA): DC
Postby snailsafari [OP] » August 3rd 2020, 10:29pm
Figured it was the clutch scraping. I'll see if I can put some CLP in there to help the clutch release fully.
Is anyone familiar with the compressor belly leak issue? I honestly do not know if the wetness is typical or atypical of a compressor. Usually I avoid touching a/c systems.
snailsafari
Postby Leeann_93 » August 4th 2020, 12:09am
If there's wetness, there's a leak. It's probably oil that you see.
Postby snailsafari [OP] » August 4th 2020, 7:16pm
Leeann_93 wrote:If there's wetness, there's a leak. It's probably oil that you see.
Rock Auto has a kit from UAC includes compressor, drier/accumulator, orifice tube, O-Rings and PAG 150 oil. What are thoughts on replacing condenser? And thoughts on UAC parts? The system still worked so I don't think condenser is clogged. Just trying to be budget friendly.
snailsafari
Postby dcsleeper » August 4th 2020, 7:31pm
if there was any mechanical damage to the compressor there could be metal in the condensor
It's easier to replace than clean.
try 1800radiator
dcsleeper
Topics: 19
Images: 77
Alias (AKA): DC
Postby Leeann_93 » August 4th 2020, 9:54pm
I've never used UAC. You should do a search to see if there are complaints.
Return to Climate Control
It is currently January 17th 2021, 1:11am
Climate Control Forum
Attached by: SportsBoy
SportsBoy
in Climate Control
Date: Jan 10 '21
Time: 5:10am
SportsBoy
in Climate Control
Date: Dec 31 '20
Time: 4:43am
SportsBoy
in Climate Control
Date: Dec 29 '20
Time: 5:46am
SportsBoy
in Climate Control
Date: Dec 27 '20
Time: 5:13am
Comments: 17
Date: Nov 19 '20
Time: 9:33pm
Users browsing this forum: Yandex [Bot] and 9 guests
