I need your wisdom...my mechanic is at a loss. We've replaced essentially all A/C components: drier, condenser, compressor and clutch, refrigerant pressure switch (on the back of the compressor), the clutch relay switch on the drier, and the evaporator and orifice tube. 8oz of oil added to the compressor. It holds vacuum. However, after happily blowing cold and running for 45 minutes, the compressor starts making a terrible sound, and the clutch face seems to be discoloring, assumedly from heat.
This is actually the second compressor this has happened to...we previously though the computer was bad, so we bypassed it, and presumed that bypassing the computer led to excessive wear on the clutch and compressor, causing the first failure. But we have since gotten the computer back in the loop (the actual problem was the refrigerant pressure switch) but the noise started happening to the new compressor as well.
Basically the entire system is new at this point.
No idea why this is happening. Anyone experience something similar? Am I missing something?
