My ongoing A/C Drama!
Postby Lee in Mountain View [OP] » October 3rd 2020, 8:09pm
Hello again members!
As I mentioned in my last episode; Blowing Cold! 40 Degrees! I though I had solved my A/C system problems of no cold air. Well, i did for a time. Slowly, over a period of more than a month, my A/C wasn’t as cold. So, figuring i had another leak, i looked again for leaks i may have missed. I believe i found in on the refrigerant hose that runs under the van to the rear A/C. This was suggested as a possible leak location in one of my earlier episodes. Found it with the help of the fluorescent dye. So, i plan to replace it tomorrow. The hose comes with o-rings, the A/C kit I purchased supplied o-rings. The ones on the replacement hose are the usual black o rings and the kit supplied the green o rings. Any opinion on which are better? Should i use what’s on the hose or change them out?
thanks...........Lee in Mountain View
My Tow Vehicle!
Years of Membership: Lee in Mountain View has been a member for 4 full yearsLee in Mountain View has been a member for 4 full yearsLee in Mountain View has been a member for 4 full yearsLee in Mountain View has been a member for 4 full years
Topics: 24
  • A/C repair drama comes to an end!
    by Lee in Mountain View » October 17th 2020, 7:16pm in Climate Control
    Last post by Lee in Mountain View View the latest post
    October 18th 2020, 2:00am
    7
    62
    November 25th 2020, 5:51am
Re: My ongoing A/C Drama!
Postby Rod's TrucksRod's Trucks is online! » October 3rd 2020, 8:45pm
Topics: 25
Images: 54
Alias (AKA): Rod and/or WE7X
Postby Lee in Mountain View [OP] » October 3rd 2020, 9:28pm
Thank you!!
My Tow Vehicle!
Topics: 24
Postby N6KB » October 3rd 2020, 10:00pm
Interesting about the o-ring colors. Are these color and characteristics relations an industry wide standard or do they only apply to the products from this specific supplier?
N6KB
Years of Membership: N6KB has been a member for 7 full yearsN6KB has been a member for 7 full yearsN6KB has been a member for 7 full yearsN6KB has been a member for 7 full yearsN6KB has been a member for 7 full yearsN6KB has been a member for 7 full yearsN6KB has been a member for 7 full years
Topics: 49
Images: 6
Alias (AKA): N6KB
Postby MechBob » October 3rd 2020, 10:20pm
There really is no "industry standard" for colors.Even black is used by some for r134.Will try to post a bit more.
MechBob
Firing on 1 Cylinder (L2)
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Postby MechBob » October 3rd 2020, 10:21pm
Prior to 1987, O-Rings for R-12 mobile AC applications were almost exclusively black.
Material-wise, the rubber in these O-Rings may have been Nitrile (Buna-N), Neoprene, or a blend
of these two compounds. In 1987, the Montreal Protocol mandated the change to a non-ozone depleting
refrigerant and OEMs around the world unanimously selected R-134a as the refrigerant
to replace R-12. In the aftermarket, refrigerants were offered that were blends of various base
refrigerants. Whether using R-134a or a blend of other refrigerants, the common trait among these
new refrigerants is that a different O-Ring compound was recommended for sealing. Several
new rubber compounds were identified as being suitable for sealing R-134a and the blend
refrigerant. The O-Rings that were made from these new rubbers have commonly been colored in
order to distinguish them from the earlier black O-Rings that were compatible only with R-12.
Over the past 15 years, O-Rings used in sealing hoses and components of mobile AC systems
have routinely been one of three colors: black, blue, or green. Black O-Rings offered by Four
Seasons are Neoprene and are fully compatible with R-134a, however, it is impossible to look at a
black O-Ring and tell if it is Nitrile (R-12) or Neoprene (R-134a). That is the reason colors have
been adopted. Blue and green have become the standard colors for those applications. The blue
O-Rings that are available today are Neoprene. They are colored blue with an external coating to
distinguish them from black nitrile O-Rings that are identical in appearance yet not recommended
for use with R-134a. The green O-Rings are Highly Saturated Nitrile (also known as
Hydrogenated Nitrile) and are commonly referred to as HNBR or, in some cases, HSN. In either
case, the green color is molded into the rubber. The blue Neoprene and green HNBR O-Rings are
interchangeable in their applications with R-134a, blended refrigerants, and R-12 as well.
Recently, there has been a move to consolidate the black Neoprene, blue Neoprene, and green
HNBR O-Rings offered in the Four Seasons product line to all green HNBR O-Rings. The
rationale behind this is that if all these O-Rings are equally compatible with R-134a, then it is
unnecessary to offer more than just one type. The elimination of the numerous duplicate part
numbers for black, blue, and green O-Rings will offer obvious benefit and will result in a general
simplification of the O-Ring selection process. The elimination of black Neoprene from the mix
is obvious as this compound presents an identification problem for the service technician. The
reason for selecting green HNBR over blue Neoprene is twofold. First is the fact that green
HNBR has OE acceptance and application whereas blue Neoprene has been predominantly an
aftermarket phenomenon. The second reason is because green HNBR has a slightly higher
operating temperature range when compared to Neoprene which makes it the slightly more
desirable choice. Add to these the earlier mentioned benefit of a large reduction in O-Ring SKUs
through the elimination of black and blue O-Ring part numbers and you have a clear picture of
why this change taking place.
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Postby Lee in Mountain View [OP] » October 3rd 2020, 10:41pm
Excellent information! Thanks MechBob!
My Tow Vehicle!
Topics: 24
Postby sixsix » October 3rd 2020, 10:54pm
Wow, just wow !!
Good data and plenty of it. Material - wise especially.
Gotta' Love the Neoprene vs Nitrile wars.
Thanks again, Bob.
Well, after all... what would Banacek say ?... “May be hard to believe... President Trump should rest easy and concede what was in fact a foregone conclusion: Another OLD MAN won with only about 50% of the Change Believers/Fools showing up."
Firing on 4 Cylinders (L5)
Topics: 38
Images: 1303
Postby AstroWill » October 4th 2020, 1:30am
I would use the new ones from the kit.
MechBob wrote:Prior to 1987, O-Rings for R-12 mobile AC applications were almost exclusively black..........
https://www.ericthecarguy.com/forums/to ... r-changes/
or directly from the 4seasons tech tip PDF linked here.
4S 376 O-RING COLOR CHANGES.PDF
(33.58 KiB) Downloaded 8 times
Images: 443
Return to Climate Control
It is currently November 25th 2020, 5:51am
Climate Control Forum
Date: Nov 19 '20
Time: 9:33pm
Date: Nov 18 '20
Time: 5:15pm
doogaloo
in Climate Control
Comments: 9
Date: Nov 09 '20
Time: 11:08pm
Date: Oct 31 '20
Time: 9:45pm
Devo
in Climate Control
Date: Oct 25 '20
Time: 10:53pm
