HVAC vacuum issue?
HVAC vacuum issue?
Postby Devo [OP] » October 25th 2020, 10:54pm
Hi Astrosafari . I’ve been working on my HVAC system and have gotten it pretty close to perfect except for a misdirection of air on floor mode. All modes work as they should except for floor. On floor mode there is some bleed through into the drivers side of the dash defrost. There also seems to be a little less force at the floor when it turned from cool to heat.
All engine bay vacuum system has been proved to hold vacuum, incl heat control valve and ball. I put vacuum on the line going into the firewall and there is a slow loss of vacuum.
I suppose the next move is to get in behind the dash and start proving vacuum lines and actuators. I was wondering if anyone had any tips on best way to get at all the lines and actuators.
I have used these sources that I found using this site and others.
https://sites.google.com/site/astrosafa ... ac-airflow
Thanks
Devo
Van Model Year: 2002
  • HVAC Assembly
    by DJMUSA » May 9th 2021, 2:02pm in Climate Control
    Last post by M_a_t_t View the latest post
    May 24th 2021, 5:17pm
  • Better vacuum hose?
    by N6KB » March 16th 2021, 6:49am in Climate Control
    Last post by Sparkydog View the latest post
    March 16th 2021, 5:58pm
    9
    86
    June 18th 2021, 3:37am
Re: HVAC vacuum issue?
Postby sixsix » October 26th 2020, 2:16pm
Devo wrote: ... gotten it pretty close to perfect
Cool, Hot and Welcome !!
All play Lori makes for a dull Nautilus.All work and no play make Lori a dull boy.All work and no play make Lori a dull boy.All work and no play make Lori a dull boy.All work and no play make Lori a dull boy.All work and no play make Lori a dull boy.
Years of Membership: sixsix has been a member for 7 full yearssixsix has been a member for 7 full yearssixsix has been a member for 7 full yearssixsix has been a member for 7 full yearssixsix has been a member for 7 full yearssixsix has been a member for 7 full yearssixsix has been a member for 7 full years
Topics: 39
Images: 1402
Postby AstroWill » October 26th 2020, 7:03pm
Devo wrote:All engine bay vacuum system has been proved to hold vacuum, incl heat control valve and ball. I put vacuum on the line going into the firewall and there is a slow loss of vacuum.
Yep, gotta get in there and test. It's easiest to start at the line that goes through the firewall to the control switch. Most of your diagnostics can be done directly at the switch using a vacuum pump w/gauge.
Topics: 109
Images: 481
Postby Devo [OP] » October 27th 2020, 6:29am
Thanks will. I plan on getting in there this week. I am suspecting the problem to be defrost actuator or line pulling it closed. Hopefully it is the line. But if it’s the actuator, does anyone know a part number for this? I have looked around: ac delco, rock auto, gym parts direct, autozone, Amazon. I’ve only found the electric temp control actuator.
Thanks
Devo
Postby AstroWill » October 27th 2020, 2:03pm
With these it's probably going to be a junk yard treasure hunt.
Topics: 109
Images: 481
Postby Devo [OP] » November 1st 2020, 4:59pm
Thanks astrowill.
I have gotten in and tested with my vacuum tool and have proven all functions. I can make the defrost door move through maximum range. Yet I still have bleed through to defrost when on floor mode.
So I think that perhaps the seal on the defrost door is getting hung up or has failed.
Is this area a real pain to get to? Can you get to it without pulling everything apart?
Devo
Postby AstroWill » November 1st 2020, 5:10pm
Some bleed through/mixing is expected, it's designed that way.
The actuator isn't hard to get to, but I'm pretty sure that to open it up and get to the door would be a bear.
Topics: 109
Images: 481
Return to Climate Control
It is currently June 18th 2021, 3:37am
Climate Control Forum
Date: Jun 12 '21
Time: 1:56am
stal023
in Climate Control
Date: May 30 '21
Time: 9:57pm
Date: May 27 '21
Time: 5:48pm
in Climate Control
Comments: 13
Date: May 26 '21
Time: 10:12pm
Olivier02
in Climate Control
Date: May 21 '21
Time: 1:07am
cron
