Ok, so had a two hour drive tonight and it’s about 20* out. Started out plenty warm after the engine heated up, but the strength of the air coming out of the vents slowly decreased until the van was freezing and barely anything was coming out o the vents after 90 minutes or so.
There was still hot air, but even on high barely anything was blowing out. The air did not become cooler, it just slowly stopped blowing.
When we arrived I looked under the hood to see this -
Seems like my accumulator got into the holiday spirit a bit late or something.
So, I’m pretty confused - not sure why the a/c system would be affected when I had the heater on (not on the a/c setting of course).
The only other thing I could find that was similar is this thread, which was very similar, except the guy was having this issue with his a/c running (which makes way more sense tbh) - https://www.astrosafari.com/viewtopic.php?p=27902
The blower motor and resistor were new this year, the plug is not. All that stuff looked fine though.
The rad and heater core hoses were definitely warm, and the engine temp gauge was at like 180 on the dash, so I don’t think the issue was lack of heat.
I also have eliminated the heater comtrol valves, so no issues there.
I’m wondering if anyone can help me out with why this is happening? I’m going to see what the ac compressor is doing when the hvac controls are going tomorrow, but I don’t even understand how that could be related. I’ll double check the blower motor resistor in the light. Plus I’ll check the a/c relay and low pressure cycling switch as well. Hopefully I find something odd with something, but if not the I’m fully lost.
Thanks folks
