P0442 - heater line leak?
Postby stal023 [OP] » May 30th 2021, 10:02pm
I popped the hood this morning trying to address an AC pressure leak and in that, this hose fell off (see photo issue #1)
If I'm following the diagram correct, this is the heater line. I can pull the line out completely from the rubber boot that is coming from inside the vehicle. How in the world do I fix this?
Issue #1
Hose diagram
images (1).jpeg (16.21 KiB) Viewed 166 times
stal023
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: stal023 has been a member for 3 full yearsstal023 has been a member for 3 full yearsstal023 has been a member for 3 full years
Alias (AKA): stal
  • Heater control valve leaks- always the valve?
    by highfigh » February 24th 2021, 5:13pm in Climate Control
    Last post by highfigh View the latest post
    March 11th 2021, 3:12pm
  • Front heater not working on full power
    by Paulc » March 1st 2021, 5:15pm in Climate Control
    Last post by Paulc View the latest post
    64
    June 12th 2021, 10:01pm
Re: P0442 - heater line leak?
Postby MI_Ghost » June 4th 2021, 4:34pm
You will need a length of 1/8" vacuum hose to replace it. It will connect to the rear heater switch.
~Ghost
Ast' Cargo: 2001 Astro Cargo
Beauty: 2009 Impala LT
https://www.astrosafari.com/gallery/sea ... r_id=66010
MI_Ghost
Firing on 4 Cylinders (L2)
Topics: 9
Images: 124
Alias (AKA): Ghost
Van Model Year: 2001
Extra Info: Big White RWD Box
Postby stal023 [OP] » June 4th 2021, 5:50pm
Can I remove that rubber housing that surrounds the 2 hoses that go inside the van?
stal023
Fueling (3/4 tank)
Fueling (3/4 tank)
Alias (AKA): stal
Postby MI_Ghost » June 4th 2021, 9:07pm
stal023 wrote:Can I remove that rubber housing that surrounds the 2 hoses that go inside the van?
That is a protective sleeve to keep the hoses from being cut on the sheet metal. You should be able to shove the new hose through it.
~Ghost
MI_Ghost
Topics: 9
Images: 124
Alias (AKA): Ghost
Postby AstroWill » June 6th 2021, 5:31am
You could but I would leave it in place.
Someone had butchered the vacuum lines on BB, had to replace the one that crosses the engine while on the road, A/C was stuck blowing to the floor. 2ft of 7/32 or 5.5mm vacuum hose(PN: 50211) and I stuck the vacuum check valve/tee directly into that rubber housing, firm fit and good to go.
Might do something different later, but if it's working, then it's already fixed ;)
Topics: 109
Images: 481
Postby stal023 [OP] » June 8th 2021, 1:57am
The leak is coming from inside of that as the hose came out of that rubber piece. I shoved it back in and then the check engine light came on after that. So....I need a better repair than just shoving the hose up into that rubber piece. Suggestions?
stal023
Fueling (3/4 tank)
Fueling (3/4 tank)
Alias (AKA): stal
Postby AstroWill » June 8th 2021, 2:07am
That isn't going to be the root cause of your code.
Topics: 109
Images: 481
Postby stal023 [OP] » June 10th 2021, 2:18pm
What is?
stal023
Fueling (3/4 tank)
Fueling (3/4 tank)
Alias (AKA): stal
Postby AstroWill » June 10th 2021, 9:51pm
stal023 wrote:What is?
Most of the time it's a leak in the EVAP system. Leaking fuel cap, filler hose/line, tank, hose, charcoal canister connections, purge valve, etc.
Topics: 109
Images: 481
Return to Climate Control
It is currently June 12th 2021, 10:01pm
Climate Control Forum
Date: Today
Time: 1:56am
stal023
in Climate Control
Date: May 30 '21
Time: 9:57pm
Date: May 27 '21
Time: 5:48pm
in Climate Control
Comments: 13
Date: May 26 '21
Time: 10:12pm
Olivier02
in Climate Control
Date: May 21 '21
Time: 1:07am
