AC wasn't working, got new compressor, still no AC
Postby DoubleDeckerStudios [OP] » June 8th 2021, 12:44am
Hey everyone, wondering if any of you guys have had this issue: No AC due to a bad compressor, I ordered this kit off ebay https://www.ebay.com/itm/163931681517
And had my local shop install it, still no AC.
What gives right?'
It's like the fan is barely blowing too if that helps.
DoubleDeckerStudios
Topics: 5
Alias (AKA): ROBIN
Extra Info: 4.3L RWD Topper
  • New AC compressor/clutch issue
    by Dbleeger » May 28th 2021, 7:40pm in Climate Control
    Last post by Dbleeger View the latest post
    May 28th 2021, 9:12pm
  • AC Compressor Style?
    by Psyckosama » May 18th 2021, 1:15am in Climate Control
    Last post by Psyckosama View the latest post
    May 21st 2021, 5:01am
    7
    62
    June 12th 2021, 10:28pm
Re: AC wasn't working, got new compressor, still no AC
Postby WoodButcher » June 8th 2021, 2:38pm
Does your heat and defrost work?
The fan / blower is a separate system from those parts you replaced. If a shop did the work they should have informed you of the issues.
WoodButcher
Firing on 6 Cylinders (L6)
Topics: 30
Images: 514
Alias (AKA): Bruce
Extra Info: 5.7L RWD
Postby AstroWill » June 8th 2021, 7:02pm
If you are not getting proper airflow, then it's most likely a blower motor/controller issue or a vacuum control issue.
Topics: 109
Images: 481
Postby DoubleDeckerStudios [OP] » June 10th 2021, 2:01am
Heat and defrost seam to be working. Its just blowing warm air on AC or Max AC though.
DoubleDeckerStudios
Topics: 5
Alias (AKA): ROBIN
Postby Mmusicman » June 10th 2021, 1:08pm
DoubleDeckerStudios wrote:No AC due to a bad compressor,
And had my local shop install it, still no AC..
Wow.. an expensive bad assumption on your part?
And the "shop" can't make it work either? Huh!
You might need to look for a new shop.
By the way.. A/C system is comprised of 3 sub-systems:
1) Refrigerant (compressor, coils, freon, etc)
2) Fan (switches, wiring, fuses, relays, connectors)
3) Vent control (vacuum lines, vent doors)
Don't confuse their operations.. each very different:
Example1: if you have a problem with your fan, then it's not a bad compressor.
Example2: if you have a problem with your vents, then it's not a bad compressor or fan
Example3: if "air blows" but never gets cold (even if coming out wrong vent), then it's probably an issue with refrigerant system and not a bad fan (assuming switch controller in correct position).
Purple Status (L6)
Purple Status (L6)
Topics: 74
Images: 61
Postby AstroWill » June 10th 2021, 9:57pm
Does the compressor kick on? What are your pressures at?
Topics: 109
Images: 481
Postby WildBorego » June 10th 2021, 11:37pm
AstroWill wrote:Does the compressor kick on? What are your pressures at?
this!
WildBorego
Images: 100
Alias (AKA): George
Extra Info: V6 4.3L SLX RWD
Postby 97cargocrawler » Yesterday, 4:46pm
That ac cycle switch is always my first test. Located on the accumulator.
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Return to Climate Control
It is currently June 12th 2021, 10:28pm
Climate Control Forum
Date: Today
Time: 1:56am
stal023
in Climate Control
Date: May 30 '21
Time: 9:57pm
Date: May 27 '21
Time: 5:48pm
in Climate Control
Comments: 13
Date: May 26 '21
Time: 10:12pm
Olivier02
in Climate Control
Date: May 21 '21
Time: 1:07am
