A/C Hi/Lo End Service Valves On 94' Astro
Postby JohnnyC16117 [OP] » May 23rd 2012, 10:07pm
Can anyone tell me or have a pic on where the low side A/C service valve is on my 94 AWD Astro (w)-Vin can be located ? From the front of van under hood I can only find one service valve to the front left of the accumulator on passenger side that sticks up fairly high off of a thin piece of tubing with a black cap on it (Figure One). The line looks too slim to me to be the low side..or is it? I am going to attempt to put a charge to the A/C and run some dye to see if I can find my leak myself to save some $$$ , I have never charged A/C on an Astro before and not sure where what service valves are where :?: My first step is to find the low side valve , would also like to know where the high side is as well and the release valve if equipped with one..Maybe (Figure Two)?? Figured I would start by locating the low side valve first, any help is much appreciated...thanks in advance :D
Figure One: Red Arrow Shows The Valve I Did Find
Figure Two: Another View Of Valve ( What is the valve on accumulator marked with Green Arrow? )
Not Sure If This Is Low Or High Side?
Not sure what the valve on the accumulator is for either
JohnnyC16117
Years of Membership: JohnnyC16117 has been a member for 8 full yearsJohnnyC16117 has been a member for 8 full yearsJohnnyC16117 has been a member for 8 full yearsJohnnyC16117 has been a member for 8 full yearsJohnnyC16117 has been a member for 8 full yearsJohnnyC16117 has been a member for 8 full yearsJohnnyC16117 has been a member for 8 full yearsJohnnyC16117 has been a member for 8 full years
Topics: 7
Images: 11
Alias (AKA): Johnny C
Extra Info: CS 4.3L V6 AWD W-Vin
  • LO I I HI
    by DaHonu » May 12th 2020, 4:28am in Climate Control
    Last post by DentManDave View the latest post
    August 25th 2020, 3:15am
  • AC hi-Lo pressures
    by DentManDave » August 25th 2020, 3:12am in Climate Control
    August 27th 2020, 12:52am
    7
    35
    October 28th 2020, 11:49pm
Re: A/C Hi/Lo End Service Valves On 94' Astro
Postby Shad0wXCalibur » May 23rd 2012, 10:17pm
That valve on the accumulator is the low side port. Its supposed to have a cap on it, too.
1987 Astro
2000 Safari
Shad0wXCalibur
Years of Membership: Shad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full years
Topics: 41
Extra Info: Lifted 2wd
Postby JohnnyC16117 [OP] » May 23rd 2012, 10:35pm
Thank You Shad0wXCalibur. I would have never thought it was on the accumulator itself and still been out there digging around for a valve on a line that don't exist LOL... It was charged before I was told from previous owner but would loose charge after a couple of days and blow warm air again. I read that the accumulator's go bad after approx 5 years and from what I know this one has never been replaced , would you suggest changing the accumulator itself before going any further and charging with refrigerant and dye?
JohnnyC16117
Topics: 7
Images: 11
Postby Shad0wXCalibur » May 23rd 2012, 10:51pm
The accumulator has desiccant in it that absorbs moisture. You replace it when you open up the AC system because you expose it to moisture. Also replace the orifice tube since its a $3 part. Leaks could be from old o-rings or the crimps on the rubber lines. When you figure it out and put it back together, make sure to pull a vacuum to remove any moisture and make room for the freon.
I paid a shop to fix the AC on my 2000 because they are better equipped to diagnose and fix it. It's too much trouble for me and I'm a DIY kind of person.
1987 Astro
2000 Safari
Shad0wXCalibur
Topics: 41
Postby JohnnyC16117 [OP] » May 23rd 2012, 11:20pm
I may just end up doing the same thing and taking to shop if it becomes too much of a hassle. Before I open up the system or anything else I am going to try AC Super Seal and cross my fingers. If that don't do the trick I'll be taking mine in for the repair(s) as well .Ill post back results I get from the Super Seal D.I.Y. fix.. Thanks again for the info :D
JohnnyC16117
Topics: 7
Images: 11
Postby JohnnyC16117 [OP] » May 29th 2012, 9:10am
Not holding a charge for more than a couple days ..so decided not to even waste the time or money on the Super Seal.. Off to the shop she goes Im going to mention to them to be sure to replace the orifice tube while they are at it as well as u mentioned, thanks for the info & tip
JohnnyC16117
Topics: 7
Images: 11
Postby CharlieV » July 8th 2012, 1:30am
I plan on recharging my A/C in my '97 Astro tomorrow. Would the location of the ports be the same as in JohnnyC16117's photo? If not, where is my low side port located? If you can upload a photo with your response that would help, that is if it is different.
MARK MY WORDS, THE PUFF WILL RISE AGAIN!!!
CharlieV
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: CharlieV has been a member for 8 full yearsCharlieV has been a member for 8 full yearsCharlieV has been a member for 8 full yearsCharlieV has been a member for 8 full yearsCharlieV has been a member for 8 full yearsCharlieV has been a member for 8 full yearsCharlieV has been a member for 8 full yearsCharlieV has been a member for 8 full years
Topics: 19
Extra Info: 4.3L V6 RWD CARGO
Postby Shad0wXCalibur » July 8th 2012, 1:38am
Yes. The low side will be on the accumulator and high side on the metal line. That's how it is on my 2000.
1987 Astro
2000 Safari
Shad0wXCalibur
Topics: 41
Return to Climate Control
It is currently October 28th 2020, 11:49pm
Climate Control Forum
Devo
in Climate Control
Date: Oct 25 '20
Time: 10:53pm
Date: Oct 17 '20
Time: 7:13pm
Date: Oct 03 '20
Time: 8:08pm
charlesives95
in Climate Control
Comments: 13
Date: Sep 25 '20
Time: 3:38am
charlesives95
in Climate Control
Comments: 13
Date: Sep 24 '20
Time: 9:00pm
