No heat from rear passenger floor heater
Postby DJWerkz [OP] » May 26th 2012, 10:50pm
I have rear heat option on my 1998 Astro, all speed settings work fine on the rotary rear heat switch but only cold air blows out from rear floor vents, any ideas?
Regards,
Craig
DJWerkz
Years of Membership: DJWerkz has been a member for 8 full yearsDJWerkz has been a member for 8 full yearsDJWerkz has been a member for 8 full yearsDJWerkz has been a member for 8 full yearsDJWerkz has been a member for 8 full yearsDJWerkz has been a member for 8 full yearsDJWerkz has been a member for 8 full yearsDJWerkz has been a member for 8 full years
Extra Info: LT 2WD
Re: No heat from rear passenger floor heater
Postby chevymaher » May 26th 2012, 11:13pm
Somebody bypassed the hot water going to it because it was leaking.
Re: No heat from rear passenger floor heater & other problem
Postby DJWerkz [OP] » June 20th 2012, 7:07pm
Further information provided as other problems have arisen:
Previously front blower/heat control worked fine but I have noticed while driving that when I have the airflow set on vents the air output is almost non-existent, then at others times at the correct speed. Then last night I got no air from vents at all, speed control works as you can hear the blower motor increasing/decreasing in velocity as you turn the switch but the airflow switch does nothing, airflow will only exit via the windscreen vents no matter where you set the airflow switch.
Temperature switch seems to be ok as I can adjust temperature properly.
Looking forward to receiving your help.
DJWerkz
Extra Info: LT 2WD
Postby chevymaher » June 20th 2012, 7:14pm
Vacuum line that controls vents is leaking or the check valve is clogged.
Postby DJWerkz [OP] » June 20th 2012, 7:28pm
Cheers buddy, will take a look tomorrow and report back.
DJWerkz
Extra Info: LT 2WD
Postby redfury » June 21st 2012, 5:21am
Also, you may find that the 6 way valve has gotten clogged up. You may want to disconnect the heater hoses going to the rear heat and see if you can back flush them with a garden hose as well as take a good look inside the passegeways for the heater control.
Easiest fix would be the rear heat solenoid died ( they do ) which is on top of the heater valve assembly, and you can simply bypass that and draw straight vacuum to the valve underneath it to open it up and allow coolant to flow. That would be your first step, especially since you are having other problems with your heat. Likely there is something wrong with the vacuum as it is if you are getting on again, off again heat control or it's only blowing through the defrost ( default setting when vacuum is lost ).
This is all too common on these vans. My particular van had the rear heat disconnected completely ( no valve or anything left! ) when the guy installed the V8. He just used front heat and bypassed the valve and rear heat.
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Extra Info: LT 5.7L 4wd
Postby DJWerkz [OP] » June 22nd 2012, 11:50pm
Greetings!
Thanks for the additional comments/suggestions. The vacuum hoses were very corroded, rubber resembled burnt toast to the touch and crumbled away lol. I replaced the vacuum hose that runs from top of engine located just behind the AC compressor (had to get my 12 year old boy to get his skinny arm in there to disconnect and re-connect it) plus any others I could see and get access to. This has fixed the problem with blower only blowing out of defrost vents so that's great.
All hoses to rear heat seem to be connected as per original factory installation, i.e. no signs of anyone having tampered with them/capped them off. 6 way valve looks original and solenoid is too so I will try the suggestions of bypassing it.
Best regards from the UK.
DJWerkz
Extra Info: LT 2WD
Return to Climate Control
It is currently September 28th 2020, 1:22pm
Climate Control Forum
charlesives95
in Climate Control
Comments: 13
Date: Sep 25 '20
Time: 3:38am
charlesives95
in Climate Control
Comments: 13
Date: Sep 24 '20
Time: 9:00pm
in Climate Control
Comments: 287
Date: Aug 28 '20
Time: 5:27pm
in Climate Control
Date: Aug 27 '20
Time: 12:42am
Attached by: MechBob
MechBob
in Climate Control
Date: Aug 20 '20
Time: 10:48pm
